GS300 warning lights
Old Aug 30, 2022 | 08:10 AM
Antant1963's Avatar
Antant1963
5th Gear
Default GS300 warning lights
Hello could some one tell me if there is a fuse that controls all warning lights on a GS 300 yr 2005. I have no warning lights on. I have taken out the tyre sensor TPMS to change battery. Also now and again i use to get low oil pressure. I broke down last month and Lexus said i needed a throttle Accutator (spelt wrong) wanted £1500 to change. Took it to local garage who reset using there ODB reader. Am worried that if oil pressure is low it wont let me know. Thank you
Old Aug 30, 2022 | 08:31 AM
So lights are on the dash? Or no
Old Aug 30, 2022 | 08:48 AM
Antant1963's Avatar
Antant1963
5th Gear
Default Gs300
No warning lights on, head lights showing and when door is open shows light. I know there should definitely be a warning light showing tyre pressure as tpms taken out
Old Aug 30, 2022 | 08:57 AM
Antant1963's Avatar
Antant1963
5th Gear
Default Gs300
Old Aug 30, 2022 | 06:54 PM
firelizard's Avatar
firelizard
98-05 generation GS300 don't have TPMS. Are you sure you have a 98-05 GS, not the next generation? There was overlap in sales years.
Old Aug 31, 2022 | 02:42 AM
Antant1963's Avatar
Antant1963
5th Gear
Default Gs300
Thanks for your reply my reg is LM05PNE , I took one of the wheels off and removed the valve which has a battery attached. Found both wheels on passenger side when I let tyres down would get a low pressure message. Drivers side back and front no message so took it for granted that both were faulty.
Old Aug 31, 2022 | 10:32 AM
ThomasGS4's Avatar
ThomasGS4
OP must have a 3GS judging by their location and TPMS issue. Other countries received the 3GS as a 2005 MY.
Old Aug 31, 2022 | 01:46 PM
Antant1963's Avatar
Antant1963
5th Gear
Default Gs300
I do know they changed the gearbox that year and then reverted back to the original one as I had to get a new one.Regarding the TPMS don't know why they put the valves with the batteries in it if there not used. Just need to know if it all runs off one fuse all the warning lights.Thanks for replying
RobbieD77
Jan 9, 2022 12:21 PM
whatnext
Jul 31, 2015 05:55 PM
sdh2106
IS - 1st Gen (2001-2005)
Nov 24, 2014 11:15 AM
bmenace781
Apr 22, 2007 08:22 AM
socalJD
Aug 2, 2006 04:36 PM
