CV split boots for front AWD?
Old Sep 18, 2022 | 01:10 PM
jrk1956's Avatar
jrk1956
Default CV split boots for front AWD?
Does anyone know of a source for front CV inner split boots for 2007 GS350 AWD?
Old Sep 18, 2022 | 09:57 PM
ibidu1's Avatar
ibidu1
I would avoid using split boots! They are not long lasting like oem stuff, the same can be said for aftermarket cv boots they dont last long. If you can source oem stuff or stuff that matches that would be good.
Some shops can replace cv axle boots without removing the axles from the car. If you can find a shop that has a specialty cv boot spreader, that would make life easier. As the passenger cv axle is a nightmare to remove on the awd, I would try to avoid having to remove it.
Old Sep 18, 2022 | 10:01 PM
ibidu1's Avatar
ibidu1
Found this little cone, pretty cool
Old Sep 19, 2022 | 04:53 AM
jrk1956's Avatar
jrk1956
TY, I did find a video that takes the axle apart at the inner CV joint (avoiding completely removing the axle from the differential). So I will go that route,
TY again for advice.
joedaddy1
Apr 27, 2016 05:40 AM
bdar
Feb 19, 2016 12:26 AM
lexasgs400
Mar 14, 2010 05:34 PM
lexasgs400
Mar 1, 2010 11:02 PM
ServerTech
Mar 10, 2007 01:32 PM
