Engine coolant pipe o-ring size
Old Apr 8, 2023 | 07:33 AM
Brt's Avatar
Brt
7th Gear
Default Engine coolant pipe o-ring size
I destroyed the new o-ring when i tried to fit the water outlet and i do not find the old one so i can take measurements
it is the o-ring between the water outlet/distributor thingy with the radiator cap and the pipe coming from the engine.
The Lexus part number is 96761-35025
Does anyone know the size of this o-ring so i can buy it at my local parts shop in Sweden?
Old Apr 8, 2023 | 10:18 AM
Don't know the size. This site will ship most anywhere in the world but of course you'll have to wait which you should. Do the job right with the correct part.
https://www.amayama.com/en/part/toyota/9676135025
Or put a caliper on the pipe, get a generic O-ring and hope for the best.
Old Apr 8, 2023 | 07:27 PM
ibidu1's Avatar
ibidu1
You can remove the tube, theres another o-ring the exact same on the other end. and take it to an auto parts store and match it. If you are not able to find the measurements. Or just take the housing and match it up
Old Apr 8, 2023 | 11:32 PM
Brt's Avatar
Brt
7th Gear
Thanks! I took measurements of the smallest inner diameter of the tube and on the pieces of the broken o-ring and it seems to be 25/32x3,5 mm.
TriniLex
Sep 23, 2022 07:02 PM
lexus-is2
May 11, 2013 09:27 AM
PFB
Mar 10, 2013 07:40 PM
ShortyPH
Dec 5, 2010 09:16 PM
TMaxxTim
May 4, 2006 09:43 PM
