Alignment Specs
Old Aug 2, 2023 | 06:30 AM
Nabil3IS's Avatar
Nabil3IS
Default Alignment Specs
Hello,
I am about to get some 90 Duro FIGS LCA bushings (inner tire wear) installed and from my understanding I would need to get an alignment afterwards. Before I go ahead and get everything done I wanted to check and see what the alignments specs should be so that I can double check the shop's work. My car is completely stock in terms of suspension (no spacers, no lowering springs/coil overs, no aftermarket wheels, etc...) and I am on the OEM F-Sport rims and on stock tire sizes. The only "mod" would be the new LCA bushings but that's it. Any insight would be appreciated!
Old Aug 2, 2023 | 11:45 AM
laobo979's Avatar
laobo979
No alignment needed as it doesn’t affect toe or camber. Install and drive. You can do one if you haven’t done one in years.
Old Aug 7, 2023 | 06:02 AM
Nabil3IS's Avatar
Nabil3IS
oh okay, I didn't know that. I had some people tell me that I would need one. Thank you! Though, if anyone still has the specs I'd appreciate it for reference.
Old Aug 7, 2023 | 02:52 PM
LA20671's Avatar
LA20671
I did alignment when I installed mine. I guess I did it because I installed my RSR springs and FIG LCA bushing at the same time. Waited a week till my car got settled and did the alignment. I would still do it though.
Old Aug 8, 2023 | 06:23 AM
atomic300's Avatar
atomic300
10th Gear
This is what I found before.
Lexus Specs 2017: AWD Front: +0.05 (toe-in) AWD/RWD Rear: +0.18 (toe-in)
AWD Factory Camber Specs Front -0.48 +/-0.75 (Max: -1.23) Rear -1.63 +/-0.75 (Max: -2.38)
Old Aug 10, 2023 | 12:35 PM
nomad21's Avatar
nomad21
2nd gear
@Nabil3IS What model is your IS? i have a 21 F sport RWD all stock, and i have inner tire wear. can you share the Figs bushing part number you got? My Mechanic is skeptic about the alignment working but i saw in the post below that it does not affect alignment.
Old Aug 10, 2023 | 03:12 PM
Pittsy's Avatar
Pittsy
It technically shouldn't affect your alignment, but its not a bad idea to have one done afterwords anyways.
Old Aug 10, 2023 | 04:36 PM
nomad21's Avatar
nomad21
2nd gear
@Pittsy do you have a gen 3 ? Did you do it on yours? All the videos online are on older models.
Pittsy's Avatar
Pittsy
I did it on my 2015 RC, same thing.
Old Aug 10, 2023 | 07:07 PM
Nabil3IS's Avatar
Nabil3IS
These are the LCA Bushings I got. But they REQUIRE a bearing press to be installed. These aren't just bolt-on. These are the bolt-on versions.
bgross88
Jul 21, 2021 05:28 AM
AVIAT0R
Dec 12, 2019 09:35 AM
nosurprise
Suspension and Brakes
Mar 20, 2018 09:38 PM
speed6
Dec 13, 2008 02:45 PM
BA_GS400
Sep 1, 2006 12:44 PM
