- Noise from left inner fender after hit a road curb - please help!
- Getting close to needing a set of Pirelli P7 AS Plus 3 Tires
- Wrong oil filter!
- Bluetooth echo and noise fix!
- Any tips on reinstalling the Front Diff fill plug?
- Winter tire size? - 2013' GS350 R18
- Lexus 19" Staggered "Full Face" F-SPORT FORGED ALLOY WHEELS
- 2021+ IS use the 4GS chassis? Other notes about 4GS platform also
- Any GS owners previously own an Infiniti Q50?
- 17 inch wheels on 2013 F Sport?
- DRL issue
- hot air coming out of passenger side
- Staggered to square??
- Are there any GS owners who have used RS-R Down springs? I would love your review.
- Mold or Dirt Inside Cluster Lens /Dashboard
- Reading light
- Advise on purchase
- 2014 Lexus GS350 F Sport RWD Duralast Gold Ceramic Brake Pads Brake Squeal SOLVED!
- Camshaft position sensor wiring colors.
- Cherry 2017 available - should I?
- Torsen LSD Compatibility on older GS Models?
- Will a GSF fender fit a 2017 GS350?
- Exhaust Question !! Lexus GS350 2013
- Smaller washer reservoir for fog light install?
- Premium vs ML Specifications - let's settle this!
- Charlotte NC area - spring install
- Gas tank opening “insert”?
- GS350 car seat
- compustar remote sale Edit: ended
- Quick question on 2013-2015 Grom VLINE2 GS350
- Winter Wheel Set - RWD F-Sport Caliper
- 2015 GS: high mileage F-Sport or low mileage premium?
- blower motor seal leaking cold water when AC on
- 2018 lexus gs350 rear door ambient light not working!!
- 13 GS350 F-Sport AWD Tire Size Help on RCF Rims
- Anybody tried the MekedeTech Android system?
- Vote and I'll Buy!
- 4gs possible lsd conversion
- DRL mod for US spec moving to Canada
- Apple CarPlay by Beat-Sonic - Highly Recommended!
- Ripped Driver Seat Repair
- Swap to toyota mirai key $20
- Windshield Wiper Control
- Car battery
- P0411 Error code after intake removal. Evap Issue
- Meet Soo Yung
- What could cause front brakes squeal?
- 225/50/R17 Winter Set
- What oil filter can or should I use for my 2015?
- What's wrong TMPS not working?
- No audio issue. Not the amp.
- Drivers seat
- What is a memory saver?
- Anyone using Hardrace parts?
- Loud and harsh thud when shifting out of manual mode
- Aftermarket TPS don’t work, but low tire sensor does?
- Complete suspension renewal
- Changing PCV valve on a 2017.
- Carpuride W103 Pro Carplay Device
- Remote start 2017 GS350
- Backup Camera not working after battery change
- GSF conversion which splitter?
- Beatsonic phone mirroring + 360 camera system
- Services Due
- Where's the power steering fluid reservoir located?
- Anyone we know?
- Passenger Power Seat Stopped Working
- Perforated leather seat cover repair
- How long do TPMS sensors last in 4GS?
- Carbon Trunk Emblem?
- Easy factory upgrades after the fact?
- DRL working but not the lightbulb
- D3 Performance Tune 2GR-FKS & Florida resident request
- 18" Winter Tires & Rims
- 2015 All Weather floor mats fit a 2019?
- How to remove old mp3 from hdd
- Grom Group Order, 1 Week Starting Sep 7th
- Change From C to F
- Any AWD GS Owners using Lowering Springs?
- Touch up paint
- Replacing water pump
- A/c slowly got worse and then was gone
- Dashboard creak/rattle above clock
- 2018 gs350 Triple Beam Headlight Upgrade Issue
- Downgrade Alert!!! - GS to Camry
- Sport + Mode - Transmission Defaults to Highest Gear
- Only 17,000 miles on Michelin Pilot Sport All Season 4
- Lexus GS350 Fsport awd. AC stopped working?
- New Owner - 2020 F Sport
- Rear differential fluid change
- Mirror tilt motor stuck
- Where do your wipers sit?
- PSA for aftermarket wheel lug nuts
- 2015 GS Fsport is my favorite
- New GS Owner Here - Any Swift Springs Owners?
- AWD front differential fluid Chand help
- Sad day - Looks like a total loss
- Issue with TPMS Sensors
- Reliability?
- 18” Wheel Stains
- Check Engine Light and Eco Monitor showing OFF
- Center console rattle
- Adding some Freon discussion
- Los Angeles stereo install recommendation…
- BC Racing coilovers for an ES?
- Weird noise coming from dash / AC wents
- 2013 GS 450h HID Malfunction
- Strange clunking at idle
- Blown AVS front, left strut?
- Indicator self cancelling prematurely
- Rear driver door tweeter has terrible static when turned up past 45
- Coolant leak 2017 GS 350 AWD 70.000 miles !
- Solution for bottle holder in door?
- How to troubleshoot noise coming from driver side?
- Beatsonic Android Auto review after 1 month.
- Recently changed back rotors and pads
- Android Auto GROM?
- Extended car warranty advice
- Triple Beam headlight performance
- Help!Can somebody tell me what's this
- GS350 Alternator/regulator and brush replacement
- Dashboard Creak
- Auto Lock feature. Want it to auto lock when I leave the vehicle
- Which debadged version do you pick?
- Gs 350 f sport 2018 cold brake squeak.
