- Please help, tranny swap
- Another "my car is leaking inside?!?!" thread - what next?
- New hid lights?
- P0420 even after changing oxygen sensors?
- afs off light flashing
- 2005 RX330 headlights not working but all others are?
- Thumping coming from rear drivers side at all times
- Wood Steering Wheel
- LCA replacement advice
- F-Sport Pedal Install
- Front Grill Replacement
- Error codes c1568 & c1241
- 2004 Lexus RX330 Driver Door Outside Center Moulding Fasteners Needed???
- Son wrecked the '05 MDX. '04 RX330 as possible replacement? Questions...
- 2009 rx350 awd no reverse HELP PLS!!!
- New Rotor Thickness
- Can no TPMS on spare tire cause errors ?
- 08 rx350 suspension suggestions
- kill switch (any Ideas)
- E-brake/parking brake clunk
- Tilt wheel squeak
- CUT Wire Under Windshield Wiper Cowl? (2008 RX350 Base)
- Highlander Strut Brace Won’t Fit RX
- 2008 RX350: Is it a solid travel vehicle if VVT-i / 9LH hose replacement was done?
- Switch to 235/50/R18 tires
- small windshield chips
- Free shipping at SE Toyota dealers
- 2008 RX400h. OEM Pads and ROTOR Suggestions
- spark plugs & coils replacement on 2007 rx 350, need suggestion
- Dash replacement
- reset fuel consumption without head unit display
- Roof Rack Cross Bars
- ALL of my power windows just quit working.
- Increase fuel consumption on 2007 rx 350 ?
- Great Key Fob Hack Discovered by Accidental Purchase
- More Check Engine and VSC issues. 07 RX350
- TPMS Receiver issue
- Engine temperature sensor RX 330 2008
- new alternator and battery, now rear windows don't work from driver's master switch
- 2008 RX350 starts and dies
- Lexus RX400h (2008) brake backing plate (shield)
- Crankshaft sensor was pulled out from connector now it won't start
- Subframe Bushings
- RX350 P0365 start and die
- 077500-5191 Ambient temp sensor loom routing
- RX400h lock actuator still not working
- RX350 No start
- Anyone running LED headlights in their RXs?
- How I added Bluetooth to my RX400h
- Loose side door mirror
- Looking at a 2007 RX400h
- NEw INterior Carpet 2005 RX330
- P0172 and P0175 Codes
- Painting grill guard?
- Aftermarket Mud Flaps
- Wood trim
- Removal Door Handle Protective Sticker Glue
- Struts, mounts, bearings, OEM vs aftermarket.... sigh
- Struts and strut mounts or just struts?
- Roof Rack Trim Piece
- I'm not kidding....
- Plug and Play headlights
- Timing Belt Kit: TKT-033 vs TKT-026
- Map update
- 05 lexus rx330 tranny issues
- Electric issues in my lexus rx 350
- Battery loss
- Failed Emissions: OBD Connection
- Head gasket
- RX 330 PowerSteering Noise
- RX350 - Cranks, Idles rough, Stalls
- v-belt quality - OEM vs. Bando
- Help!! Noise after changing front control arms
- 2004 RX300 SE-L air suspension to coilover conversion
- OBDII Code Reader For AFS Problems
- Immo Box aka Transponder ECU Known Good Data Signals
- Need Help Identifiying Passenger Footwell Light
- 2009 rx 350 not starting
- Power Steering Pump and TPMS
- Trim Packages
- Mother of ALL Keys, FOB, Immobilizer, Transponder, Security Alarm Thread
- Courtesy lights, radio and lighters on after removing key
- Rear Tail Light Vandalism
- 2005 RX330 Radiator Which One?
- Help! 2007 rx350 car stereo wiring harness
- Programming a Different Style of Key Fob?
- Amplifier Type
- Imobilizer ECU aka "Immo box", all keys lost experiment
- 3rd gen front badge emblem on 2nd gen?
- Part# for tensioner pulley??
- Undercarriage catalytic converter protection mods
- What to replace for EGR valve, 2009 RX350 AWD
- 35% more power, 25% more torque!
- Replacing water pump, serp belt, pulleys??
- Blower motor resistor shorts out
- replaceing front parking brake cable on rhd rx400h
- Smart Wifi Garage Door Opener
- 2008 RX350 Project
- VSC flashing, engine and trac lights on
- How does the heater work
- Noisy Transmission?
- overhead buttons ???
- 2008 Rx 350 Repairs 250K Miles
- Shopping for an RX 350 - 2007 vs 2009?
- Used wrong Lexus key now correct one won't operate ignition
- location of Oil sensor in RX-330
- Engine (I think) ticking sound at low RPM
- 2009 350 2wd std suspension
- Stereo Recommendation 2009 RX350
- Crankshaft Position Sensor Wires Pulled Out
- Clunking in rear of car 2009 rx350
- Rocker Panels vs. Running Boards
- Rx330 3mz engine leakage advise
- Window mechanisms
- Heating Issues - Drivers side vs passengers side
- maintainance light
- switch off stock alarm?
- Strut Boot - Essential?
- Coolant valley plate possibly leaking?
