2006 gs430 tpms
Old Jan 23, 2023 | 11:30 AM
e-man's Avatar
e-man
Default 2006 gs430 tpms
I am buying replacement sensors on Rock Auto. I seem to recall that Denso is the OE replacement — Denso 5500103 for $35.79 each. Does anyone know the difference between those and the slightly more expensive category (Programmed + Clone Capable)?
Old Jan 23, 2023 | 03:34 PM
Oceans13's Avatar
Oceans13
I bought oem denso on rockauto and had a local shop install them. Then went to a Lexus dealer and had them program the sensors with TechStream. Write down the serial numbers of each sensor and which tire they go into before installation because they will need that info to program.
Old Jan 23, 2023 | 03:44 PM
e-man's Avatar
e-man
Thank you. Do you have to go to Lexus to program them? Are local shops/chains not equipped to do that?
Old Jan 23, 2023 | 08:11 PM
CruzinGS's Avatar
CruzinGS
The Denso 550-0103 part is exactly what you'd get if you walked into a Toyota or Lexus dealership and asked for a TPMS sensor for a 2006-2011 Lexus GS. Neither Toyota nor Denso actually manufacture this sensor, it is made by Pacific Industrial Company, LTD, and will be marked with their part number PMV-C11A. The older Denso 550-0102 part is actually Pacific PMV-107J. These sensors seem to last for quite a long time, and are the sensors your car was designed to use, so I'd recommend them above the "premium" models, provided that you have a way to program the car for the IDs.
I don't have specific experience with the "programmed + clone capable" models, but I would guess (and YMMV, take this with a grain of salt) that they come pre-programmed with a unique sensor ID, but have the capability to "clone" the ID of another sensor and use that as their own ID. This allows you to swap out sensors without needing to reprogram the car, if the clone procedure works (which also assumes that you have a way to program them, or all of your old sensors are still working / broadcasting).
One note of "caution" though -- there is a switch under the passenger's side dash that lets you toggle between two sets of sensors (summer and winter wheels kind of thing). If the switch is in the "B" position, that may cause problems. I believe the way most tire installer tools work is that they program the sensor IDs into the memory "slots" for the "A" set, so it will look like programming was successful, but the car will report the "CHECK SYSTEM" message because it is still looking for the old sensor IDs of the "B" set.
Old Jan 23, 2023 | 09:04 PM
e-man's Avatar
e-man
Thank you, I’ll get the Densos at Rock Auto.
Are there places other than the dealership where I can get them programmed/synched up with the car?
Old Jan 23, 2023 | 09:11 PM
lexo98's Avatar
lexo98
What's the price breakdown of what you paid. From my experience the dealer is way over priced for anything TPMS releated.
Old Jan 23, 2023 | 09:16 PM
lexo98's Avatar
lexo98
You are correct about cloning sensors...Maybe with Techstream you can pull the ID's from the ECU if the sensors are dead, but I don't have experience with that. I know with Ford it can be done with some TPMS scan tools.
Old Jan 24, 2023 | 01:45 PM
CruzinGS's Avatar
CruzinGS
Techstream can definitely show you the IDs that are programmed into the computer ... but at that point, if you have Techstream, you can just program your "preprogrammed" sensor IDs into the car's computer.
Old Jan 24, 2023 | 07:10 PM
e-man's Avatar
e-man
Does only the Lexus dealership have tech stream? Is there any other equipment that can program the sensors?
Old Jan 24, 2023 | 07:23 PM
lexo98's Avatar
lexo98
Your local mom and pop shop might not be able to but most large chain stores can. Costco. Sam’s Club, Discount/ America’s Tire etc.
Old Jan 25, 2023 | 04:06 PM
e-man's Avatar
e-man
Does anyone know if donut spare has a sensor?
Old Jan 25, 2023 | 06:41 PM
lexo98's Avatar
lexo98
it does not
Franck
Mar 5, 2025 04:45 PM
Soarer2
Wheels, Tires & Brakes Forum
Oct 20, 2023 01:51 AM
ColdFusion
May 20, 2018 11:42 PM
justYnG
Jun 11, 2014 11:02 PM
