2008 RX 350 Driver side Air Mix Servo
The Driver side is not blowing "fully" cold. (Passenger side blows fine)
I gather its the Air Mix servo.
No codes.
Before I remove and clean it out I just need confirmation from one of you if this (see pic) is partially or the fully open (cold) position.
This is where it currently sits in the coldest temp setting.
Thanks in Advance.
Driver Side Air Mix Servo
That is the fully open position.
It appears all servos are working correctly.
Any suggestions as to why this issue exists would be appreciated.
Blower works fine, Heat is good.
Passenger temp responds perfectly. (Hot and cold)
Just the drivers side is not blowing cold.
Thanks in advance (again)!
I was hunting around and found a thread where a poster stated that their Avalon did something similar.
I'm gonna try and get it evac'd and recharged this week. Hopefully no leaks. (I don't wanna try and do it myself and blow a seal
)*Crosses fingers*
Thanks for the reply!
