- Some pics I just took of my SC400
- Does anyone know where this spoiler came from?
- AEM v2 & GE auto tranny?
- Dgr fabrication
- HELP! Sunroof stuck tilted open!
- tranny coversion question
- Where kind of aftermarket intakes are available for my 98 sc300??
- How do i override the traction control on my 98 sc300?
- Upgrading my dash....chrome trim rings
- Blinker Mod & Foglight Mod
- are my 17's to small or do i just need to drop down
- No power light on auto dim Rear View Mirror
- Replacing head gasket, any suggestions?
- 93 SC400 vs 99 SC400 Projectors
- Bringing me and my soarer to CLUB LEXUS. NEWish
- Murphy's law.
- did type t-iv replace type II ATF?
- New Interior!
- Making the First Changes on My SC300
- 2jzge to 1jzgte trans swap
- has anyone ever put the hks ti limited for an is300 on their car??
- Fan speed changes on its own??
- missing wheel center cap???
- 1995 Fog Light Covers?
- i need a passenger side door lock actuator
- Bored.. Rolling on 18s for right now..
- Fuel pump issues, what do I do next?
- question regarding inter cooler piping placement
- Has anyone tried Ebay Piston Rings?
- Looking for an SC300/400
- Any of you guys?
- Ebay high and low beam
- Speaker change
- Who needs steering rack bushings? Go here.
- Replaced the brakes and new rims
- '97 SC4 Climate Control Died
- Help reading my emission results
- cluster just shut off
- Question on eBay Headlights? Look Here!
- Electronics Shutting Off
- Calling all White Diamond colored SC's
- Head Lights (General)
- the jdm soarer and sc300
- buying a TT supra to swap in to my sc300 got some quick questions
- So, I made a GE manifold...
- Stub antenna, poor reception
- Showroom new 1992 SC400
- need help i have supra seats and need help wiring the power seat
- Coolant line going to throttle body
- gas in your area?
- Power tilt gear...
- wtb sc parts
- How to re-align my steering rack?
- Interesting day at work
- Cam Replacement
- Busted 95 SC300
- found a video with an sc300 in it
- Pics of a friends SC that came by today.
- soarer ac controls
- That damn crank pulley bolt
- Help! Cruise inop after 99/00 steering wheel swap w/pics
- Rough Running SC all of a sudden
- New OZ Wheels
- Unable to Open the Door from Inside
- Question about coil-overs
- Sc300 Wallpaper
- HELP !!need help airbag and steering wheel swap ?
- the sc's out of commission HELP
- Pounds of Pressure in Your Tires
- Interior issue help
- Soarpra, Supra front end on a Soarer SC300 SC400?
- short video
- Tire width for wheel width?
- sc400 help
- Next car? Decisions..
- Help with my turn signals
- 1JZ stalls randomly and now won't restart
- After almost 2 years....
- anyone using a controller from raddesign
- bearing
- help, r154 shifter housing confusion
- 2JZ-GTE Swapped Lexus SC300s @ Kaizen Motorsports
- Need help with trac light codes 95 sc400
- part numbers
- My 97 SC300, first pics..
- Radio Harness
- Think I found the wheels I want to buy
- Need Advice on removing rear lower control arm..
- ***BIG PROBLEM*** NEED HELP Rear Suspension
- JDM Supra Adjustable struts
- Help! Need advise on short shifter!
- Tilt motor problems
- New Wheels - What do u guys think?
- Need sum fender opinions
- MAPECU(1) vs SAFC: Timing and fuel
- Help needed from the tire guru's.
- Tune Up - What am I missing?
- Need Help! White smoke from exhaust and check engine light!
- Passenger air bag, Black or SEM a tan one??
- looking for pt# in this kit
- Show off your Engine Bay Pics......
- New Cali smog rules for 2013?
- Supra vs. Aristo 2jzgte installation...
- A question for those who have seen OEM Upper Control Arm Bushings
- carbon fiber hood
- my ac is not broken but it doesnt work
- marlin crawler parts for late model soarer trans
- Road & Track - 1992 SC400
- sc400 corner weight
- not sure what do yall think?
- What should I lookout for when purchasing a sc300?
- pics of my work in procgress
- Opinion wanted: should I use these emblems?
- is this compression good on the 1jzgte?
- HID lights Help!!
- Car is worst after tune up???......
- HID's ...New battery?
- A Few Things I've Been Buying And Wanted To Share A Few Pics..Hope You Like!
- Should I buy?
- Corning/Fog light HID retro fit idea
- Evo Wheels on Sc300??
- Installed Front Lip Today
- Is my mechanic serious?
- Common power sterering issues in the sc400??
