GS300 2006 - Coolant Flush
Old Sep 30, 2012 | 05:05 PM
newbeemech's Avatar
newbeemech
Talking GS300 2006 - Coolant Flush
I just got my coolant replaced.
Here are the steps
Tools
10mm Socket Wrench
2 Gallons of Toyota Super Long Life Coolant(this is premixed so NO need to dilute)
Ramps
5/15th Inner Diamerter Vinyl Pipe.(I got mine at Lowes)
A bucket to receive the old coolant.
A crawler to get under the car.
A funnel.
Turn on the engine and set the thermometer high
so the heater is on.
Get the front wheels on a pair of ramps.
Turn off the engine.
Wait/Make sure the engine is cool.
You will be getting very close to the catalytic converter/exhaust pipe
so this is critical.
Open the coolant filler cap.
Get under the car.
Find the drain **** on the engine block.
This is on the passenger side under the
manifold, by the third cylinder exhaust(farthest back).
This is a very tight spot.
Reach in over the suspension A-Arm(wishbone).
Plug in the drain pipe.
Dangle the other end into the bucket.
Use a 10mm socket wrench with a short extension, 2 inches or so.
Put your arm into the area from above the suspension A-Arm.
Twist open the **** with one arm
just enough until the coolant starts to drain.
Half a revolution should do, do not remove the nut.
Wait for 10 mins to drain fully.
Tighten the drain nut.
Now get under the radiator.
Find the drain ****.
Open the drain ****.
This is a white plastic butter fly ****.
Turn until the coolant flows.
Wait for 10 mins to fully drain.
Tighten the drain ****.
Get above the engine.
Remove the front most engine cover.
Press the plastic fasteners
in the center and remove the fasteners.
Remove the two 10 mm bolts
holding the coolant reservoir.
Pull out the cap.
Pull out the reservoir.
Drain the existing coolant from the reservoir.
Replace the reservoir.
Replace the resservoir cap and bolts.
Fill from the fill hole using a funnel.
Go slow.
Allow the coolant to fill slowly.
When full, replace the cap.
Fill the reservoir to the full position.
You should have used almost two gallons
with a little bit left.
Check the reservoir for a few times after the
next few drives. Refill the reservoir if necessary.
Dispose the old coolant at a car parts shop.
Have a beer.
Old Sep 30, 2012 | 05:20 PM
newbeemech's Avatar
newbeemech
Here are the pics
Attached Thumbnails GS300 2006 - Coolant Flush-dsc01691.jpg   GS300 2006 - Coolant Flush-dsc01696.jpg   GS300 2006 - Coolant Flush-dsc01699.jpg   GS300 2006 - Coolant Flush-dsc01700.jpg
Old Sep 30, 2012 | 05:22 PM
newbeemech's Avatar
newbeemech
One more pic
Old Sep 30, 2012 | 05:24 PM
newbeemech's Avatar
newbeemech
yet another pic
Old Sep 30, 2012 | 06:49 PM
newbeemech's Avatar
newbeemech
Whereever you see ****, the word was "c o c k"
omg, can I not say "drain c o c k"?
Old Sep 30, 2012 | 07:04 PM
BinaryJay's Avatar
BinaryJay
Just in case there are any 3GS owning toddlers around...
Old Feb 2, 2013 | 08:55 AM
Gennady7's Avatar
Gennady7
Thanks for this! I will try this in a bit. Also, do you know if you can purchase the coolant that you can dilute yourself?
Old Feb 2, 2013 | 09:39 AM
ibidu1's Avatar
ibidu1
LMAO@ Drain the ****! I haven't had my **** drained in awhile, am I doing something wrong? lol
c-low's Avatar
c-low
hahahahahha
Old Feb 2, 2013 | 10:20 AM
ibidu1's Avatar
ibidu1
Yes you can, but make sure to use distilled water. So the internals do not rust out.
Old Feb 2, 2013 | 08:42 PM
GS2100's Avatar
GS2100
Nice write up i need this done as well.
How many miles since it was flushed last and did you see any rust in the antifreeze/coolant.
Old Feb 24, 2013 | 07:37 PM
BAR | F1's Avatar
BAR | F1
There are drains on both sides of the block.
Heater core is closed while the engine is off.
GS300ken
Oct 26, 2021 03:07 PM
cjamie
Feb 22, 2017 05:16 PM
habitat
Maintenance
15
Feb 11, 2007 11:42 PM
DangGS3
Maintenance
Dec 17, 2006 09:53 PM
engin_ear
Maintenance
Apr 23, 2003 03:44 PM
