cluster just shut off
Old Mar 7, 2011 | 07:34 PM
t66sc3's Avatar
t66sc3
Default cluster just shut off
I have a 99 sc300 and as i was driving the cluster just went black, everything works as it should the only illumination i get is from the turn signals everything else black. I get illumination through the radio and climate control and the dimmer switch still functions correctly.
I tried banging on the dash and no such luck. i checked every fuse in the drivers kick panel box also under the hood and none blown and have continuity through each as i should.
So is there a common fuse or ground i should be looking for to diagnose this problem also does anyone know where i should be getting power to the connectors in back of the cluster to deem the cluster itself is where my problem lies.
If anyone has a interior or gauge cluster wiring schematic id help me greatly as im stuck untill i can dig up some more information on this circuit.
thanks in advanced,
brian
Old Mar 9, 2011 | 06:54 AM
t66sc3's Avatar
t66sc3
any ideas?
Old Mar 9, 2011 | 08:07 AM
iridebmx's Avatar
iridebmx
is your car lowered by chance? if so, its prolly your harness in the wheel well.
if your not lowered... no idea. do you have a aftermarket headunit in?
Old Mar 9, 2011 | 11:28 AM
soarer13oy's Avatar
soarer13oy
try unplugging the negative cable for a couple minutes and then plugging it back, if youve checked your fuses.
Slickcam
GS - 1st Gen (1993-1997)
Mar 4, 2016 09:26 AM
RobertMuir
May 16, 2014 11:19 PM
j stuff
Feb 22, 2011 09:54 AM
serioh22
Jul 29, 2010 01:41 PM
JAPPILAC
Mar 23, 2009 06:33 AM
