- question about different options (GS350 awd)
- How to remove fenders?
- Brake sensitivity at the pedal
- who has remote start?
- 2006 GS 300 vs 2008 ES 350
- the keyfob is annoying me a lot....
- Updating navigation system
- Baby Bear Gangster VIP....(^_^)
- New to CL and have a few questions
- bonnet bra, to be or not to be gs 300
- Where do you hook tow straps?
- 2007 Lexus GS 350 Side View Mirror
- PSY- Gangnam Style
- Rear sunshade not fully extending
- 3rd gen (F)18x9.5 +22 (R)18x10.5 +22
- installed new ksport bbk
- Who's got the most miles on odometer?
- Audio problem
- Need some help on aftermarket carpet and padding
- Oil change issue
- Torque Specs - Front/Rear Caliper & Caliper Brackets
- New member
- hid bulb
- Need some suggestions or help on how i could pin point this noise problem.
- Mystery Button on the Climate Screen
- New here with pics and quick question.
- Bad battery?
- Automatic Headlights won't shut off
- DIY Hvac evap drain blockage(Leaking water in car)
- mr
- Auto Wipers
- Hello
- brake service etc. cost from local shop?
- Hello all - back again to Lexus
- gs430
- Lexus Educational Center
- 2006 GS 300 Exhaust Diameter
- 98 ls400 Front brakes on 06 GS300???
- Picked up a 06 Glacier Frost Mica
- High pitched squeak when driving
- what are a full set of gray front & rear seats worth?
- Perks of new Pilot Super Sports (unusual accident...)
- GS300 2006 - Coolant Flush
- New Owner 2006 GS300
- Help!!!!!!
- Thinking of selling my GS430
- Driver side Dome LED flickering
- 19 Works Varianza
- New guy lookin for my new ride
- Quick Teaser.....
- Higher Mileage Demos – Your inputs please!
- Question.... New bulbs???
- Help: Intermittent Humming Sound
- Anyone have an SK-R Duraflex Body Kit on their GS 350?
- Mini Me...3GS edition
- weird memory seat bug
- 4GS Trunk Chrome Trim on 3GS
- General Question
- '09 GS350 AWD approaching the 100k Service: what is really needed?
- Direct Subwoofer Replacement for ML?
- Pic of the new setup...
- Modified Stock Look
- 2012 Navigation DVD GEN05.12
- Did anybody change the license plate light?
- Need Suggestions on updating my Navi
- AUDIO: "big3upgrade" anyone do it?
- Where is the OBD2 connector in car?
- Looking to buy the SL2Vu
- 2006 GS300 o2 sensors
- Creaking F Sport Front Brakes
- Ac is leaking water on to passenger floor
- Missing Panel Under Car - Help CL
- GS430 Accident/Insur Question FLA
- HID Projector Movement
- Headlight Washer Chrome Bezel
- 2006 GS430 Rattles, Squeaks...Out of Warranty
- Had cam gears replaced per TSIB EG020-07
- About to get a 2006 gs300!!
- Anyone had success in tuning the 3GS?
- sway bar conflict with after market exhaust?
- What oil are you running?
- Replacement of a Single Tire (dealer story)
- worn upholstry on drivers seat
- License Plate Cavity US vs Euro Spec?
- Brake light problems!!!
- Stock exhaust question
- So my GSh is currently 1st at the EagleOneCarShow...
- Q: Supercharger kit
- No nav/ml no DVD?
- Throttle controller question...
- 07 350 transmisson awd
- AM - Sat button on radio
- Afs
- ECT Power button
- Help with wheels pls
- 2008 GS460, advice on wheel selection
- original floor mats?
- what % tint do you have?
- Rear driver side window
- 3GS Drinking Oil
- Completely Disgusted!! Lexus denied a warranty claim!!
- XM or Sirius satellite radio
- 205/50/17 snow tires
- New member
- Fresh paint and rolled fenders
- Side Mirrors making noise?
- FINALLY....Recall on GS300 engine misfire
- Upgrade of Audio from ML worth the $?
- Shark Fin antenna / 2008 GS / no nav
- Does Seafoam really work?
- Vaistech system ? / 2008 GS 350
- Rear Shade Mod..
- LS460 front caliper vs IS350 front caliper
- Is this a sign of TPMS failure?
- Replacing headlight
- can anyone help with Chinese..
- Just picked up my gs300!
- E brake!
- Momma Got a New Lexus
- Who has an Aftermarket exhaust?
- Cheap D4S?????
- Side view Mirrors Will not Return to original position
- embarrassing
- 2006 gs300 bad motors?
- When should I replace my water pump on my 2006 GS300?
