- Clutch replacement
- need help with auto tranny on 93 sc400
- Amsoil Help
- HELP AC doesn't work
- 1uz-fe (71, 76mm turbo spool)?
- Short shift kit
- Canister is leaking Gas...Please Help !!!
- Does anyone still use the MSD BTM?
- 95 SC300 won't shut off
- traction light flashes, check engine on. Car won't drive
- TT coil fitment on a na-t (please advise)
- Where O Where do my hoses go? W/pics
- AEM EMS+ JDM 2JZ-GTE help please
- Any Plug and PLAY standalone for aristo engine
- sc300 belt squeal
- Crank Pulley Bolt Removal?
- Cam Gear Cover Mod and 02 Sensor Question
- Squeaky Clutch 94 SC300
- Few questions for a Newbie (engine swap questions)
- Where to begin
- Question i'd like an answer to please (Engine Swap Questions)
- One simple question!!!!
- ge water pump on 1j?
- car bogging and hesitating. pls help :(
- I just got my 92 lexus sc400
- Smart people...
- '92 5sp won't crank, no fuel, no power door locks after installing new battery
- Supra flywheel
- 1993 SC400 Over Heating Problem
- 1JZ hesitation issue
- Difference Between 2 W58 shifters?
- Changed spark plugs, now car barely running...HELP
- supra fuel pump?
- results on
- *What car is this clutch pedal from*
- Code 52+55 (Knock Sensor)
- Camshafts...1uz
- Check engine light
- exhaust leak help
- 2jz-gte + w58...clutch component concerns...
- A few problems/diagnosing help
- IS300 steering wheel? what is needed?
- Fuel cut? clutch slippage? HELP!
- knock sensor help!!!
- Do you trust this TURBO MANIFOLD?
- Anyone run a surge tank??
- Crank Pulley
- NEED help >how to install GM3 bar map sensor
- will a mk4 torque converter fit my 1jz/a340e swapped sc300?
- Oil leaking from 94 SC300 2JZ-GE
- purchasing a 97' sc300 five speed manual, motor swap help
- 1jz auto
- Head Game Whats The Difference VVTi Head VS. Non VVTi Head
- Short Shifter
- Car missing and stalling
- JDM 1jzgte california legal
- washed my engine bay, but the problem is not what you think, help please
- Mounting a MKIV Stock Intercooler
- W58 and 1jz
- Diff centre replacement
- Megasquirt II v3.0 Q's & A's
- Trans swap question
- 98 2jzge vvti into an 94 sc3
- 1jz/2jz with emanage blue install direction
- Speedometer Issue
- So has anyone tried installing injen's intake on 96+ SCs?
- where to find 1jz distributor?
- 98+ cluster in 92~96 sc300
- Best way to drain P/S fluid?
- Electrical Wiring Issues w/ Pics
- Some GTE swap questions
- Stock exhaust piping size
- OBD II 1jzgte?
- 98 sc400 vvt-i possible drive shaft problem, not sure though..
- 98 sc400 vvt-i custom exhaust pipe while retaining stock mufflers..
- JDM Oil Return Line - At wits end please help
- quick question
- trans slip intermittent
- Single turbo questions.
- almost there...na-t need some help/advice befor i start the car
- Help...Starting problems...
- Newly purchased SC400
- Quick A/F readings from my AEM UEGO (video)
- Keeping my 1JZ-GTE.. possibilities?
- 2jzgte into a 2000 SC300...doable?
- OMG! I broke my PI Dragon converter!
- walk through of manual conversion?
- heater problem
- Going Single Turbo.. Need some help!
- After market radiator
- Junkyard Electrics Fans PICS
- Wiring Up the Alt.
- 1jz swap very odd problem
- Replacing Main Cat with Cutout - But I have a question
- sc300 kick panel fuse diagram picture
- 1jzgte 1st start up advise
- Greddy sld on JDM GTE swap issue
- Smoke on Start up
- SC300 auto speed sensors (HELP!)
- Map Ecu 2 VS AEM FIC
- BFI or SRT/ecu Intake
- pre 91 4runner distributer guys chime in.
- Got exhaust on the car
- 1uzfe NA 420rwhp @ 9300rpm
- 1jzgte-vvti turbo manifold
- takes forever to warm up
- 92 SC300 ecu, fuel pump problems
- 92 SC300 Sub-O2 Code 27
- New to sc300 !! Need help please ! Turbo etc.
- 1JZ-GTE or 2JZ-GTE? ..
- new sc owner. the mods start.
- 1999 SC400 vvti Custom Exhaust
- Sway bar in the way of lower radiator tube
- SC300 5MT 5th gear whine noise
- Conversion Gasket set???
- Stock 1JZ going Single.. Turbonetics?
- Heater problem
- Strange gas needle activity.
- 1jz transmission slipping help
- Fuel pump control unit re-build
- Anyone have a 1JZGTE ECU recapped?
