7 MIL code - able to fix it
Old Feb 18, 2011 | 06:53 PM
RayN's Avatar
RayN
Default 7 MIL code - able to fix it
I have multiple MIL codes on my 143K 99 RX300 and I was able to fix the issues.
1. P0300, P0303, P0305, P0171, P0301, P0136. Off course misfire is noticeable. Solution: I cleaned the MAF and throttle body. Replace the 3 ignition coil by the firewall. Reset MIL.
2. MIL comes back with P0300, P0305, P0171. Solution: Added fuel injection cleaner. Reset MIL.
3. MIL comes back with P0171, P1133. Solution: Replace MAF sensor. Reset MIL.
4. MIL comes back with P0171. Solution: Replace O2 sensor by the firewall. Reset MIL. I use a 22mm box-open wrench and use a box-open wrench as a extension, really easy to loosen the O2 sensor.
No more MIL code and car running better. I think if you have a misfire you can ruin the O2 sensor/s. Also the second time P0300 and P0305 shows up, I think the ECM didn't learn the ignition coils yet.
Puttster
Feb 3, 2016 07:32 AM
zrob
Feb 10, 2014 08:07 PM
richonline
Nov 11, 2010 05:11 PM
lockie
Nov 23, 2007 06:31 AM
palaka
Sep 3, 2007 06:58 PM
