- 2002 Knocking under light load
- Figured I'd introduce myself
- Need some hose location help
- Buzzing noise under glovebox when air is on?
- Evap canister and CELs
- Changing display screen from MPH to MPG question
- Have you ever been off road?
- VSC and Check Engine Light
- Driver Auto Windows up/down & door lock problem
- Right hand drive front seat for rx300 2002
- Sun visor removal?
- Replacement rear motor 99 AWD
- DIY Exhaust System Replacement, Please!
- Can I save my transmission?
- Denso a/f sensor on header in front of rad
- key problem
- 99 RX300 rear window install
- Help me Remove RUST!
- 1999 RX 300 Needs Tires....help
- A sad day..
- painted the lower half of my rx
- Rear Struts
- '99 RX 300 Limited Slip Diff? How do I tell?
- Help Burning oil
- bajabill
- Mileage readout in console stuck
- Led turn signal mirror cover
- 2002 RX300 Keeps Shutting Off at start up and Draining Battery!! Please HELP!
- Roof rack part needed!
- 3MZ-FE swap in a RX300 - How Practical?
- RX300 2001 inside driver mirror directions not working
- Led upgrades to interior blue light and lighted door sills
- Smoke from glovebox of my 99 RX300?
- Lexmex...
- Dome Light and Middle Console Out! HELP!
- A/F Sensor - Is this right??
- WTF 15 codes???
- My Transmission Problem, help!
- gas leak from top of tank/fill neck
- Looking for a 2000 RX 300 Key Deal (Master Remote x2)
- 2003 RX 300 Exhaust Leak
- 2003 RX 300 Fuel Smell
- Just bought a 99 rx300
- A exhaust or warm oil smell when standing still
- A real head-scratcher: P0170, P0300, P0301, P0303, P0305
- 99 RX300 Issues
- Sunroof Hail Damage
- What does "O/D OFF" light mean
- Brake Light Comes on at idle
- debating whether to replace OEM brake rotors
- ticking noise
- CEL P0500 and ABS codes!
- DVD Headrest Wiring HELP
- My RX300 won't arm
- Tachometer Jumping & Check Engine light on!!
- @#^&*@ bulbs
- rx300 died while stopped-but restarted immediately
- Can you fit, A Baby, two Adults and three Dogs on a RX300..??
- how many total years of warranty for the Engine?
- 2003 "sport" model?
- After Market Knock Sensor Reviews
- No light in headlight, turn signal and cruse control switches
- P0305... not a normal coil pack...
- fuel injection!
- Help?
- Fredrico55
- Duplicate or Laser Cut Key
- Is it all downhill from here?
- drivers side low beam off when fog lights off
- Ignition Coil
- High Idle (Help)
- hard shifting with delay and hesitation
- What did you do to your RX300 today?
- "liquid" in the throttle body
- Not driving for long periods of time?
- Transfer case drain plug
- Is any AC maintenance needed?
- Philip HIR 9012 bulb
- Jerk, when transmission shift from gear 2 to gear 3
- sensitive driver side window switch
- Electrical issues
- diy rear valve cover gasket
- Change engine oil or not. 6 months passed, but only 2500 miles on synthetic oil
- MPH and RPM question
- yaw rate sensor
- Installing a Parrot Bluetooth kit on 1999 rx300
- Rx300 not running so well
- my rx300 is running rough p0171 need help
- Engine number on 2001 RX300
- New backup camera monitor VM1
- I See Lights!!
- Mobil 1 Synthetic ATF, is it better?
- Grinding Noise at Low Speed
- Intermittent Check Engine Light
- Fuel Injector cleaning?
- Rx300 transmission slip, after engine rebuilt
- Loud Noise Start Up, Airy accelerating, Leak
- P0125, P1150, and P1155
- 2000 rx 300 died
- How can I remove my tire, without lug key?
- This rims going to fit?
- Air conditioning blowing hot, hot, and hotter .... help
- Which wear out first - front or rear struts?
- Coach Edition Touch-Up Paint
- Front end creaking noise left turn
- Rx300 with Bluetooth phonecalls
- Think'in Buy, transmission has me think'in pass
- Help! Electrical problem?
- PCV valve is wet with oil
- Guy advertising lock actuator repair in DC
- How in the world did the car start?
- 2000 RX300 Driver's window sticks, mind of its own
- 99 rx300 cold shifting problem
- Toyota ATF is better than BP, Shell or Valvoline ?
- Drivers Side Window
- Need help 99 rx300 awd check engine light on codes po300,po301,po325,po330
- Interior lights won't come on - 2002 RX300
- Looking for Roof Rack End Cap (Cover).
- Car Vibration and Check Engine
- 2000 RX300 aftermarket halo headlights
- Just put a nice one in the RX
- 2002 RX300 - is the transponder part of the keyless entry remote?
