- Anyone in/near Ventura, CA with a 3GS?
- Sinking brake pedal 2007 GS 350 AWD
- My car interior noisy sound
- GS 350 getting loud
- Leather Seat replacement!!
- Stock stereo is cutting out
- Low Gas Milieage
- Trunk lid spoiler
- Lower Door Trim
- Reuse a Second-hand Lexus Certification ECU
- 3GR-FSE to 6 speed manual with RA62/RA63?
- 2010 GS350 Aftermarket Headlight swap
- 3gr fse swap to 2gr fse
- 06 GS300 Trunk Won't Open
- GS450h (2008) - Interior lights ridiculously dim
- Engine coolant pipe o-ring size
- Headrest help
- 2007 GS 350 awd P0300, P0301 and P0420
- Just Bought an 08 460 Smoky Granite Mica
- Gs430 issue with cruise control or normal operation?
- Avalon Owner Needs Advice on Garage Keeps 08 GS with 144K miles
- JDM OEM Lip Kit
- low tire
- Strut bar
- Tire recommendation for 3GS AWD
- GS460 Headlight lens re-seal
- Reading live data
- 2006 Lexus GS300 Vacuum Hose
- 2010 Lexus GS460 Upgrades
- Caliper and bracket bolt torque for 2006?
- Gs460
- Can 2006 Lexus IS250 Rims fit on 2006 Lexus GS300 AWD (pics attached)
- Temperature gauge problem
- check system light tire pressure
- 2006 GS 3000 - Starting issues
- Ruthenium spark plug (NGK)
- Decisions Decisions...Please Advise
- Air Mix Servo Stuck (i.e. can't pull it out)
- Need "How To" remove roof trim moulding
- 2011 Lexus GS 350 Headlights faded, need new ideas
- Hello everyone!
- Unable to add new key to my 2008 Lexus GS AWD
- Lexus GS450 Adaptive Cruise Control Sensor Location
- Weird noise when turning left GS450H 2006
- 2006 gs430 atf drain plug question
- 2007 GS450H longevity
- Model Year Upgrades
- automatic tranny fluid level check
- Tires for 2008 GS460
- Tow Hooks
- Berryman's Piston Soak Results
- car wont start after fuse swap?
- Doing after market stereo (Not Tesla screen)
- Axleback cat back from lexus IS350 will it fit?
- P0022 and P0300 on GS450h
- 2006 GS430 VSC ECB ABS Brake and TC only when cold out
- Stop Catalytic Converter Thefts
- Still in need of help
- Muffler replacement GS350 AWD
- vvt oil line replacement
- Gs460 low engine oil
- White smoke and humming type sound coming from engine bay.
- Air Mix Servo Motor Help (2006 GS 300)
- "Check System" TPMS ERROR - can't remove it. Batteries, or?
- Driver side air mix servo motor -- gear arm (?) broke off
- 2011 GS350 charging problem diagnosis
- Midpipe
- 2006 GS430 Won’t Start
- Gs350 2007 tail light
- How to remove cracked lug nut?
- Headunit converted to TESLA STYLE SCREEN
- Cost effective Bluetooth connectivity that actually sounds very good.
- Front Clunk Over Bumps After Tire Work (TPMS)
- Anyone knows what sensor is this?
- 2006 gs 430 transmission problem
- Front dash speaker replacement?
- Question on parking lights
- Help deciding between two used vehicles
- Help w/ ECU/ECM Location
- GS300, what mileage is too high?
- Please help!!
- pacesetter manifolds?
- Leveled AFS, still flashing
- HELP!! 2011 Lexus GS350 rpm fluctuating when car starts
- How Durable Are Our Transmissions?
- mr
- TPMS light on aftermarket rims
- 2006 gs430 tpms
- Highest Possible Gains on 2007 GS350 RWD
- 2008 GS450h cracked block
- friend of mine GS450H 3rd gen just died please advice.
- Help! Electrical problems 07 GS 350 AWD? Or something else?
- Replace 2009 GS350 (225/50/R17) with 2013 GT200h F sport rim and tires (215/45/R17)
- How is the boot lid supposed to work?
- Can the AFS swivel motor be replaced, without buying the entire assembly?
- 2008 GS350 Non-ML Sound issues
- Code B1214 Understand the Door System Bus 2007 GS
- Gs 2006-2011 sounds system
- 2007 GS450H Not starting after tinting guy put new tint on
- Help please
- GS460 and LS460 Oil pan questions
- Need help finding bushings + LCA bushings
- 2008 gs350 AWD starter location
- 2006 gs300 awd starter replacement having trouble
- 2006 GS 300 Limp Mode
- Bought a 2008 GS460. Need advice.
- Need Help with CEL!!!!!!
- 2006 GS430 200,000miles
- Sound system
- 2006 GS300 Oil Consumption / 5K mile oil change
- Lexus gs450h engine misfiring - p0390 code help
- What issues gs430 can have?
- Parking light as Daytime running lights
- Gs430 ECU
- Weird Trans issue?
- Electric power steering
- Aircon temperature control
- Replacement speaker foam rings for 2010 gs450h ml speakers front and rear
- 08 GS460 Sunshade stopped working
- 2011 Japanese Import with a 2GR-FXE??
- How to adjust headlight for GS 3rd gen ?
- WTB exhaust for GS
- Windshield water pump location
- Will P265\65R17 tires fit my car?
