Ruthenium spark plug (NGK)
Old Mar 16, 2023 | 06:18 PM
fey725's Avatar
fey725
10th Gear
Default Ruthenium spark plug (NGK)
Is there anyone who has used a ruthenium spark plug? I am not using it yet , but I want to know how it feels. (2007 GS350)
Old Mar 18, 2023 | 03:04 PM
ibidu1's Avatar
ibidu1
I would only stick to OEM plugs or NGK part number FK20HBR11
These engines are sensitive to spark plugs. Original plugs are pricey but they last a long time. I would avoid buying ngk from online, because the majority of online ngk plugs are fake. Original ngk's cost around $11-12 make sure it is from a reputable scource
Old Mar 18, 2023 | 03:06 PM
TreysGS460's Avatar
TreysGS460
I've had them for about a hundred miles on my modified 460, not long enough to tell a difference and i've been waiting on gaskets from lexus before really driving the car.
I doubt you will notice anything anyways, they're just spark plugs...
Old Mar 18, 2023 | 07:20 PM
TopNotchIN's Avatar
TopNotchIN
@fey725 I've had them in my '11GS350AWD for about 10k miles. They work fine, but are no better than the original plugs. Just use DENSO or NGK and you will be fine.
Old Mar 20, 2023 | 07:10 AM
fey725's Avatar
fey725
10th Gear
I wonder what is worse than the original. ⁇ Is the startup unstable or the acceleration not as good as it used to be? ⁇ I already bought it from Rock Auto, and I regret it.
Old Mar 20, 2023 | 07:16 AM
fey725's Avatar
fey725
10th Gear
I wonder what's wrong with it, for example, the engine is unstable, or the acceleration is not as good as it used to be. I bought it from Rockauto and regret it.
Old Mar 20, 2023 | 07:21 AM
fey725's Avatar
fey725
10th Gear
These engines are sensitive to spark plugs. Original plugs are pricey but they last a long time. I would avoid buying ngk from online, because the majority of online ngk plugs are fake. Original ngk's cost around $11-12 make sure it is from a reputable scource Thanks for the great imfo
Old Mar 20, 2023 | 01:21 PM
TopNotchIN's Avatar
TopNotchIN
@fey725 The NGK Ruthenium plugs will work good. I have used them for awhile and have not had any problems. It is recommended to use the original DENSO plugs or NGK because they are known to work correctly with our cars.
Old Mar 20, 2023 | 01:30 PM
TreysGS460's Avatar
TreysGS460
They are not worse than OEM, its just a different type of plug. Its really only recommended for modified vehicles, a stock 350 doesn't need them and won't notice any changes.
Old Mar 20, 2023 | 06:01 PM
fey725's Avatar
fey725
10th Gear
Smile
Thank you very much for all of your responses - it's a great help
snook789
Feb 18, 2023 12:12 AM
fastegg
Jul 29, 2014 03:20 AM
dhuston99
Jul 13, 2013 04:31 PM
CBRA928
Aug 10, 2010 01:57 PM
GOLDSc300
Aug 9, 2002 09:53 PM
