View Full Version : Suspension and Brakes
Pages :
6]
13
14
15
16
17
18
19
20
- Newbie question to lowering
- C8 Coilovers?
- are SPC camber kit any good?
- Rear alignment specs -0.28 Toe bad?
- SPC Camber adjustment tool
- Stainless Steel Brake Lines, performance upgrade or not?
- 06 is350 Shock Question
- Trunk won't close help!!!
- Tanabe Pro Five or Z40
- Help: front upper Ball Joint removal and/or SPC installation
- Help air runner system
- H&r & awd???
- Lowering Springs and Struts Combo
- Getting both rear tires spinning?
- Tein CS EDFC beeping at me and not functioning properly
- Need help with False floor and notch frame
- F Sport BBK
- Bc coilovers & Swift springs on is 250 awd
- Installing Megan LP, replacing one shock
- Megan Camber Kit
- F Sport Shocks Only?
- Fsport BBk kit not fitting 2009 Awd IS250
- Megan camber arms for front please chime in.
- d2 racing coils
- Is350 calipers and rotors on is250 awd
- Lowering springs
- 65k miles. All 4 struts to be replaced?
- Help with brakes and rotors on 2009 IS250
- Small Project: Accuair upgrade with hard lines
- Upgrading front brakes to IS350?
- brake pad suggestions?
- Stoptech/ Centric rotor RUST
- How low can you go!
- Help with noise over bumps!
- Rear Brake Pads
- aftermarket suspension addon? (on budget)
- Megan LP coilovers spring change
- New coils :)
- Megan LP Coilover Spring Change
- awd wobble option
- Airrex suspesnions digital upgrade for Air Runner Basic Management on LexusIS250
- Megan Front Upper Camber kit question..
- Fit Kit & Shim Kit
- AWD Lowering Issues
- Help me choose Lowering springs
- E-brake Not working as well...
- BC BR damper adjustment and squeak/klunk
- Shock life: mileage vs age
- time to change the caliper color
- Are the stock shocks serviceable?
- F-Sport or Hotchkis Sway Bars for IS350?
- Fortune Auto 510 vs BCR
- Bleeding Brakes With A Mityvac Question
- The final touch
- Performance questions for those who have done 350 brake swap
- brake pad part number question
- Dealer, F sport brake, and modified dust shield
- brake pads
- Is350 awd rotors confirmation!
- quiet coilovers?
- IS 250 right rear cv boot replacement
- Rubber for the springs
- F sport upgrade front brake issues
- IS250/350 F-Sport front sway with IS-F rear sway, Best Balance?
- Lowered AWD Vibration NOT from the steering wheel
- F-sport big brake kit
- Suspension Change between 06-08 IS and later 2nd Gens?
- stock height help ?
- Springs an shocks
- Do I really need Megan/SPC rear camber arm to run on Air?
- Upgraded base suspension to X/Sport/F-Sport suspension + F-Sport Sways, impressions!
- Bagging AWD.
- Megan Racing LP Coilovers
- IS250 AWD Rear shocks
- after lowering reason for vibration
- is250/is350 awd - road magnet springs
- Coilovers
- What kind of rear axle in the 2IS?
- Does GS450H coilovers fit for IS350RWD?
- Rear Brake Issues
- Where to place rubber silencer?
- Megan Racing LP Vs. Tein CS Coilvers
- BC coilovers MAJOR issues….
- Getting really bad squealing/chirping when stepping on brakes
- Is250 awd 50,000miles + h&r springs ?
- CV Boot woes...
- If you had to choose: slotted vs drilled vs dimpled rotors
- Your thoughts on yonaka vs dgr coilovers
- Factory shock/suspersion replacement question - MY06 IS350
- alignment numbers?
- Springs question
- Where are all the Tokico HP Blue rear shocks?! (06 IS250)
- Callahan Drilled Slotted Sport Brakes? Anyone have them?
- Tires (size/model) for 19x9.5/10.5 +35
- T-demand FUCA... (Rare JDM candy!!!)
- Acceptable Alignment Specs
- IS350 Rear Calipers
- Tire Feathering / Alignment problem
- Awd 07 is250 air ride questions
- Need suggestions on new brakes
- Shock / struts
- Brake/spacer issue!
- Did I do something wrong?? (DIY Goes Wrong)
- What type of Brake to go with??
- parking brake swap
- New Rear Brake Pad Abnormal Wear
- IS250 AWD brake upgrade to IS350 brakes
- Break Dust!
- signs your shocks are wearing out
- Need Help for my new navigation item
- Bought springs, should I be worried about anything else?
- Thermoquiet Front Brake Pads - not so quiet...any suggestions?
- Mileage and wear
- My experience with the High-Friction brake pads
- Lowering and Alignment
- can i clear f sport bbk with 20'?
- Tein CS coilovers and Swift Springs
- Best rotors and pads for low dust?
- F Sport springs question
- F Sport (BLUE) front springs with (OEM) F sport rear
- Squeak coming from front driver side
- Squeaking Problem with New Brake Pads and Rotors
- Finally Pics! Lowered [:
- Same spec wheels in different diameters....affects fitment?