- 1999 RX300 Automatic Headlights
- wiper rubber refill for rx 2001
- Keyless remote shells cracked...Help
- Michelin LTX M/S vs M/S2
- Can part 35330-21011 (Trans Strainer) be used on 2001 RX300.
- 2001 abs keeps coming on
- Cold start - whining noise
- 2000 model RX300 PDF service manual links
- 2002 AWD - Problems
- high pressure power steering hose
- Harmonic vibration
- need advice - noise/squeak, front driver-side
- Looking at a 1999 RX 300
- Buying another used RX300 - your choice from these options?
- Accelerate slowly and smoothly will help to prevent damaging transmission?
- Advice Needed: Code P0136 and Dubious Repair Shop
- Do I need struts or mounts?
- 1999 RX300 Code P1354
- 2000 model RX300
- YAY For CEL's and o2's
- Update
- Good Autel Scanner deal on Amazon
- Rx300 Transmission Interchange question
- Does transmission fluid and transfer case fluid share the same reservior?
- RX300 Electrical Issues
- Fixing Dash Lights
- How to manually check the transmission status?
- Trailer Wiring
- Today upgraded front door speakers and sound quality 70% better
- Need Help on a 2001 Rx300
- Squealing and AC problems. Plz help.
- Homelink-NOT a programming question
- Where to buy drive shaft parts?
- P1130 code on reader
- need of advice
- Need a new master cylinder for an 2002 RX 300, how much?
- Audio Woes
- Buying 01/02 rx..what to look for
- Nav unit on fleabay looks like a good deal
- Intake mod/home made
- Cruise control troubles
- codes codes and more codes: Need Help
- Tranny not shifting at high speeds after warming up
- Cold Air Intake
- Deceleration sensor
- Loud Air pump noise from center console
- Looking for a new motor.
- Code Help?
- hi pressure power steering hose
- The best brand name of Engine Oil for RX300
- Wife reports: "growling noise while driving"
- 1999 with a P1760
- Marvel Mystery Oil or Auto-RX for Rear Main Seal Leak?
- Whistling noise from the rear
- Where is the Transmission Cooler Line?
- Brake Pad, original or after market?
- Turbo threads live again
- 2003 RX300, 3 weeks of trouble, need some help
- HID Lights question
- Denso 234-4215 Oxygen Sensor OR???
- My beautiful '01 is wrecked.
- AWD and Different Tires
- Tail lights out, brake lights work
- Mute connection location for 2000 RX 300
- Interchangeable Parts
- Information Display Replacement Options
- maintenance costs for 2001 RX 300
- Do AWD's have the power/snow switch?
- Got an RX300 today
- Engine Oil Leakage, help please.
- Replace seat belts
- Rx300Sel Air Suspension. Diag Codes: C1713, C1735, C1739
- Is there a way of reseting all the radio stations on 99 rx300??
- '01 RX300 Exhaust Leak [pic]
- my new 400h
- Is RX300 more durable than Highlander?
- How do you determine if a key is a "Master"?
- Need an extra key, where do I go besides Lexus
- Replace power steering pump or not?
- 2002 rx300 question
- Rear seat cable?
- Remanufactured Tranny 1 day old, now A/F Sensor??
- Will these rims/tires fit???
- RX 300 brake pedal goes to floor
- Need clarification with the Oxygen Sensor
- '02 145K Transmision Fried
- Trans.
- First Time Posting
- Gas Cap & Gas Cap Gasket
- Lexus RX300 Recalls from 2008-2009
- Mfg Service Bulletin- Electrical Sys Software
- RX 2002 nav system
- need tires - thoughts?
- Transfer Case Leaking, is that serious?
- Locked Keys In Car
- Loud Noise When Excellerating over 60
- 2001 RX300 Transmission Fluid
- P0500
- Magnaflow has arrived...
- Strange noise from my car when I start my car for the first time of the day
- help !
- 7 MIL code - able to fix it
- Upgrade rear door stock speakers
- New RX Owner Checking In
- Red "BRAKE" Warning Indicator and Chime
- Seatbelt warning
- RX300 rear passenger window switch
- Rear rotors grinding, needs any help!!!
- Exhaust Center Pipe Leak
- New toy! Weapon R Secret Ram...
- Lexus brand or Aftermarket Air Filters
- Correct fuse for headlights on a 99?
- new brake pads and rotor & lower control arm
- A very Unscientific RX tranny Study
- Rim for RX300 year 2000
- Check Engine Light P1131
- Creeky noise coming from wheel well when i turn
- radio buffs only
- Upgraded Headlights!
- Help Please
- Looking for oem floor mats...
- Kind of a pleasant experience at Sewell Dallas today...
- My front and rear wipers and working at the same time!!! lol
- new to lexus but have couple issues!
- Help!! im looking for a reflector
- factory amp 2002 rx300
- Finally found a cheap silver-sport grille
- New owner!
