What Exactly is the "S Mode"
Old 08-16-12, 12:11 PM
fruitycups
fruitycups's Avatar
Default What Exactly is the "S Mode"
Hey guys,
I have an idea what the s mode MIGHT be. Im assuming its a mode where it allows you to dictate which gear you want while still being semi automatic.
My question is, will using s mode maximize fuel economy or is it less efficient than letting the car decide when to switch gears and what not (automatic).
Another reason why I ask is because while the car is quick, it seems as though it lags in the first, second and third gear. If possible i wanted to shift into a higher gear before hitting 3000 on first gear, second and third.
Let me know if any of this makes sense. First time i even had a "faux manual" so im a bit new to all this.
btw, my vehicle is a 08 gs350.
Old 08-16-12, 12:26 PM
IXI187IXI
IXI187IXI's Avatar
it will lag even more if you do that.
Old 08-16-12, 01:49 PM
Whitena
Whitena's Avatar
Throttle control by Apexi, Blitz or Tom's.
Old 08-16-12, 03:00 PM
Boron
Boron's Avatar
S mode is useful going downhill to use engine braking rather than riding the brakes to control speed.
It'll also let you use the full rpm whereas the Sport mode switch will just let the car hang on to gears a bit longer before automatically shifting to the next one, in D mode.
If you're wanting to shift earlier, make sure the switch is set to ECT or jerk your foot off the throttle (if it already is), that'll get it to switch through the gears a bit quicker.
Have a read of your owner manual - info in there which may be useful to absorb.
Old 08-16-12, 10:41 PM
XxGoKoUxX
XxGoKoUxX's Avatar
doesn't using a "downshift" method destroy your trans in the long run? I know my civic's manual trans took a dookie on me (D16 series) when i started playing with downshifting.... Same thing with my miata, had to get a whole new trans for the noise to go away unfortunately.
Old 08-17-12, 04:00 AM
tbilisi79
tbilisi79's Avatar
Sport mode hangs on to gears a bit longer depending ond driving style. Also downshifts happen sooner depending on throttle input. I usually switch to sport when I am alone, because downshifts could be a bit abrupt sometimes and it might look like I am having too much fun to others.
Sport mode is awesome.
Old 08-17-12, 12:29 PM
GS350Lexus
GS350Lexus's Avatar
Everytime I am in power mode, man i waste $20 in gas in an hour.
Old 08-17-12, 06:56 PM
tbilisi79
tbilisi79's Avatar
I think its a bit more....but whos counting?
Old 08-17-12, 10:01 PM
GS350Lexus
GS350Lexus's Avatar
When i said hour i meant 20-30 miles maximum in distance, i love it but man that thing loves gas
343434xx
RX - 3rd Gen (2010-2015)
07-22-22 11:28 PM
Tsmith1982
05-05-14 12:02 PM
dubzino
01-14-13 10:18 PM
rhodesk22
09-11-12 03:03 PM
IS3FIDDY
08-17-06 09:58 AM
Quick Reply: What Exactly is the "S Mode"