- Sc400 overheating,
- 2jzgte/96 sc300 swap
- Dilemma over which turbo.
- How important is this heat shield?
- A340E tranny pinouts
- maf unplugged
- Spark plugs whats good??
- oil restrictor hole size
- Exhaust question
- Rebuild trans?
- '94 SC400 Hydro Pump Leak
- SC300 how to check and add tranny fluid?
- Best SC to modify for high performance
- E3 Spark Plugs
- Bottom alternator flange nut stripped - size?
- VSS/Pink wire from cluster question-all with inst cluster knowledge
- What is my drivetrain worth. (Built Soarer R154, ACT Stage 4, DS, NA Rear End w/lsd)
- 1JZ Not Starting
- Car won't start, fuel pump staying on
- Help - Issues with - Memory Seat - Heated Seats - Button
- just got my sc300 on the dyno :-/
- took my sc to get dyno'd
- what are some perfomance mods for my 94 sc400
- bad wheel bearing causing poor mpg?
- Timing Belt
- Took my Sc down the 1320!
- Alternator
- low budget dual full pump
- my sc300 turbo project
- cat and resonator delete?
- Exhaust smells like fish?
- 95, SC300, no fuel no start issues.
- Should I get the Timing Belt parts at the dealer?
- how much hp with this set up
- Power steering fluid flush, How?
- !NEED HELP! misfiring??
- sc400 gauge cluster help 1jz
- EGR valve on 92 SC 400?
- Hesitation finally fixed!
- AEM EMS help with emissions controll
- steering wheel stuck
- making 700+ on r154
- 1jz+bpu=?
- Just changed my battery -- starter wire too short
- Non VVTI to VVTI?
- For those who went GTE w/Aristo Auto trans...
- blinkers, haz flashers, gauge backlight doesnt work
- Aluminum radiator for not much $$$, pics inside.
- Need Help! Coolant in valve cover covering spark plugs????
- Problems with my starter wiring
- pcv question with pics...
- Auto Transmission code 87 anyone know??
- sc400 & ls400.. same trans?
- breaking up around 3.5-4k after 440cc swap????
- SC 300 Rusted Gas Tank
- 1jz fine till i hit 13 lbs of boost. little help pls.
- Want better gas mileage? Clean your TB and Plenum
- spark plug & wire replacement help
- stock exhaust question
- one step closer to boost!
- adjustable fuel pressure regulator???
- It Begins... My swap
- 1jz owners chime in. How long is your dipstick?
- Video 1UZ with Individual throttle bodys!
- Greddy/ trust jdm exhaust need piping advice
- 95' SC300: What is the best route to turbo my car?
- serpentine belt tensioner replace on 93 SC400
- Whistling "cricket" noise when clutch pedal is released
- Alternates to Soarer harness
- Why wont my car start...
- Compression Testing
- 93 SC300 AC/Heater control not working
- Correct idle for a 1jz single turbo?
- Any benefit with Magnaflow's x pipe vs the Summit store brand?
- What plug is this...?
- 1jz timing belt tensioner
- Problems still with the Speedo after install of new rear end.
- Sc400 acceleration (video)
- Need a How-To/DIY for removing 2JZGE Intake Manifold..
- 92 sc300 5 speed stalling
- need some help or suggestions
- 5speed swap help!!!
- Treadstone Intercooler core?
- Screeching Window (with video)
- 2jzfte swap info needed
- exhaust for a sc300
- a/c help!!
- anyone ever get wastegate clearance issues
- Driveshaft help needed...
- Exhaust help
- any Ignition system DIY (sc300)?
- can i boost it without rebuilding it?
- I need some help!
- injen intake or custom intake??
- Knocking after NA-T? Valve tapping? Wired noises.
- Compression test validity?!?
- 2jz swap abs light?
- New Exhaust
- gauge prolbem
- AC just cut off while driving
- Transmission Whine After Swap
- so BHG DAMN!
- Knock Signal issue...please help
- 2JZ-GTE Swap Into An SC400? Should I?
- walbro fuel pump question.
- 1JZ, 2JZ swap?
- Please help me out, my 1st sc400. ENGINE dies while shifting to 2nd gear
- SC400 Problem (Engine/Mechanical) - Please help
- Airbag wiring polarity
- help please!! Fuel pump won't cutt on
- 1jzgte-vvti manifold
- Length of engine and transmission
- Soundclicp of my single exit sc400
- Would the 1JZ/2JZ models with TRC fit into a 92???
- transmission solenoid
- TRD Strut Tower Bar on SC400
- Blown headgasket on 1uz?
- Problem with Passenger Window switches
- Close to impossible to safely get the PS solenoid filter out in SC400 !
- For those running a getrag and 6-speed rear end
- How high do you rev your stock 2JZGE?
- Frustrating Starting Issue!!!
- Clutch Pedal Return Spring
- wire harness question
- ge upgrades?
- 1jzgte VVTI
- Need a Coolant Reservoir Tank -