- Megan Racing camber kit?
- Road magnet and tire specs
- 2011 IS350 AWD summer wheel recommendation
- swapping coilovers, do i need alignment?
- 2006 lexus is250 spacer question
- Brake rotors (Centric blanks or OEM)?
- What would cause a whizzing sound when braking?
- 3GS coilovers for 2IS
- Tein S. Tech Springs
- Your process for adjusting coilovers?
- Tein S.Techs
- Worn Brakes + Sewell = No down time.
- New shocks needed with springs?
- Stock struts and springs
- Air bag noob question
- Local shops to install coilovers
- Installing road magnet springs
- BC coilover spring rates
- What is the way and sequence of bleeding break
- F sport spring question
- Just Installed Road Magnet Springs on my Breakwater Blue IS AWD PICS
- tein street advance coilovers 08 Is350
- Tein H-Tech - Looking for reviews...
- Sounds like rubber/metal crunch/grind noise on turning
- Need some help with coilover install!
- For sale! Eibach Pro-kit IS -30mm
- Stock Spring with F-sport dampeners
- EBC Pads and Rotors
- Brakes & Rotors (Alignment?)
- Coilover install, strut bolt through LCA seized, stuck, need help!
- Rear Brake Recommendation
- Lowered on Tein Coilovers
- Shocks & Springs - Suggestions
- 2008 IS250 Brakes and Rotors ?
- After lowering with coilovers, weird ugly gap solution?
- Which coilovers should I get?
- i need to buy f-sport rear sway bar end links
- KW v3 installation
- What are some good coilovers?
- Lowering awd is250 problems
- Changing the suspension
- Rear Sway Bar - shape?
- Need help/guidance/options on what to do about problem!
- Road Magnet Springs for IS250/IS350
- f sport springs
- Lexus IS350 2007: Please Help with Lights
- BBK issues (detailed explanation)
- BC Coilovers: What's your settings?
- Tein Street Advance coilovers bouncy after road trip
- 20 wheels/road magnet/road conditions
- Front rotor options
- I may regret installing F Sport Springs and Shocks
- Alignement
- EBC set up on a IS350
- question on tire wear
- Best BBK for the money?
- WTB: OEM Shock and Spring for IS250
- Just Replaced Rear Shocks
- Front Brake Help Needed Quickly
- F Sport sway bar question
- NF210 Tanabe's Help
- 714 tires Doing alignment .
- Anyone?
- F-Sport BBK and Spare Tire
- EIBACH® - Pro-Alignment Kit
- Brake pad change pricing in the tri state
- Suspension/Swaybars for is350
- Air Suspension
- What's the best rotors to get without going the BBK route?
- Best Rotors?
- 2008 IS250 AWD w/ rear f-sport sways, is this the right part?
- Megan Weld Quality Concern
- 2006 IS250 Rear Shock Replacement
- Rear brake pads wont fit! Need help! (pic)
- Looking at options, need suggestions
- brake power loss + peddle feedback isn't normal
- UAS Bags Question
- Changing the Brakes
- 6SICK6:Painting my IS350 Calipers
- pedal to the metal to start braking..
- Squealing brake noise PROBLEM!!HELP!!
- Coilovers - can u adjust height with automatic switch???
- kw, ksport, d2, bc, tein, megan, tanabe, other - which one?
- tanabe, eibach, tein, h&r, f-sport - which one???
- Sway(Roll) Bar vs Strut Bar
- Megan Racing Street LP vs BC Coilovers
- 5 mm. spacer without extended stud bolt?
- H&R spring coming from fsport.. Need your opinion
- anyone have a review on D2 coilovers
- F sport or Megan springs?
- How much do the BC coilover settle down?
- Brake Fluid Speedbleeder (is350)
- IS350 2008 Brake squealing
- BC Coilover Preload Setting
- Spring rates on Megan LP...
- Need expert advice on setup?
- Pedal to the Floor (BRAKES)
- help
- Properly Aligning after Lowering
- Airbag suspension for daily driven IS
- New wheels!?
- suspension revelation
- Finally Installed my H&Rs
- Okay i know how forums are and threads being beaten up but!
- IS350 caliper upgrade! Need help!
- Sway and Springs or Coils?
- Aftermarket Tire Fit... Help!!
- IS250 front brake clicking!?!
- Megan Front Upper Camber Arms vs SPC ball joint
- Megan front upper control arm
- Spring Rates vs Ride Quality
- Seized Rear Caliper
- Tein Street Advance from Ebay, $940 Fake?
- Car slight hesitation when braking
- A week after installing my H&R's..
- Literally Brand New BCR Coilovers Height Adjusting Collar Stuck
- f sport spring
- What do you think?
- ~1" Drop Please
- Basic DIY H&R Spring install questions: position and bump stops
- Question to f-sport springs/ shock owners
- No camber adjustment??? Help!
- Any body cut eibach prokit to drop the front?
- Camber kit necessary?
- Brake Pad Recommendations?
- Noise when coming to a stop
