- looking for stoptech brakes
- Oil Maintenance Reminder Reset Procedure - Video
- Parking Brakes
- Rx shift knob to Gs???
- Do yours rattle this badly?!?!
- 07 Gs350 check engine light blinking..
- Plastidipped my 2006 gs3 chrome trim
- New to Forum
- Lexus GS300 lighting question, driving light bulb question
- Lexus GS460 22 inch wheels
- 22 inch wheels
- I cant start my GS 350
- Need new front struts
- Wheels with stock suspension question
- Trunk Carpet doesn't fit?
- Repeated check engine light after installing k&n intake
- Inspecting and cleaning speed sensor rotor
- Which Tire; 235/35/20 or 245/30/20
- Former Avalon owner to possibly a 3GS AWD owner, need your advice please.(Researched)
- Lexus dealership cannot figure out what's wrong!!!
- Mark Levinson tweeter question
- Need Help with Ignition Switch removal
- Tire size helppppp!!!!!!
- GS 350 Passenger HID turning off after few mins (new Owner)
- Goodbye dear '07 3GS
- Range Approximate is very low.
- Looking for this exact day time bulb
- Does anyone know how to do the NAV/DVD over-ride (cut wires) on the 2011 GS 350?
- 2006 GS300 Spark Plugs are Easy!
- Winter Wheel Options
- Spare Tire for 2007 Lexus GS 450H
- Squeak / Squealing noise from Air Conditioner when heat/air con ON
- Where to buy timing belt & water pump kit for 06 GS430?
- My 2006 GS430 experience
- installed alt. and now won't crank or start
- could use better brakes... (near miss accident)
- I can't find the right size rims for my car!
- Recommended scanner to read wheel speed
- 2011 GS350 - weathertec all weather mats issue
- Share your exhaust setup here
- Megan midpipe vs Invidia midpipe
- HPS intake vs k&n typhoon
- Caster & Camber out of Spec During Alignment
- First post - coolant problems
- 2006 lexus gs300 check engine light trouble
- memory seat problems
- Total noob needs help with exhaust mods
- Thinking about switching from ES350 to GS350 AWD
- Has anyone here had their car repainted?
- Codes Po172 & P0175
- 2GR-FSE Timing Cover Oil Leak?
- Mis-Post
- How do I check for codes for with an OBDII?
- 2011 Lexus GS350 non mml how to add a signal processor
- Rear Seat Torso Airbag
- Got T boned
- Difference between 2008 GS460 and 2009-2011
- What do YOU use to clean your 3GS leather?
- 2007 3GS aftermarket rear bumper search. Help me!
- Can't unlock trunk
- Can this board tolerate another transmission discussion?
- Front suspension wear
- simple iPhone integration kit?
- 06 GS300 inner headlight issue
- Old Lexus member but new 3GS owner!
- VSC/engine light & headlight
- School me on GS 350 paint
- 2007 gs350 wont start need help!!!!!!!!
- RPM's drop normal in S mode?
- Aftermarket Headlights
- Body Lean
- Drove over a curb...Help
- How can I reset tcm memory for my GS350?
- How to protect your floor mats (A Revolutionary Solution)
- Advice Please! 2006 GS300 Purchase after Recall Service
- Factory speaker
- Question: Can I put 245/50R18 Pirelli Cinturatos on my 2006 GS 300 awd?
- looking for aftermarket grill for 2009!!!!
- DIY Water Pump Replacement Video
- Are the oem "f sport" parts worth buying?
- 2006 gs430 superchargerd
- Permanently disabling seat belt buzzer in 2007 & 2011
- New to Lexus... Exhaust diameter?
- engine stutter coming to a stop...
- aftermarket "JDM/VIP" signals
- The cut key
- 4gs rear on 3GS?
- Those with aftermarket front speakers..what are you running?
- Brighter Headlight Suggestions?
- Brakes making loud squeaking noise!!!!
- MPG seems pretty low...
- More Repairs on GS350
- Need plastic bracket for license plate
- Anyone used Leatherique on their 3GS?
- Satellite Radio Install In GS350
- Comprehensive DIY Videos
- hood strut? DIY? anyone tackle this yet?
- Does anyone know how to adjust the highbeam lower?
- Brake malfunction' Vsc, awd, abs light all on!
- Headlight Chrome
- 2010 GS350 - issues?
- Water on the floor in the rear seat carpet
- 2009 ISF Wheels opinions!
- No Idea What to Call This Thread Problem
- Rear muffler delete on 2006 GS430?
- question about transmission fluid change, please help
- 07' gs 350 awd engine vibration.
- Looking for Lexus Mechanic that does side work in San Diego
- Question about light bulbs and interior lights
- New to the Club, back in a Lexus
- New guy with a new to me GS 300 AWD
- New to GS350
- No Crank, Check VSC, cooling fan runs.
- 2007 GS350 AWD Rear Bearing Replacement - notes
- Had a friend powder coat my wheels, opinions..?
- Horrible Fuel Economy - '07 GS 350 AWD - 13L/100KM (18MPG)
- Part numbers for fuel pumps/injectors
- Happy to join the forum!
