Oil pressure sending unit location
Old Nov 19, 2021 | 07:04 PM
JimmyRX350's Avatar
JimmyRX350
Default Oil pressure sending unit location
Can someone pl tell me where the Oil pressure sensor/sending unit is located on my 2007 Lexus RX350?🤔
I think it's next to the Oil filter but not positive 😳
Old Nov 20, 2021 | 01:26 AM
Mesquite77's Avatar
Mesquite77
Bottom left front of engine. If looking from the serpentine belt view, then on the right near the crank pulley (raditor side).
*1 = with tow package (i.e., has engine oil cooler)
*2 = without tow (no oil cooler)
You can follow the harness down past alternator and A/C condensor, it is last thing on the end. Yo will need to remove front belly pan unless you can see it with right front wheel off.
Old Nov 20, 2021 | 01:28 AM
Mesquite77's Avatar
Mesquite77
BTW, Toyota calls is a switch, rather than a sensor, on/off deal I guess.
Old Nov 20, 2021 | 07:11 AM
JimmyRX350's Avatar
JimmyRX350
Thx for the Diagram 👍🏻
Old Nov 20, 2021 | 09:55 AM
Margate330's Avatar
Margate330
Default Oil Pressure Switch
Would've been nice if Lexus would've sprung for a real sensor and made the sensor's oil pressure data available to an OBD scanner.
It wouldn't been that hard since the electronics are already set up for live data on coolant temp and other live sensor data.
JimmyRX350
Aug 22, 2021 06:51 PM
BeigeSC300
May 18, 2020 09:50 PM
robd88
Oct 10, 2019 11:19 AM
lexaus
27
Feb 25, 2019 04:12 AM
67rivdog
Mar 6, 2011 08:08 PM