- Door Panel Wrinkles
- Play DVD while driving ??
- Turning left at full lock-terrible noise
- F Sport Gauge Cluster retrofit
- OEM part number..
- A/C Delay when starting vehicle
- 8AR-FTS Engine Power Limitations
- Noise when shaking tire for bearing inspection (video)
- Rear Subwoofer Cover Trim
- 2015 GS rear "Seat Gap"
- IS coil springs on GS
- Still waiting for any help with the upgrade to triple led
- What this sensor for?
- "Engine Light On and Cruise Control Malfunction After Changing Spark Plug"
- Gs 350 luxury trim
- Speaker replacement '13 GS
- Looking at GS
- Timing belt / chain
- Opinions on current and pre-pandemic pricing for 4th gen GS350
- Question on your exterior side mirrors (gloss black?)
- Anyone switched to LS from GS ?
- How desirable is red interior?
- Airlift 3H management system
- black emblem present. need assistance
- Beat Sonic vs Grom Audio
- New spark plugs. Placebo effect?
- 2015 gs radio won't work, will AC work if radio is removed?
- 2013 aimgain rep front bumper conversion
- Sorry boys, I did it again!
- MPC Remote Start
- Premium versus Regular gas
- Credit Card Smartkey
- Wide Body GS spotted
- Correct Spark Plugs?
- 2016 Luxury: Do I need F Sport or Base Rotors?
- Rain sensing wipers malfunctioning after temporarily pulling out fuse
- 2013 gs350 codes p0171 p0174 and p1170
- AC Compressor not kicking on
- Chrome delete on 15 gs350 “atomic silver”
- Wiring up 4-pin trailer lights to my GS
- TPMS sensor error no idea how to fix
- IS steering wheel fitment PSA
- Front camber adjustment
- Buying a used GS--will parts/repairs be an issue since it's discontinued?
- Emergency Brake
- Sources for Genuine Lexus parts
- Headlight keeps pointing down intermittently
- Time to say GOOD BYE!!
- 2014 GS350 Radio stopped working!!
- Swap in heated seats?
- Service Manuals
- SHe gave me great service for 10 years!
- Headrest pretty hard replaced with IS one
- Difficulty in removing rear shocks
- PCV Valve 2016+
- Squeaky front windows
- Negative battery corrosion and ground wiring help
- Should I Make the Move to Lexus?
- What does this do? 2013 GS350
- Coolant leak / 2016 F Sport / 130K mi
- Need help with radio area backlit
- "Radar Cruise Control Not Available" message -- diagnose issue myself?
- Your thought on aftermarket intake tubes ?
- Is my 8yr old GS350 getting a little too rusty? (PICS inside) I live in a snowy area
- When you go for rust-proofing (Krown), should you let them take off the underpanels?
- Aftermarket 360 camera
- Seat Covers
- Anyone mounted 370z nismo 19” forged wheels on their gs??
- Anyone use the thigh extender in their GS
- Looking to buy my first Lexus
- Replacing Cooling Fans and Shroud Assembly
- 2018gs350
- Discovered leak in shock
- Finally fixed rattle!
- 2013 Trans Surging + Backup Camera - Dim
- Techstream Setting for Recirc
- Rear Differential Seep
- Anyone have a roof rack
- issue with rear right power window
- Should I Rust-proof my GS350? (Living in harsh snowy salty winters)
- Does this mean I have got a bad/cheap tech stream unit?
- 2018 GS350 VIDEO intermittent clicking noise, normal?
- Vibration First 5 Miles ???
- Belt tensioner pulley replacement
- Check Headlight Leveling System, aftermarket Headlight
- 2015 GS 350 - Tried to change battery without reading the forum first...
- New to the Lexus fam! Thanks to everyone who helped me out!
- Lexus GS 350 F Sport Values
- Need help with vent recirculation problem. Bad smell coming in.
- Exhaust system for a noob
- Need help with front bumper sensor issue
- How do I wipe out all the radio presets?
- Is there a trusted brake pad/rotor set available for a good deal?
- Screeching noise from front driver side wheel when making a right turn
- Clicking in the rear, CV Axle?
- Fsport brake kit upgrade on base model?
- Higher Oil Weight
- Time to move on
- 2014 occasional slight shake/pulsing while at idle in drive
- Funny smell after full throttle
- Jumped backward/connect battery backward
- GSF Exhaust -> GS350
- Assymetric Lift Arm pad support points
- My GS won't start?
- Is this CarFax good? There don't seem to be many oil changes done, why is that?
- (Merged threads) Importing an auction GS350 to Bulgaria & related questions
- 18 way driver seat adjustment what does this button do?
- Can I run RR racing carbon intake without tune
- Gsf/rcf lca bushings ..has anyone installed different /offset sizes ?
- My alignment specs.. what do you guys think?
- Wont start! But cranks! No communication! Cluster not working!
- 2014 GS350 gas pedal feels like there is a button underneath it
- LED headlight conversion
- Wheel question.
- Anyone running Advan GT wheels? Need specs :(
- Driver Wheel Fender rubbing with stock wheels/tires
- F Sport Strut Replacement
- Help! Rear Brake Noise
- P0455 and P0441
- 2020 F Sport Black Line Edition
- Fram Fresh Breeze Cabin Filter - Arrow Direction
- Transmission Temperature Ranges
- Factory Service Manuals and looking for advanced repair/maintenance area of forum
- Anyone have excessive wind noise on the driver side??