- gs350 AWD slip indicator, power loss at 55+ mph
- This isn't the classifieds.
- Replacing Windshield Washer Fluid
- Farewell...sort of
- 2009 IS F or 2014 IS350 F sport
- New to the forum, transmission question.
- My first GS350
- Vaistech SL3B Simple/Settings Mode Question
- Door speakers 6.5" comp set
- What could be wrong with my 06gs300
- Very LOW Mileage 2008 460 - This is NOT a Classified AD
- Malfunction Indicator Light On?
- i250 caliper vs gs350 caliper
- Invidia Mid Pipe on AWD
- Gs460 with 140k?
- What is this cog for?
- 2010 gs Lexus 350
- Lost my car, looking at a GS350
- Purchasing a 06 GS430 with questions!
- 06 GS300 changing temp from C to F
- Starter issue?
- ML radio won't read the VAIS IVIC or the IPOD hookup
- adjusting headlamps help needed
- Safety Recall ELF time for repair?
- thread closed
- Broken TPMS Valve stem
- Leather and plastic paint
- Deciding between 2 vehicles
- Recommendations
- Anyone got pics of Weathertech window deflectors installed?
- Long shot - Anyone have old drip rail moldings?
- HELP! - 2007 GS450H won't start even with jump
- Advice RX vs GS
- New Water Issue
- Remove driver side door trim
- Repair Suggestions Needed for 07 GS350
- 3GS bodystyle VS RC-F goodness!
- 2006 GS300 buring oil - 145k miles on it
- Walnut blasting in Brooklyn, NY?
- Holy fricking rattles!!
- 08 gs460
- engine off sound
- aaaaaaaaaaaaaaaaahhhhhhhhhhhhhhh!!!! An GS Abomination!!!!
- Rattle Noise | passenger dashboard | 2008 GS
- start button not working after trying to program key
- New Owner
- My GS300 got smacked by UHaul truck
- TPMS ID codes, and my stupidity.
- 07 GS350 Suspension questions Front Caster bushing
- Just got new toy!
- Rear Satellite Speakers Replacement help
- ABS part
- trunk not locking down GS300
- Trunk auto lift when released?
- GS 430 Invidia mid pipe - Very Pleased
- Side view mirror
- engine knock at startup - GS450h 100k miles
- 2006 GS300 Rear Hub Assembly...Alignment?
- GS300 AWD water pump replacement
- PPE Headers & Never ending CEL
- Part identification
- Houston, TX - 2008 Lexus GS 460
- Gs430 limo?
- GS 350 Oil Consumption
- gs 300 rear shade not going all the way up
- Door interior trim removal
- TPMS (Tire Pressure Monitoring System) Schematic and Disable Attempt
- Pass side windows.
- About to Purchase a GS 460
- Front End noise Lexus GS350 AWD solved !!
- 2010 GX350 18" wheels on a 2007 GS350 RWD?
- Grill replacement and weather stripping
- gs350 versus gs460
- 06 GS430 ABS actuator
- Advice. Engine failure at 115,000
- Battery dead? how? (2008 GS AWD)
- Lexus Lawsuit - Transmission-VSC/P2757 Issues
- Popping noise in the rear around the gas
- Anybody know how to tune the engine? like cam shafts?
- Clicking Noise
- Shopping for GS350
- Horrible FM Radio Reception
- My JobDesign GS350
- help replacing daytime running lights
- clunking noise in front suspension
- A few question for the masses..
- 06 GS push button starting issues
- Headlight Issue on 07 GS350
- New GS350 Owner! Could Use Some Tips
- GS 430 or IS F
- Engine noise
- Heated mirror (Glass repair)
- Loud A/C Condenser
- 2010 GS450h C1252/C1256 Codes
- Tire wear rear, AWD
- Vaistech SL3B Install Help
- Will these wheels fit??
- Advice/help request
- Hi all Lexie owner...
- thread closed
- 3gs front brake freeze
- factory 32PSI not enough?
- my "srs" airbag light is on
- abs gs430 2006 problems
- Lexus gs300 2006 over 244k miles
- Trying to source Rhd clip
- My 3GS is losing oil. Why???
- got into an accident, need some advice
- Please solve the TPMS ECU
- Recommended Services 08 GS350 AWD
- Good bye 3rd Gen
- Always wondered about the numbers
- HELP! 02 oxygen sensors
- let me tell you about my saga
- looking for a shop familiar with the 3gs
- Dashboard speakers
- Side Mirrors
- Battery beeping issue?
- Looking for accuair full kit gs460
- New Member, GS430 Questions
- 19 Inch F-sport Tire Size, Need Help !
- Nav DVD wont go back in! Just making clicking noise!
- passenger axle replacement
- Vertex Aero specific
- Power issue...help (gs350, 2007)
- 2006 GS300 Died on Road Changed battery won't start
- '08 GS 350 Overheating Issues
- just got check PCS/VSC/ECS and a ring while driving
- Nav screen stuck on insert
- Just did a headlight restoration
- pic removed in the diy to drop the front bumper
- Anyone guess why the center of my tire went bald after 15k miles? (Pic)
