help replacing daytime running lights
Old Oct 21, 2015 | 02:40 PM
nated0323's Avatar
nated0323
Default help replacing daytime running lights
i have a 2009 gs350. i want to replace the daytime running lights with leds. I bought a set and after i installed them they flickered while the car was running. i figured out that that was most likely happening because the drl are also the high beams.. I'm assume thats whats causing the flickering. i just want to be sure that this is the problem and its not something else. also could someone recommend a good pair of leds that aren't crazy expensive and preferably no ballasts, not sure if this is possible. thanks for the help
Old Oct 21, 2015 | 03:26 PM
ReyRey305's Avatar
ReyRey305
You need to get a decoder if you want to use LED's in your DRL. But then bad part is you will loose your High Beams since the LED's are not as bright as a regular halogen bulbs.
Old Oct 21, 2015 | 03:27 PM
ReyRey305's Avatar
ReyRey305
Here is a guide to install them
http://store.ijdmtoy.com/Lexus-RX350...Beam-a/430.htm
Old Oct 21, 2015 | 03:33 PM
nated0323's Avatar
nated0323
hmm, do i have any other options? i noticed some are single beam and some are dual beam, does that make any difference?
Old Oct 21, 2015 | 03:40 PM
nated0323's Avatar
nated0323
im not going to mess with the decoder thing, id rather just keep my high beams.. so what if I bought an hid kit, would i still have issues due to the drl also being the high beam or are hids able to do both like the stock halogen bulbs?
Old Oct 21, 2015 | 04:00 PM
tcr101's Avatar
tcr101
Not sure if this applies to you. On my 06 gs430, it has a wedge bulb and high beam. To my knowledge (and I may be wrong), the DRL is run off the wedge bulb during the day. When you turn on your headlights (low beams), the high beams will run on half-wattage. As ReyRey suggested, a decoder would stop the flickering, but you will lose your high beam functionality.
HID Powerhouse (a sponsor of this forum) suggested these 3 options:
1) Traditional 6000K LED bulbs with traditional relay unit attached to the bulbs (subtle upgrade - ideal for DRL, high beam output is diminished);
2) CREE XML2 6500K LEDs with built-in resistor and cooling fan (very bright for both DRL and high beam); and
3) Philips Lumileds Luxeon 6000K Crisp White LEDs with built-in resistor circuit (brightest for both DRL and high beam).
Personally, I am currently waiting for the philips lumiled luxeon's to arrive.
Old Oct 21, 2015 | 08:30 PM
rl9010's Avatar
rl9010
Other way around...The wedge bulb is the night "city" light and DRL is the high beam bulb operating at 10-20%.
Function > Form..just my 2 cents
Throwing HID into the high beam reflector bowl is not the best idea. HID needs that brief warm up time eliminating it's usefulness as a high beam replacement.
Old Oct 24, 2015 | 10:21 AM
tcr101's Avatar
tcr101
Weird, I replaced my bulbs last night with:
Philips Ultinon D4S 6200K
LP2 Samsung 2 LED chip bulbs (1 pair)
Samsung LED chips are used for DRLs and the Lumiled Luxeon for high beams are BRIGHT. I do not see any loss of high beam functionality. The highbeams seem to be run when the headlights are turned on.
Just a heads up for anyone trying to match colors, they seem to be a bit off in terms of kelvin. Nothing big, but i can notice the difference.
lyonkster
Apr 19, 2017 07:20 AM
luxe88
Apr 20, 2015 10:49 AM
rcnv
RX - 1st Gen (1999-2003)
Jul 25, 2009 11:11 PM
andyboy
Jul 7, 2008 10:07 PM
Antonugi
Apr 22, 2008 11:59 AM
