Bc coilovers & Swift springs on is 250 awd
I heard good thing with these setup. I know a local guy with an isf with that setup up and love it. As far as vibration that an awd thing. Some people can deal with it others can't. It also depends on how low you go with it. Just make sure the spring load is set and not lose. Something that will cause clunking from moving.
Its not that the BCs cause a vibration but there have been issues in the past with any coilover system or lower springs on the AWD cars (Lexus). Some guys had slight vibrations at idle. Apparently it is something to do with how the factory axles are setup. We do a ton of suspension setups and specifically the BCs and I rarely ever heard anyone get back to me about a vibration on their AWD. If you do end up getting a vibration with whatever kit you do I've heard that you can play with the height and it will get rid of the noise. Let us know if you have any questions or need anymore suggestions.
-Paul @ CMS
-Paul @ CMS
-Paul @ CMS
-Paul @ CMS
jmsharp02
02-14-12 02:19 PM
