Speaker replacement '13 GS
2nd gear
Hi Guys,
One of my front speakers is blown. Looking to replace it and found the OEM ones to be overpriced. Can anyone suggest a replacement. I saw one thread on here for a 2016 GS that used Infinity speakers. I have the base audio system and I only looking to replace the fronts with something as good as OEM which for me was mpore than good enough before my kid blew one of the speakers. Fyi I am in Canada. Wondering if these would be compatible for $120 a pair on Amazon.ca
Infinity Reference 6532EX - EZFit 6-1/2” Shallow Mount Coaxial car Audio Speaker
Hi Guys,
2nd gear
Thanks for all the replies. Can anyone tell me what my car has? are the speakers 6.5" or 6x9? 4 ohm? I don't have the ML system. I still find the sound quite good. I would rather not pull the doors apart twice
A larger ferrite magnet is not superior to the smaller neodymium magnet. Don’t judge a book by its cover.
The non-ml system is 4-ohms, the subwoofer is 2.5 ohms.
I wouldn’t change the speakers first, add a DSP amplifier. That will make the single biggest difference.
Actually, both of these speakers are from Prius. The left one was the OEM Prius speaker (From 2015 Prius II, to be exact) that I replaced with the Pioneer A-Series 6"x9". But regardless, yes, you can use the Prius speakers, but they will sound like they were made out of Kellogg's carton, because they were.
The other option would be, replace all of your door speakers with Infinity Reference series. Thats what I did a couple of years ago. Went with Infinity Reference all around and they sound quite a lot better than the Lexus Premium speakers.
gaki (08-09-23)
I thought the whole audio system ran through the sub on the ML? If you unplugged it, how did you get any sound from the speakers? Not questioning your method, just curious. Thanks.
Honestly, if I had the ML system in my GS, I would not have messed around with it by replacing the speakers with aftermarket.
