Loud Noise Start Up, Airy accelerating, Leak
Old 04-11-11, 09:20 AM
kidlex93
kidlex93's Avatar
Default Loud Noise Start Up, Airy accelerating, Leak
I have a 99 rx300 with about 161,100 miles on it. Towards the end of winter my car started making weird sounds. As soon as I turn it on it sounds like a monster. I can hear it from in my room and i park it outside, not in the garage. Also whenever i accelerate it sounds really "airy" and abnormally loud. My friend who has a greater knowledge of cars said that it was probably the exhaust manifold. He told me to check under the car for a leak as soon as I started and of course theres a leak coming from under the car. I'll try taking a picture today before I head out to show where it is.
Can any of you guys help me out and give me some idea's on whats wrong. I'm taking it to my mechanic this friday/saturday and want to get a general idea of whats wrong before. Many thanks in advance
Old 04-11-11, 11:37 AM
salimshah
salimshah's Avatar
There is an ongoing discussion on exhaust leak. It could be he flex joint, hole in the piping and even a in the manifold.
You can do search.
https://www.clublexus.com/forums/rx-...old-crack.html
You can visit a muffler shop and they can suggest alternatives.
Dealer solution will be to replace the bad part (instead of a patch-up)
Salim
Old 04-11-11, 01:14 PM
kidlex93
kidlex93's Avatar
http://www.youtube.com/watch?v=zGy92S-naz4
Old 04-12-11, 05:29 AM
Lexmex
Super Moderator
Lexmex's Avatar
That area sounds like an exhaust gasket going bad as below. There are two 14mm bolts that hold those joints on. I don't remember the gaskets being that expensive and it is likely something even an exhaust shop has or you could pick up at the dealer. It might be possible just to tighten up the two bolts and see if that helps cure the problem temporarily, but eventually the gaskets go.
Attached Thumbnails Loud Noise Start Up, Airy accelerating, Leak-rottedburned.jpg
Old 04-17-11, 10:06 AM
chenxingha
chenxingha's Avatar
In my similar experience, the two "weakest links" in the exhaust system when loud airy noise are heard are: (1) the flex pipe, for which you can get an OEM direct fit replacement on rockauto.com (walker # 53421) for around $70 including two gaskets; I just did it about four months ago. (2) the joint between the y-pipe and the front of the main cat. converter, where two sping-plus-bolt set connect the back-end of the pipe with the main converter; because the joint's forced connection by springs and is therefore "movable", the seal could be cracked or broken and leave a big crack inside the fitting; you can find the seal ring and spring-bolt set on rockauto.com as well; I replaced the seal ring and spring-bolt set not long ago and eliminated the airy noise.
I learned the trick to identify the exhaust leak on this forum: at the night drive the car to hot and park it in a garage; then in the next morning, immediately after starting the car, look at the two joints for steammy air and/or water drips; if they are observed, you know where the leaks are. In my case, white steammy air coming out from the back end of the flex pipe and water drips from the spring-bolt/y-pipe/converter joint.
Good luck.
Old 04-17-11, 12:37 PM
kidlex93
kidlex93's Avatar
i went to my mechanic and he said it was the exhaust gasket. it looked really bad, he had to blow torch the screws off and chip off the old gasket with a flathead and hammer. he replaced it and and oil changed for $100. Thanks everyone
Old 04-17-11, 02:10 PM
chenxingha
chenxingha's Avatar
Is the exhaust leak at the y-pipe and main cat. converter joint? If so, check the repair work again: it must use the proper spring-bolt combination to tightern the pipe end with the main cat. converter (to allow some movement) with the proper bowl like very think seal-ring gasket to have a very tightly fit. Installed unproperly, such as not using OEM direct-fit mounting parts, you may end up with ratlling noises by exhaust parts at startup and vehicle viabration noises later on.
LesisBest
05-30-12 04:50 AM
Banshee365
05-09-10 06:55 PM
Rock-a-Lex
Performance
10-24-07 08:01 AM
BadViper22
23
08-12-07 12:29 PM
tbridgers
Maintenance
03-16-06 08:30 AM
Quick Reply: Loud Noise Start Up, Airy accelerating, Leak