- new guy
- Car died suddenly
- no power to radio
- New For 2011: XXR 526 surpise LOL
- Windshield fluid line
- Just got a sc300 last week.... and now I regret
- Numbers below VIN on 92 SC400
- rock chips up front
- Ordered some new seats for the supra... may get the same for the SC
- Power cutting out
- LexusFTW's Quest for More Horsepower
- the beginning of another swap o god plz dont take long
- LS400 to SC300..
- What are you doing with your tax return??? (if you were working)
- 1jz swap question
- Bad Power Steering Pump?? **VIDEO**
- Some new pics of my SC.
- Help with 1JZ swap anyone?
- How do you remove the wood trim under pass air bag on a 97
- some wheel help.
- Remove back seats?
- manual engine harness in auto?
- Problems lights keep flashing
- IMF performance Y pipe
- 20" wheels on 97+
- Aem ems gte to ge
- eye can see clearly now!!!
- ebay turbo kits????
- What size amp for the stock sub??
- Pics from this weekend in Savannah
- What a Tease! Got me some fine looking tail this weekend!
- Drifting Pictures
- Not running on all 8
- Sc400 Stereo wire color codes
- auto 1jzgte with soarer r154 into manual sc300
- sc400 flex coupler!!
- 12 CD Disk Player
- SC Video...
- None of the speedo or dash lights working how to fix?
- How and why do i keep geting water in my cylinders! car wont start because of it.
- soarer r154 transmission input shaft cracked!?
- Anyone using the Apex Neo on stock SC400?
- Painted Wheels which looks better?
- Marimoto Projectors (H1/D2S)
- supra sway bar
- Wonder wth... Do i do!!!
- Need some help..
- Where is the factory chirp siren ?(Stock Alarm)
- My Baby wont start
- Weird sqeaky noise Cant figure it out
- cat delete or midpipe for sc300????
- 1.5jz-ge+t questions !!
- anybody with a passenger side door handle
- bogging badly at low rpm after tune up
- 97% complete 5spd swap
- will this strut bar fit a sc300
- Last night car died on highway at 70mph
- my cluster stopped lighting all up
- 98 SC400 Camber Kit
- 94 sc-300 got wrecked...
- Your opinions on my ball joints
- whats the diffrence in Misfiring,fuelcut.boostcut?
- 6.5 Speaker Adapter for Rear Fitment
- need some help with rims.........
- TT Fuel Pump
- HiRo Body Kit?
- what is the best turbo to get for right now power?
- What color should I paint my head lights ?
- How's this timing belt look to you?
- A little motivation for your slow going projects
- Instrument Cluster / Factory Alarm
- sc400 power steering issue?
- tail light strobes?
- Quick Brakes Question
- Question about rims
- Rear end Damage on SC. Debating what I should do.Pics included.
- 1jzgte or 2jzgte swap
- sc300 1jz single turbo need help
- A Lil "what rims are these" Thread.
- sc400 broken antenna
- Code 25,26
- so after i sell the sc300.. what should i get?
- Installed 3M Di-Noc Carbon Fiber Vinyl on Interior
- soarer window trim vs sc300 trim...
- Ebrake have anything to do with seat harness?
- 350z wheel question
- Ebay Seller has Erebuni Style Rear Lip?
- my sc400 1jz swap finally
- who owns this SC?
- 2jz turbo downpipe
- Window Tint..
- Can't help but post these pictures!
- Quick ??? About cabin air filter.
- Seat belt light with after market seats. Q'
- Future Plans For My SC400
- Will an obd1 sc300 body harness plug into an obd1 sc400?
- So i did the blacked out headlight mod and now...
- SC with LFA-Style Body Kit?
- Swapping trans. What else should I change???
- Why am i Smelling gas
- Best source for oem floor mats?
- Gold Emblems
- WTB exhaust system for 97 sc400
- Front seats interchange
- Gauge Cluster LEDs
- What exactly is na-t?
- Saleen Rims on Sc300
- EGR Help
- Coilpack Clips Problem
- Dilemma!
- spent my day off doing this!!!
- Painted calipers Red and Silver...
- 1992-1996 & 1997-2000 Spoiler Holes
- R & L distributing sucks
- I need a new button for my key...
- 1993 sc400 for sale
- Check out the mileage!!!!!!!!!!!!!!!!
- Need some exhaust feedback.
- Cost of an SC new?
- not the type to bash but...
- My pride and joy!!!
- NA-T turbo manifold question
- My new wheels, tires, clear side markers and window tint
- 1.5JZ build, Bad knocking :(
- we all know about the LS 4pot in the front but about the 2pots in the rears
