- Check engine light is on 2007 400h
- Annoying Squeak
- Aftermarket backup camera etc
- AC light flashing. Hot air, then fluid leaking
- Replacement Radiator for Inverter Cooling - Hybrid
- Windows, Roof Light Reset? How?
- Check System = tire pressure
- Transmission, transfer case and differential Drain and Fill PN's (Good to have)
- "Auto" on Light Switch not Working?
- Short squeak on hot weather start
- Dome Light Not Coming on
- Auxiliary cable for iPhone in 2007?
- Vacuum Hose Routing Diagram for 2007 RX 350
- Woodpecker noise driver side 2007 RX350
- Maintenance light on
- 2007 Rear Power Door Auto Closes. Impossible to stop by holding.
- Tires
- Change Transmission Fluid with 175K Miles?
- Transmission
- 05 rx330, CE light, VSC light and trac off light WITH acceleration cut out
- Suspension not Raising
- Brand new battery- dead
- 08 RX400h Daylight Running Light Issue
- Air conditioner
- 400h no power steering
- Transfer case
- Drone sound from rear
- Ignition coils replacement
- RX350 died on the freeway
- Trying to change wheel bearing and a steering knuckle but ran into this problem.
- 235/60/18
- 2007 RX400H What to look for
- Sunroof will not open
- 2006 RX350 Alternator Part Numbers
- Small differential leak when driving after pinion seal replacement
- Black rod sticking out front seat right side rx 300 2005
- Tool for tightening clamp for steering boot?
- RX350 Intermittent starting issue
- Best way to add a bike rack
- Help with passengers side LCA removal
- 2006 Lexus RX 330 made in Canada’s with tow package
- Running a 60 series tire ???
- ntermittent Clicking Noise when driving - 2007 RX400h
- Cabin windows condensation
- Barter my 06 dodge ram 2wd to 05 lexus rx330 awd Craigslist
- A/C relay RX330 2006 Where is it?
- timing belt replacement
- 2008 RX 350 Stereo Replacement Chronicle
- Engine trembling when it reaches 65km/h (40mph)
- Timing Belt Replacement on a 14 yr old low milage RX 330?
- Engine Tapping Noise - 2007 RX 350
- ECU pinout for 2007 RX350
- 2007 no heat when turn on heater. It was over heated when i drive .
- Swap Ls engine.
- 2008 RX 350 Driver side Air Mix Servo
- Remove old cracked chip film
- Seats adjustment stopped working after buttons exchange attempt
- Tire pressure warning light
- Linear Offset Calibration - Brake Actuator Replaced - Bleeding RX 400h ('07)
- P0430 CEL Code
- Problem with putting back steering column after removal.
- Buying advice. 2 serious concerns..RX330 and RX400H
- Call me crazy.... Low Profile Tires on an RX?
- repainting door moulding
- Changing carpet
- Prerunner front bumper/skid plate
- Changed my Power Steering Rack...Now VSC Off and Traction Light Illuminated
- Japan-built RX versus USA-built RX: Difference in Power Steering Pumps
- Windshield washer out of service.
- 2009 RX-350 AWD Shocks and Struts
- Tire recommendations?
- Won't start
- Block heater
- No DTC codes but engine will not start
- Changed transmission fluid and filter...and +1 for MaxLife!
- Check Engine, VSC, Trac Off - Code P0705
- Strange leak and don't know where's the source
- Radio gremlins
- 2007 Lexus RX350 - Navigation dsyfunction
- Horn Beeping While Car is Off
- TPMS light will not go out. Uncle!
- Parasitic Drain
- Car speaker Size's and recommended brand for speakers
- Brake bleeder screw thread size?
- I won the Crash Competition!
- 2009 RX350 left front cv boot
- Odd Sirius Antenna Connector
- 2007 RX 350 Rack and pinion
- 2007 rx 400h just turned 200000 and cel P1420
- Lighter help
- Replace Mark Levinson with Apple Carplay
- Starting Issue
- 265/60R18 snow tires - will these rub?
- 2005 Lexus RX 330 water leak?
- Start-Up Squeaking
- Rust on rear left wheel well area
- Luggage Cross Bars
- Did I buy the right part?
- Stupid mistake on my 2006 rx400h. I put a new 12v battery in and hooked it up reverse
- Tail light for the driver's side
- shocks riding low
- Noise when brake pedal is depressed
- Head gasket job on a rx350
- 2004 RX330 Liftgate Won’t Open
- RX330 Liftgate Won’t Open
- Cigarette lighter swap
- 2005 RX330 won't shift out of park
- Check Engine P0037
- Diagnosing an Overheating Issue as Blown Gasket, Air in Coolant System, or???
- Items fall behind steering Wheel, help!
- Climate coltrol acting odd, this normal?
- where is mg clt relay
- Cost to paint
- Very Poor Radio Reception
- Can’t reset check engine light
- Key Fob Shell Replacement
- Getting Rid of Mold under Carpets
- key fob/
- Engine Coolant Flush on Hybrid
- 2004 RX 330 No ignition but hear fuel pump running?
