Sway bar bushing access cut
Old Jun 15, 2015 | 03:27 PM
Deathrow23's Avatar
Deathrow23
Default Sway bar bushing access cut
Just installed new front sway bar bushings. I noticed that the cut is not the same location as oem. Question is, should I be ok with the way it is? The cut is on the flat part and not the sides like oem.
Old Jun 17, 2015 | 01:06 PM
Gville350's Avatar
Gville350
It's designed that way; you're fine.
Old Sep 15, 2017 | 04:19 PM
MikeFig82's Avatar
MikeFig82
I know this an old thread. Do you remember if the bushing ended up snug on the bar? The IS250 front sway bar is 27.2mm OD. I'm just cross checking for fitment. I will be using these bushings on the F sport AWD 28.5 mm OD. I'm assuming I'll have to ream them out to work with the bar.
Thanks
Old Sep 17, 2017 | 08:12 AM
bazzle01's Avatar
bazzle01
You cant just 'ream" them out. You can purchase the correct sizes.
They can bind and make noise if too tight, loose and they will open under side load.
Old Sep 17, 2017 | 08:50 AM
MikeFig82's Avatar
MikeFig82
I reamed the ones I have now. Went from 24mm to 26.5mm. Very carefully with a dremel tool and sanding bits. Been working fine for about 2 years now. I just didn't want to do it to these new ones on order. I find superpro's the best OEM style. Aftermarket are really thin walled, and require new brackets.
hypervish
RX - 1st Gen (1999-2003)
Nov 22, 2014 09:42 AM
JAB
Oct 30, 2013 07:05 AM
GS714
Jan 24, 2012 03:08 AM
Red Bully
Suspension and Brakes
Sep 7, 2008 12:14 AM
prep2
14
Mar 16, 2005 07:19 AM
