- 2008 RX350 Back Hatch Won't Stay Up
- Keep Volume Controls with new Head unit?
- 2007 RX350 not blowing hot enough air
- Mating engine and transmission inside the engine bay
- Middle Left Air Vent Blows Cold
- Surge and then engine off, won't restart 07 RX350
- Differential and transfer case OEM oil for the 2007 Lexus RX350
- Strut Replacement 2009 RX 350 FWD?
- Tire Pressure Sensor Question
- New owner of a 08 rx 350 160k NOISE from timing cover
- Sporadic heat issue help!!
- Center Console Buttons
- Where to buy
- Help with 2005 RX330 driver's door lock not operating
- HID Pattern - Normal?
- Instrument cluster bulb burnt rx330
- Engine overheating and misfire cylinder 5
- Afs = hid?
- Spare Tire Lower Cable / Scissors Jack / Alternatives?
- Fix this nasty leather (pic included)
- How do my timing marks look? Do I need to remove the cover and try again?
- Issue with gas cap (Part#:7730006040)
- emissions
- P0717 and P0793 Codes After Changing Speed Sensors Less Than 1 Year Ago
- Front Motor Mount replacement
- Driver side DRL Turns off when headlights on turned on
- Stereo head unit upgrade with bluetooth and USB ports added
- Fuelling Problem
- P2174
- Tire/wheel upgrade 411
- Factory Lift Points(not jack points)
- Rear door switch question
- Coilovers
- Camber Adjustment maxed out?
- 2008 non AFS HID housing part number
- I spoke too soon!
- Back light problem
- Is 260 000kms (161 000miles) alot?
- 2007 RX350 miles per full tank of gas. Anyone?
- Seat back rocking
- Driver side window squeaking at very top position
- Console Storage Open/Close Buttons
- Help needed - how to access Junction Block 2 (J/B 2)?
- Possible to turn DRL off WHILE PARKING LIGHT IS ON?
- Small elliptical bracket(s) that connects ac compressor line to the condenser
- Trying to find a good driving position
- 2007 and programming the key fob
- Ignition Issue
- Radio compatibility within the 2nd gen's
- Headlight and center console lighting issue
- Is this a normal engine sound? Car has 203k miles. I feel a bit of a vibration inside
- Gas Cap Seal Hack (OEM parts, never buy a new cap again!)
- Bank 1 sensor 2 location
- LEaking steering rack replacement options
- warning re hid ballast
- 2007 RX350 Stripped Transfer Case Drain Port
- Replacing Nav Screen with Car Play + wiring Aux
- 2nd gen (2007) RX 350 Liftgate won't close
- 2004 Lexus RX330 making weird sound...
- Car Jerks at Highway Speed
- BG full synthetic ATF
- pushbuttons that open hidden storage in rear hatch....
- Driver seat uncomfortable for 5'10"+ people
- Why on earth is there a fluid tube on the underside of the hood?
- Timing belt replacement, cams off by a tooth
- Exhaust flange studs and nuts rusted to hell
- One more time 2005 rx330
- Driver Side Air Vent Not Opening Enough?
- Tune Up '05 RX330
- Illuminated Door Sills?
- Do I need to do this if I’m hoisting the engine through the top?
- Help with Steering gear and shifter cable
- Installing an idatastart remote car starter
- Multi display not working properly?
- Still going strong!
- Questions on engine removal/ replacment.
- Ac compressor partial remova / engine swap logistical help.
- 07 rx350 p0328 & p033
- Seat Cover for a 2009 RX350
- Tpms blinks..stays on, even after reset. Hlp
- Will an RX300 hood fit my RX400h?
- Anyone have known good waveforms surrounding P0017?
- Grille made in Japan or US?
- How much would it cost to repair RX350 after an accident?
- Rx330 engine swap progress
- Head unit upgrade 2005 RX330
- Correct spark plug socket size.
- AFS lights in a Non-AFS car
- Fuel system depressurization
- Replacements for non-AFS HID with auto-leveling
- Door Control Receiver
- Front rotors from a different generation??
- Hose needed for 2006 Lexus RX 330
- Progress update on 3mz-Fe engine removal and replacement
- Fuse 33 keeps blowing
- LS Wheels
- Calendar issue -- cannot advance past 2020
- Help with multiple codes
- True Dual Exhaust on a 350? + Possible Intake Mod
- Need Help Finding Center Console Insert/Organizer/Adapter Tray
- 2008 RX350 Transmission fluid flush or drain/fill
- When taking sharper turns the slip indicator comes on and the abs will pump the brake
- Just got a Lexus RX350.... have lots of questions?
- 2009 RX350 AWD transmission or differential whir/hum at 15-20 mph?
- Cooper Discoverer AT3 4S: 245/65R17 fit?
- Help removing rear rotors (E brake pad engaged)
- Radiator or cap or other?
- When to bleed brakes? When oil is bad?
- RX330 body control module
- starter stuck to transmission
- Rear Differential Axle Seal & Lower Control Arms - A Few Questions
- Normal idle speed on rx350?
- code 0304 and various VSC ABS codes help!!
- rx330 tranny stopped at a light now wont go into any gear
- code 0304 and VSC
- Remote keys
- Power Steering Difference Between RX330 & 350?
- alternator swap
- Compare RX AWD v GX 470 AWD
- 2004 RX Electrical Component Issue
- What is this spring sticking out in the back of the trunk Rx330 2005
- Busted my mirror
- Break Job for 2009 RX350
- 2009 RX350 air filter 2
- 2004 RX 330 - code P0351 to P0356: Ignition coil A - Primary/Secondary Circuits
- 2005 rx330 evap. hose part number
- Adaptive xenon headlight conversion
- RX Downshifting Pros & Cons
- Upgrade to 99-03 RX300 Armrests
- Preferred brake pad/rotor combination?
