Turn signals won’t work
Old Aug 14, 2023 | 05:13 PM
lexyis3's Avatar
lexyis3
9th Gear
Default Turn signals won’t work
Hi everyone,
Suddenly both my front/rear signal lights are not working. Hazards aren’t working either. What fuse(s) are related to this?
Another issue is none of my doors being able to lock, either via the key fob or the inside lock switch.
If anyone could guide me to the related fuses or would be deeply appreciated! Thank you.
Old Aug 15, 2023 | 06:42 AM
arentz07's Avatar
arentz07
Do you have any modifications to the car such as aftermarket lighting? Just want to rule that out right away as we've had lots of questions that ended up tracing back to a modification as the cause.
There should be labels on the inside of the fuse box to indicate what each fuse is. I think it is likely the indicators are in the larger fuse box located on the driver's side of the engine bay, since the wipers are also on that side. Check there for blown fuses if you think that is the issue.
Tootsall
Jun 13, 2023 09:16 AM
Jessek1486
Oct 27, 2018 08:00 PM
kayyjohnst
Jul 1, 2017 03:28 PM
AlaskaUSA
Jul 17, 2014 01:22 AM
2jzNoShiz
Apr 28, 2010 12:12 PM