- cargo / tonneau cover headrest clip
- New radiator
- Driver window gets gunked up
- Front speakers compatibility for RX330 2004
- 04 RX330 Power Mirror Problem
- Drivers Side Suspension Rattle
- Oil Cooler Leak (not cooler line!)
- 2004 noise and rattles
- Ignition coil wiring diagram
- GROM Vline Carplay Module Issue
- Hello please help
- Custom rims
- 2008 RX 400H 90k Service
- Cracked Front Lower Control Arm Bushings
- Ideas for center console organizing?
- 0451, EVAP, emissions, check engine, pass smog check
- How do I flush a heater core in a 2008 rx350?
- 07 rx400h locked keys in car
- New member with heat and cool issue
- 2009 rx350 Transponder code B2799
- Noise from the rear seat area
- Rear Carpet Latch
- buy and cut new key for less
- sync key fob to Lexus FREE
- Happy New Year
- Video Screen on Startup
- Keeping my Rx330
- Replace fluids?
- AFS Add On to 2004 RX330
- bearing noise"
- Dash Speakers
- AGM battery?
- Chains
- RX400h Alignment Specs
- RX300 2005 Battery Problems Maybe
- Interior LED Light Upgrade
- 2008 RX350 - What to know?
- Oil Leak Question
- Looking to replace my 2007 RX350 valve cover gasket
- Rear passenger door, window and lock issues
- Rear Hatch Stuck, Dog leash in it.
- Passenger Seat Guides?
- New member with a heat issue
- Backup Camera 2004
- Bad wheel bearings=bad fuel consumption??
- Rear Struts
- Dealership damage & issues... where to go now?
- VSC, ABS, TRAC lights all on after installing snow tires on my 08 RX400h
- This bushing is in the rear passenger side. I think its a control arm. I need a bush'
- NGK Ignition Coil Unboxing, legit from Rock Auto
- 2007 Transmission issue
- 2006 RX 330 with AFS
- Intermittent oil cooler leak (not lines)3.5 V6
- 07 RX350 non ML factory stereo wiring diagram W/O NAV
- RX330 with Nav & Mark Levinson - Amp Bypass or Delete
- suspension bolt & privacy slide question
- 2007 GX470 Error Codes P0430 and P0420
- 05 RX350 U151E trans 3-4 4-3
- It has been fun …
- Where to get service instructions?
- No sound out of the radio...
- Down to my Smart Key Card. What to Do?
- 07 RX350 is there a factory microphone wiring?
- Need 2005 Lexus RX330 Amp Wiring Diagram
- Crankshaft position sensors
- P0354 Ignition coil
- Rear lift latch problem,
- Need help with cd player
- powitanie
- 10mm nut missing on 2007 RX350 engine valve cover?
- Lexus rx330-2004 hand lift back door not operation
- 2004 Lexus RX330 side mirror
- Stiff Steering
- RX350 Complete Suspension Overhaul Guide...ish
- Downshift from 3rd gear to 2nd hard knock
- 2008 400h: high water temp message on dash readout.
- Shifter Console Lights Out
- 2007 RX350 REAR differential fluid fill and drain bolt locations
- How to: Replace rear center seat cover and lever.
- Vacuum lines
- How to connect factory camera to android tesla style radio
- Telescopic steering problem
- Oil pressure sending unit location
- Krylon white primer for Crystal White paint touch up
- Codes C0205, C1223 and C1290 after front bearing replacement
- Strange buzzing sound when I turn on the car
- Still radiator
- Lowering Suspension AGAIN
- Lexus wants $3,000 to stop a lek
- No audio
- locked keys inside
- 2004 rx330 - p0420 + vsc
- Tire size
- Low beams randomly don't turn on, left or right, never both
- New wheels, visors, deflector and plate replacement
- Said goodbye to my RX330 and added a second GX
- Driver Side Mirror Defrost not working. How to troubleshoot?
- Pulled wires from my VVT connector, not sure on order of colors
- Axel Nut Stuck - Help
- Dead battery, physical key not working, how to get intro get into car ?
- 2004 Rx330 air suspension changed
- May be starting a project.
- vibrator?
- Rx400H airplane burring noise while driving
- Power Back Door Doesn’t Close Automatically
- Entire A/C system doesn't work
- 2007 Lexus RX 350 won't start after battery change
- Ugh, screws!
- RX 330 vibration problem
- Replacement driver’s seat leather for $60
- Pearl white Touch up paint does not match
- 2009 RX350 rear struts
- Thermostat...change when broken or as maintenance?
- Preparing my RX 350 for ocean shipping/transport
- Break Fluid: DOT3 or DOT4
- How long have you seen timing belts last?
- vsc and engine check light on
- 08 rx350 hood struts
- Battery issues and Reverse polarity alarm
- Rx330 2004 AWD Parking Break Dash Light Stopped Turning On
- Replacing Nav unit with standard climate/info display
- KYB Strut Install
- Which brand of Coil pack I should buy for 2007 RX 350?
- To slant or not to slant
- 2007 RX350 lumbar plastic gear sets
- Performance Chips
- No Codes but EVAP is not complete 04 RX330
- Speakers making distorted sound lexus rx330 2004 non-ML, no navigation
- Should power door open automatically when button (on power door) is manually pressed?
- Clunk noise front left wheel