- Front end noise ? Tire ?
- Need help with new wheels
- LCPO : '06 GS300 or '07 GS350
- Lexus body painting specs (repairs, not factory)
- SICK BBK Option!!!
- Wheel damage repair
- VSXX wheel fitment help
- no FS
- Oh No! Rust!
- how many of you doing oil change by yourself?
- My GS Pics
- new member
- Painted my emblems
- Audio wiring Help !!!
- new member from SC, 07 gs350
- Rwd vs Awd
- 2008 GS 350 AWD Lexus
- My 3GS on some new Linea Corse shoes. :)
- MY low life....
- Aftermarket IS350 BBK on GS350?
- Do I really need to replace the shock mount?
- GS430 Timing Belt and Water Pump Install >>VIDEO<<
- Samsung Galaxy S III to my MultiMediaLinQ?
- Did the Lexus 4-Door RWD/AWD Coupe Die with the 3GS?
- Any Ideas on how to Fix???
- My warranty is almost up... need your help!
- What front bumper is this?
- New Shoes - Pics
- gs350 video shoot kizzy
- GS300 AWD Tire Question
- Fix external door strip?
- JDM Visor Group Buy from Nigel
- Picked up new daily driver 06 GS430
- is250/350 brake calipers
- Connected battery backwards on GS430...
- 2 weeks after ownership had to get wheels
- Red / black gs!
- Use a 2007 GS350 Key of 2011 GS350
- Waiting for iphone 5?
- Not sure about 06 GS AWD oil drain plug
- Mid Pipe Noise Problem AWD 300
- 20" v 22" on 06 GS300 RWD
- odd remote key/locking issue
- 06 gs 300, vip rear trays
- Seattle/Bellevue Spring Install
- Most horsepower - GS430 vs GS350?
- Buying a 2006 GS300
- door panel ... gs430 2006
- ABS, VSC, CHECK SYSTEM, TRACTION LIGHT - Soft brake pedal
- Lexus chrome door handle trim
- tire size for vossen 20
- Trouble transferring DroidX contacts to 2011 GS350
- Moonroof Up/Down and Open/Close performing same action
- Fairly new TSB for rear headrest wrinkled
- E-Brake doesn't work???
- Replacing brake dust shield?
- Instructions on how to replace headlight bulb
- The infamous problem of the wet rear carpets
- GS Brake Squeak TSBs
- Vaistech Sl2vi Questions
- people with aftermarket audio systems
- Weird noise during acceleration
- Making my GS look tiny.....
- Best iPhone Integration
- adding AUX port
- Will ISF Headers Fit?
- 5x112 to 5x114.3
- Battery Issues
- HELP: OEM CD player not working in GS350
- Finally Shipping My GS!
- what could be wrong? d4s or ballast?
- Anyone in or close to Montebello, California?
- FS goes in classifieds not here
- gojeezy123's 06 GS300
- Trying to Purchase a used GS460
- Passenger Side Airbag problem
- Headlight issues!!!!! Any Idea????
- Please help! Check system warning light?!?!
- running light insert?
- vossen wheels
- OhnO's GS350 AWD!!
- Advice needed regarding engine start noise...
- How much I should pay for this GS350?
- prussian blue bodykit?
- Poor MPG
- IS-F wheels & 3GS offset
- oil filter part number
- '07 GS450h | Wald | iForged
- question about AFS
- Wheel Guru's
- Just picked up an 06 GS430
- 2007 32k miles, what price would sell quickly?
- Zone Wheels - Where to buy and questions
- Looking for an ipod integration solution on 06 without ML/NAV
- front seats swap??
- What would you guys pay for an 06 GS430 with 35k miles
- vossen 10.5 rear wheels and neg camber wearing tires
- Looking for the part number
- Paint Question
- Am i looking for trouble to get this wheel fit ?
- Painted my stock GS300 calipers today & added decals....( pics)
- 20.8.5, +35 offset - What Size Spacer?
- Wheel circumference difference threshold for AWD
- new GS owner
- Questions about Lexus RX
- What Exactly is the "S Mode"
- brake pedal so stiff, difficult to start
- GS 350 MY 2010 Reverse Back-up Camera
- GS430 dyno result 153KW at the wheels
- OBD2 Location
- Pinot Grigio
- 2006 Lexus GS 300 P2757
- LFA Wheels
- Some Pics taken recently of my car!
- Just checking...
- WTB New Nav Disc
- Nav dvd 2006 gs430
- Navi not able to search for # on address
- replacement rotors
- 5x120 fits gs350?
- wheel fitment
- grinding sound at idle/front end
- speaker configurations?
- 2011 GS350 Wheels ?