- ignition coil question
- Replacing head gasket
- transfer case and differential drain washers
- Lumbar support motor
- Parasitic draw from power windows
- Do All RX's Have the Oil Cooler Lines?
- Thermostat/water pump
- 2004 Rx 330 Struts and radio replacement!
- 2004 - worth buying?
- Worth Repairing
- Why might DRL just not work?
- 05 RX330 Can't connect to emissions machine
- AFS off light on, 2005 RX 330
- 2004 RX330, knock sensor, thermostat, spark plugs replacement
- Tracking Headlights
- My “New” Used Car
- Liscense plate light replacement
- Replacing 2005 RX-330 Air Filter Housing or Case
- How to Tap Into Reverse Lamp Wire in the Cabin?
- Cost of ball joints and shocks on 2004 rx 330
- Bizarre Radio/Nav/Lights issue
- Camera transfer
- Cracked Dash
- Power Steering Rack replacement?
- RX won’t turn over but all lights and ACC’s come on
- 2007 Lexus RX350 Vibration
- top power port doesn’t work
- autozone tools couldn’t find my check engine code
- Led interior lights
- Bought a 2005 RX 330
- Rear hub bolt size?
- replace license plate lights
- 2005 RX330 Rack and Pinion Replacement
- how many speakers in the car?
- Doh! Lost screw!
- 2004 rx 330
- 2008 RX350 Transder case fluid change
- Peeling behind side mirrors (pictures)
- led bulb for daytime running lights
- Harsh Downshift to 1st
- 08 Passenger window problem
- Rx400h not starting after airbags deployed
- Possible to replace HID headlights with Non HID?
- FIXER bumper conversion
- Driver seat replacement
- Remove rear left door
- ABS warranty 10yrs questions
- Possible new 2nd gen owner!
- 2004 Lexus RX330 Compression Test DIY
- Parts in Japan: RX 350 2007
- 2005 RX330 Roof Rack Protector
- 2007 rx 400h tpms
- Anyone with 2010+ Wheels
- Rx 400h - music via Bluetooth from iPhone?
- Painted my grille
- Locating the air conditioner drain hose from above and rear sunroof drains
- Lexus RX330 New radio & backup camera with amp delete,
- RX350 - Harrier Zagato
- RX350 Dashboard Replacement Compatibility
- CEL codes for EVAP control & Warm Up Catalyst Efficiency P0441 & P0421
- Nav Delete Nav to non-nav
- Rear door stuck open. Help!
- Lexus rx400h airbag trouble code suggestion
- 13 error codes in a row
- Aftermarket Radio Causes Navigation DVD Issue
- What color wire is daytime running lights?
- Tire pressure sensor battery change
- No power
- Coil packs
- awd rx300 rear wheel bearing torque
- Interface with Factory screen
- Timing Belt advice
- 2007 RX350 front seat - how to remove the plastic back panel
- Made a 12V outlet for the rear passengers
- Radio Issues with 2009 RX350
- Rough Idling
- Has anyone ever replaced the faded/oxidaized rear hatch trim chrome piece ?
- wiper part
- 2005 RX330 Hard to steer
- RX330 Help with DTC PO500
- Help Needed - Replaced Odometer - Mileage questions
- Why does my driver seat belt feels wet every morning?
- Lost a couple nuts ...in the rear strut area.
- Sad goodbyes!
- Greasing out U joints...is this grease ok?
- Que about dimmed mirrors???
- US to UK Headlights
- a/c making a humming sound when running
- Engine/Radiator Fan Loud when Driving
- Box under front passenger side rx330 2005
- Transfer case
- High Mileage 5W-30 oil
- What to do.
- Strange humming from my Lexus - Is it transmission or something else...
- Almost overheating? Thermostat?
- Pinout Diagram for the Radio RX330? Installing a new aftermarket radio
- FOB key programming for RX 400h 2006
- Short vs. Long Key shaft
- Headlight cover Replacement
- first post! just got rx350!! some questions..
- Rx400h European navigation DVD reader part number
- Rear Spoiler 3rd Brake Light assembly ?
- Engine splash shield connectors?
- What is black box under the drivers seat
- Problem with new navigation DVD
- Rx400h ECU reset?
- Pulling to the right
- Tire Time
- Front passenger side tire shakes on/off
- Transmission fluid level check corect procedure
- trunk toolbox
- Pulsing at high speeds
- Rear Quick Strut
- Q: Hardwire radar detector and tap into rearview mirror power
- 2009 RX 350 shock/strut replacent
- Temperature control button broken
- Major door lock problem
- When in park the reverse lights and back up camera come on
- Non AFS headlights in AFS enabled RX330
- rx330 whine during acceleration
- Dome lights and Moonroof do not work at all
- battery light doesnt go on
- P0 441 p0455
- Where can I purchase OEM radio with satellite band for 2009 RX350
- Rx330 No interior lights. Sun roof has no power.
- Can You Help Me Identify This Part?
- Replacing the rear spoiler
- How to use Voice recognition for 2009 RX350
- Lost radio stations
