Lowering awd is250 problems
Old Jul 31, 2013 | 02:24 PM
Ptown250's Avatar
Ptown250
Unhappy Lowering awd is250 problems
Hey guys so I lowered my is250 awd, just the front so far, both fender to ground is 25". Two questions, is that a safe height to drive so the axles won't get messed up? And also CHECK VSC and CHECK 4WD came on, also my traction control says its off.. Anyone know what to do?!
Old Jul 31, 2013 | 02:27 PM
Ptown250's Avatar
Ptown250
and btw i havn't done alignment or anything yet if that could be the problem, but i dont see how that should be the issue.
Old Aug 1, 2013 | 03:26 PM
knguyenk's Avatar
knguyenk
When you do any suspension work, always perform an alignment. It will help your tire wear in the long run (unless you have qualms in spending money on tires).
Yes, a search of the forums here will show that a lot of AWD users run this setup and either have the CV boot and axle leak or not (it's a hit or miss). Common issue with lowering our AWD platforms is the vibration associating with lowering (it's just as talked about as the axles and CV boots).
The CHECK VSC, CHECK 4WD, and traction control can be something with the AFS (if you have factory HIDs, where the lowbeams swivel left or right when you're making a turn/corner at a certain speed) when you lowered the car.
Old Aug 1, 2013 | 07:45 PM
droolerk9's Avatar
droolerk9
Default Suspension warning lights
1) Could be your wheel speed sensor, but I recon that the ABS light would be on too.
2) Possible that your system is faulting because the car is not "level" any longer since you've only lowered the front of the vehicle.
Find out what codes your car is throwing via your OBDII port, and go from there.
Old Aug 2, 2013 | 07:52 AM
sm1ke's Avatar
sm1ke
I would lower the front and rear to even height, and make sure any sensors you unplugged are plugged back in (if you had to unplug any, I had a shop do mine so I'm not sure).
Old Aug 2, 2013 | 08:05 AM
zen's Avatar
zen
I like the painted wheel, matches with the exterior color. make sure all the sensors are plugged in, not sure the reason to lowered awd cars. awd made a little taller from the factory is to prevent "buttom out" if it's lowered, it's has no point to be awd.
Old Aug 2, 2013 | 08:44 AM
sm1ke's Avatar
sm1ke
I can't believe I have to explain this.. AWD gives you "easier" traction in unfavourable conditions like rain, snow, or ice. The system works at lowered heights too
Old Aug 6, 2013 | 08:15 PM
blackgpgt's Avatar
blackgpgt
those lights usually only turn on if you've changed the rolling diameter as in running different tire sizes front to rear or if you have a staggered setup or are running spacers...Never heard of those lights just coming on from lowering...the wheels look good though...did you plasti dip them?
A/C
Mar 21, 2017 03:46 PM
mrrhr4
Feb 20, 2016 12:40 AM
RU514
Suspension and Brakes
Mar 9, 2010 01:26 AM
Sarorn
Nov 29, 2006 06:51 PM