- *attention passionate 3gs owners*
- Need info on throttle controllers
- Blown Mark Levinson speaker? Torn Speaker Ring? Super easy repair and upgrade.
- Lexus gs 350 gs460 navigation screen repair
- 2006 GS300 Problem HELP! - VSC / Alternator / Starter / Wiring
- Head Gasket replace, GS350 w/2GR-FSE. AWD, 08. help
- Introduction New to Lexus
- Will a 2GR-FSE fit in a 2006 GS300
- Rear sunshade won't go up past half way
- Advice needed on 09 AWD Value
- Lexus 3GS aftermarket seat bracket
- rear head rest
- Reliable DRL/High Beam LED bulbs
- RC-F & GS-F LCA bushing purchase
- 2006 gs350 & 2006 gs300
- 2008 GS460 ML rear door speakers question
- Price Check 08 GS460 120k mi 1 owner FL car dealer svc'd
- Wheel advice - 2IS wheels / tires on 3GS?
- A warning about Quantum Auto tuned GS430 ECUs
- New to Lexus. Need some help.
- Waterpump Preventative Replacement
- Low Key Fob Battery
- Abs light on
- Weird Squealing Noise from the Hood
- Transmission : 430 &350 the same or different
- 2006 GS300 start / no start issue
- GS350 midpipe fit GS450h?
- Gs350 gauge cluster self test.
- Front end clunking in tight parking turns
- 2006 GS 300 won't start after battery Recharge
- Vantrue N4 3 channel Dashcam
- 06 gs300
- Optional Audio Input? Built in Audio input from factory.
- Will 2010 GS350 AVS struts fit a 2006 GS430?
- Paint chip color code 3R1 GS350 07
- Rocker Panels
- front door windows scratch easily !
- Aftermarket speakers 08 GS350
- O2 sensors - Gs350 2008
- 2010 GS Daytime running lights.
- Electrical Issues
- Questions: Japanese Import 2006 GS
- Might buy an 08 GS460
- GS450H don't want start after long stop
- 2006 GS430 start issue and keyfob issue. Calling All Master DIYR'S!!!
- How do I remove the foglight assembly?
- changing brake pads - 2010 GS350
- GS460 valve cover gasket install
- Misfire On number1 coil
- Need help - communication failure
- Wheels
- GS 450h No electrical power when vehicle is off.
- Non-routine maintenance for longer trouble-free motoring
- Multi-Display Malfunctioning
- Drivers side headlight
- 3UZFE HP changes
- Fuel trims skyrocket with ac on help!!
- Anyone seen in person/know of this custom built gs430??
- 06 GS 430 interior mirror Q
- Head units
- 2007 GS350 not starting
- Max rim and tire package I can install.
- Lc7i. Pre-install 2007 gs350 non-ml
- Can you put 1ur-fse in the gs350?
- A question on method to change the ATF on GS450h (3rd gen)
- Bought a baby GS300 --> IS250
- CV split boots for front AWD?
- Does your GS300 steering wheel or seats vibrate?
- Please place all WTB and FS threads in the marketplace classifieds only
- All warning light on
- Oil control valve
- (Gs460) CEL: P0174 and P1170… thoughts?
- anyone else have a broken lumbar support switch before? How did you fix it?
- New Battery New Alternator Still Not Charging 2007 GS 350
- Need help with my 2006 jdm Lexus GS 350
- Need help diagnosing car pulling right
- 3gs potentially burning oil
- Misfire in D or R while idiling?
- Weird Noise When Lightly pressing on the Brakes
- Wanna 2jz my gs350 2007
- 09 GS350awd - P2757 code - was no transmission fluid
- Coilovers for GS460
- Check Engine Light - O2 Sensor
- GS350 AWD front strut removal
- headlights replacement?
- GS300 warning lights
- Upper oil pan/oil pan no. 1
- Unpleasant sound after catless downpipe
- air vent removal
- Clicking in headlight housing
- 2010 engine replacement
- Intermittent wiper problem
- Issues after changing ATF on 3rd gen GS450h
- General Servicing Advice
- 08 GS 460 Atlanta area
- Steering Wheel spot light - very dim
- Front rotors Problem
- Junk Cardone CV axle.... has anyone seen this?!
- Leaking brake line during ABS replacement -- URGENT PLZ HELP
- 08' Lexus GS350 Key fob battery
- Lug nuts
- Cardone CV axle replacement
- Has anyone seen these wheels on a 3GS?
- Intermittent HVAC Issue. Not really sure where to start?
- Installing Bluetooth Module in a CD Changer model (Not DVD Changer)
- Low beams not working
- GS460 Exhaust
- Seat swap
- 3rd gen AWD
- Upgrading to 2010 NAV
- Driver power seat noise
- Trailer light wiring
- All for sale and WTB threads belong in the marketplace classifieds only
- Alternator not charging battery 2006 Lexus GS 430
- Help: 2008 GS350 Runs Great but Burns A LOT of Oil. What to do?
- Vacuum Switch Valve (VSV) change
- Ambient light (daylight) sensor removal?
- 06 GS 300 oil leak at water pump?
- 2010 or 2011 3GS Nav w/o Tape Deck in 2007 3GS
- 2007 GS350 won’t start
- Which part of sunroof is this?
- F sport cold air intake GS350 fitting
- Car won’t go higher than 2k RPM
- Interchangeable side view mirrors?