- 04 Rx330 air suspension conversion
- Dashboard Whipping a dead horse
- Rear control arm bushings needed !
- water in headlights
- RX 350 Spark plugs
- 2007 Lexus RX350 Throwing A Ton Of Codes
- Leaking washer fluid reservoir
- Barking brakes, Bleed Brakes, Check VSC System
- P0014 code, Dipstick Dry, Boot exploded?
- Need Help with Diagnosis with the p0300 code. Shaking. Also needs head gasket, water
- Coilovers
- New to me RX questions
- Had dash replaced, now my 6 disc cd changer is acting up
- Aluminum Sway Bar End Links
- RX 400h Thermostat change
- Brake padel sinks
- Help in identifying trim component.
- 2GR lubrication system= Shocker
- I change the O2 sensors Check Light Still on! Need help RX 330 2005
- Brake booster removal on right hand drive
- Shout out to PowerBass and those FKers in Germany.
- 09 Headlight Upgrade
- 2nd Gen RX Upgrade/Modification List, DIY Help & More
- 2007 RX 350 keeps dying after changing fuel pump and ignition coil
- 09 RX350 Ignition Coil
- 2009 RX350 cranks but no start- HELP
- Help! 2009 RX350 Trouble code P0171&P0174
- Another speaker/stereo replacement thread
- rear differential swap
- Leaking Seams! Definitely check your RX!
- Trunk latch keeps popping open
- P0441 2007-2009 rx350
- Help!! All Cylinder misfire on 2007 rx 350
- screeching noise when turning - much louder after replacing tires
- Will 235/60/18 fit on 2009 RX350?
- 2008 RX 350 windshield washer not spraying
- Does '120k Service Performed' Really Mean That at Lexus?
- HID to LED headlight conversion
- 09 RX350 Hesitation when accelerating
- Swap to RX400h Taillights (2004-2009)
- What to look for when buying 2009 with over 200k?
- 2008 RX350 Does not blow enough cold air
- Refrigerant Pipe clamp at firewall
- Question about rear hatch button 2006 RX330
- 2009 RX with Nav - can you set the screen to open up on the function you prefer?
- Another Door lock issue - LOCK but no UNLOCK
- Glitch in steering column retraction
- Replacing Dashboard Junction Block
- 2004 Lexus Rx330 rear lift repar
- Is this leather peeling or it is some synthetic panel on the seat? Is it fake?
- drivers door light switch / Body Control Module
- RX300 dragged into the 21st Century, CarPlay & Android Auto
- Blend Door Hunting/Crunching
- Belt Molding Tool
- RX 330 & 400H Suspension Differences.?
- Ghost in the Machine
- 2007 rx350 alignment
- Maintenance Questions
- Wheels lugs and lock
- 2008 RX 350 Check AC on Nav then overheated
- 2008 RX350 Driver side AC is not cooling/ Passenger side is cooling OK
- Is this exposed wiring in front of the radiator normal?
- Rumbling noise when coming off gas
- 2009 RX350 cold start noise
- New Dashboard Wanted
- What does the unused blue 6-pin plug do in the factory NAV?
- Gauge cluster brightness dim during daytime
- 2009 rear tailgate struts que..
- Lexus RX400h - change stock radio to aftermarket Pioneer SOUND ISSUE
- AC completely stopped working in 400h. What do?
- Air intake button issue
- 2008 RX350 Key question
- anyone had calipers replaced?
- MOOG K100401 Greasable Rear Toe Adjustment Bolts (AWD models)
- Work on a'07 RX
- How the VVTi works and the noises it makes
- RX300 air Suspension (again)
- Cup holder insert
- Need help diagnosing inoperative intermittent wipers.
- rx330 motors
- U151 spec'd for T-IV and WS
- Auto headlights don't turn off
- RX350 2008 won't start new batter inserted
- RX330 AC question
- cabin sound level ????
- Check engine light
- 2007 RX350 Transmission additives?
- AliX cheap dash cover (carpeted)
- 2001-2003 Highlander Steering Rack Fits
- Dash cam install, 2008 RX 350, Hardwiring
- Coolant leak 2007 Lexus RX350 HELP PLEASE!
- New Shock or Struts???
- Display screen (the no nav version) is starting to discolor
- Rear sway bar 14mm to 16mm?
- 2001-2003 Highlander Steering Rack Experiment
- What front struts to go with the oem springs
- Sound Deadening wheel well?
- Key assembly -- NEED HELP!
- Reducing wind noise, Quiet cabin (cheap)
- No air from front hvac blends.
- 2004 Rx 330 Bad Vibration under center console when accelerating
- shaking steering wheel
- Radio + CD changer issues
- Remove Under Seat Vent to Remove Object
- Transmission filter change
- Got brakes
- Looking for a good USB data port for Alpine radio
- Steering shaft stuck(?) Up in actual steering column
- Power steering rack isn't tightly bolted in
- Hit the Like Button, Post More PLEEZE!!!
- Air-Fuel O2 Sensor (Bank1 Sensor1, Bank2 Sensor 1)
- Rear diff and transfer case - 1st fluid change
- FELPRO MS 96786 Intake Plenum Gaskets - BUYER BEWARE!
- Unidentified noise
- ignition switch problem.
- Best replacement shocks and struts for the money?
- Body Side Molding Replacement
- 2005 RX330 Calipers & Brakes
- Volume Control '05 RX330
- ABS light on after driving in snow,ice
