Connected battery backwards on GS430...
Old Sep 2, 2012 | 01:53 PM
JeffLexie's Avatar
JeffLexie
Default Connected battery backwards on GS430...
I pulled a major bonehead move trying to do something in a hurry and connected a brand new battery up backwards on my 2006 GS430. My car is virtually dead now. The headlights, hazard lights, horn, and vanity mirror lights all work. I think that is about it. Nothing comes on in the dash, doesn't try to start, basically nothing. I've checked some of the fuses looking at the owners manual. I keep reading about a main fuse but don't know where that is located to check.
Does anyone have any ideas they could possibly help with for me to check?
Thanks in advance.
Old Sep 2, 2012 | 02:58 PM
dtd80's Avatar
dtd80
Let's hope you just blew the main fuse. I can look in the repair manual but it's for my 460. I think it should be similar as far as fuse location. Brb.
Old Sep 2, 2012 | 03:04 PM
KJSmitty's Avatar
KJSmitty
Now that's a real bummer,
To be frank this could literally be really bad or just several blown fuses, relays, and/or links and possibly the alternator. Did you see or smell any smoke? Did you notice the error before or after you tried to start your GS?
This typically reeked havick on older vehicles yet hopefully something as sophisticated as an 06 has several fuses/relays to prevent serious damage etc. I've seen the aftermath of others at the dealership I worked at but luckily I've never done this myself. Very easy with same size post and side-post batteries etc.
Hopefully you didn't tick off every ECM/computer in the car.
Keep us posted.
Old Sep 2, 2012 | 04:31 PM
passnu2's Avatar
passnu2
I can also gather anything you need to try and help out. Ill post this for now and start to check any/all fuses and relays. Hopefully you blew a main fuse before it did anything else.
Old Sep 2, 2012 | 04:33 PM
passnu2's Avatar
passnu2
I would think with as smart as these cars are that there has to be some sort of fail safe for this reason.
Old Sep 3, 2012 | 10:35 AM
passnu2's Avatar
passnu2
just checking back to see if you figured it out or need more help
Old Sep 4, 2012 | 07:08 AM
worker's Avatar
worker
ouch. the thing with fuse is it regulate current, not direction of flow. diod does the polarity and most cars don't bother to have that. if you can see where to put in the batt you can see the red wire.
check the fuse but i think dealer is your best solution. they have more tools and more 'know how' people and this reverse is a major one.
when i replace my battery, i tell ya i checked this red wire like 10 times. make sure the neg have a wire hook into the body.
Old Sep 4, 2012 | 01:10 PM
Coleycole's Avatar
Coleycole
Ouch!!! Yea I would agree the deaer is ur best bet. Anything else that may have went wrong that you can"t see they should be able to find out. Do it right the first time.
Old Sep 6, 2012 | 05:51 PM
ELITech's Avatar
ELITech
I believe the '06 gs430 has a bus bar with the main fuse built in. I am not 100% sure... however, if you are lucky, only the main fuse blew. If that's the case, and it's in a bus bar, then the bus bar needs to be replaced.
It could be worse... I had a salesperson jump an RX backwards, and also popped the ecu for power steering...
Old Sep 7, 2012 | 06:53 PM
arnieosp's Avatar
arnieosp
This thread is now 5 days old, and not a word from the original poster anymore. Hmmm......
Old Sep 7, 2012 | 11:03 PM
worker's Avatar
worker
he had to cut his internet to save money to fix his car. LOL j/k
it happen all the time, ppl don't report back. me with my over active imagination I always assume the worst, it's more fun. LOL
His lexus die middle of nowhere due to this problem, an alien abducted him cause he was the only 1 in middle of nowhere. than to escape he uses the only skill he know, he reverse polarity of the battery in the alien space ship and blows all their refuse and he died in the crash and therefor cannot report back to here. LOL
Old Jul 2, 2020 | 05:07 AM
meera1974's Avatar
meera1974
Default cross polarity on my 06 GS 430
needed help here please,jump start my lexus and switch cables around,car won't start,so my local mechanic changed all fuse and a few on main bus bar,car starts up and all lights came on on dash,vsc,ect.car has no brakes now and reving very hard.
we also test ecu which is good and still has the same problem
any help
Old Oct 16, 2020 | 03:14 PM
That2JGuy's Avatar
That2JGuy
any help
ever figure this out? having same issue flashing CEL? saying multiple misfires?
Old Oct 16, 2020 | 03:20 PM
meera1974's Avatar
meera1974
Default cross polarity jump start
unfortunately i sold the car,but the new owner told me that he put on a new ECU,main computer and car was perfect.
hope this helps.
anyways i bought the samw exact car with 70k miles in excellent condition
JefDav84
Jun 8, 2020 04:32 PM
ninja23313
Nov 7, 2018 07:52 AM
Pusha100
Nov 20, 2011 08:17 AM
daleer
Mar 19, 2005 02:55 PM
Automan
Sep 16, 2003 11:03 PM
