washed my engine bay, but the problem is not what you think, help please
Old 10-22-09, 12:12 AM
UTSC300
UTSC300's Avatar
Default washed my engine bay, but the problem is not what you think, help please
well yes i did the stupidest thing ever, i washed my bay. But it didn't start acting funny till hours later. i had the car jacked up from the front end and when i put it back down it's sputtering like it only running on 5 cylinders. mind you the car was running fine for hours before. when i jacked it up i messed with nothing electronic. could somehow some water gotten in their when it was raised? i replaced spark plugs 1,2,5,6 . 1 was a little wet , the rest were bone dry which makes me think 3, and 4 will bone dry too. any suggestions? i'm not pulling any codes , it just runs like **** . I tried running it for a while to evaporate any water and no dice. let me know what you think. thnx
Old 10-22-09, 09:39 AM
ICONYQ
ICONYQ's Avatar
did you check distributor for water?
Old 10-22-09, 10:02 AM
BSC300TT
BSC300TT's Avatar
maf? maybe when washing it did you disconnect a vacuum hose?
Old 10-22-09, 10:24 AM
meangreen1
meangreen1's Avatar
Sounds like water in the plug holes. Try pulling your plugs and drying everything out. Oh yeah, make sure to put the wires back in the right location.
Old 10-22-09, 11:26 AM
UTSC300
UTSC300's Avatar
dizzy is dry as a bone, if the maf was f'd i would get a code wouldn't i?. I have not touched any vaccum lines. but usually a leak or disconnected hose would only affect idle wouldn't it? but if water was in the plug holes wouldn't it run like **** as soon as i started it? not 4 hours later.
Old 10-22-09, 02:48 PM
IOWNALEXUS
IOWNALEXUS's Avatar
I bought a 95 SC that had just had the engine bay washed, it missed and ran like crap the whole time i test drove it, i got the dealer to take $500 off cause i said it needed a tune up.
I drove it home from atlanta like that (200mi) and it cleared up and ran mint about halfway home and i had no issues after. I was pretty sure water got down into the plug galley and once it got hot evaporated and fixed the issue. so i suggest getting on the highway and driving for an hour or so and see if it clears up, also pull off the plug wires on the cap one by one and see which one is missing, youll know which one it is because the bad cylinder wont make any difference and the good ones will make the miss worse.
Old 10-22-09, 04:36 PM
UTSC300
UTSC300's Avatar
yeah i got her up to operating temp and drove for about ten min with no change. maybe i should just take it on a long drive. I'm going to do plugs test with the wires hopefully it points out plug 3 ,4 as my problem. I'm still wondering why their was a delay in making the car run like **** until i jacked it up.
Old 10-22-09, 04:52 PM
LEX_MAN
LEX_MAN's Avatar
LOL my car was running like crap for about 2 weeks after i washed my engine bay.
Old 10-22-09, 04:55 PM
UTSC300
UTSC300's Avatar
and you just drove it daily like that , and it finally fixed itself ??
Old 10-24-09, 03:25 PM
Justinizme
Justinizme's Avatar
I had this EXACT problem! Ended up being the passeneger side coil.. Replaced the coil and never looked back.. This was on my sc400 that is.. Now, since its a 300 you're working on, definitely check the coil.. OR unplug the plug wires one by one and see which cylinder is not firing correctly.. When you find it.. Replace the plug wire.. If it still acts up, replace the coil.. Odd's are it will correct itself.. Hope this helps!
Old 10-24-09, 03:49 PM
t70 supra
t70 supra's Avatar
ut run compressed air in ur gally and see what happen if water shoots up u know the problem and try using a dry rag also.
Old 10-24-09, 03:55 PM
IOWNALEXUS
IOWNALEXUS's Avatar
Its NOT the coil..... reason i know this?? cause there is only ONE COIL on his car so if it were bad the car wouldn't run. He just needs to go drive it around for a couple of hours and burn the water off.......
Old 10-24-09, 04:06 PM
Justinizme
Justinizme's Avatar
True.. Hence the reason I suggested going thru and testing plug wires.. I was mainly thinking of my 1uz.. My apologizes..
Old 10-24-09, 07:02 PM
IOWNALEXUS
IOWNALEXUS's Avatar
True.. Hence the reason I suggested going thru and testing plug wires.. My apologizes..
Which is what i suggested 4 posts above yours (in post #6) 2 days ago. No reason to apologize you were only trying to help.....
Old 10-25-09, 11:03 AM
UTSC300
UTSC300's Avatar
UPDATE : The car is running perfect now . I actually had two things wrong . When i was working on my car earlier i had undone a vaccum line going to the EGR . With that fixed i drove the car for about an hour to Nevada for some gambling cleared right up on its own. btw yeah thought about the coil too , but then thought yeah if that was gone the car wouldn't run. But thnx for all the help , u guys are awesome . I will never wash my engine bay again lol
Quick Reply: washed my engine bay, but the problem is not what you think, help please
