Looking at GS
From model years 2013-20 inclusive, the F Sport trims all have digital display.
Meanwhile, the Base and Luxury trims have analog displays.
@peteharvey Correction to the above, the F Sports did not get the digital gauge cluster until model year 2016.
The following 6 users liked this post by JDR76:
abqhudso (08-02-23),
bigblack06 (08-02-23),
GrandSedanFan (08-02-23),
Jakerin (08-03-23),
repugnante (08-02-23),
and 1 others liked this post.
JDR76 (08-02-23)
My apologies.
JDR, was digital optional on the F Sport trim in earlier model years from 2013-15 inclusive?
JDR76 (08-02-23)
RWD, AWD and Hybrid - each use their own coil springs across all trims.
They generally use the same roll bars, except for AWD front.
The 2016 mid life update used firmer front roll bars, and by 2019, firmer rear roll bars were added to the range.
Different years used different coil springs; for RWD models, the 2015 was the stiffest, softest from 2016-18, and intermediate in 2019-20.
The shock absorbers were generally firmest in 2015 model year.
1) AVS automatic electronic variable shock absorbers in Luxury and F Sport trim.
2) F Sport trim uses firmer software to control the AVS electronic shock absorbers.
3) F Sport trim RWD have fat asymmetric staggered rear wheels on ultra low profile tires.
4) F Sport trim often used full blooded sports tires like Bridgestone Pontenza RE050, or Dunlop SP Sport Maxx 050, or Michelin Pilot which have stiffer sidewalls to maximize handling - as opposed to sporting luxury [nee touring] tires like Pirelli Cinturato P7's which have softer sidewalls for a smoother and quieter ride.
5) The F Sport trim may have a rear wheel steering which may affect the ride?
Hope that helps...
4th Gear
F Sport is generally stiffer for the following reasons.
Hope that helps...
Hope that helps...
Thanks for your help.
There wasn’t an optional digital cluster on the 13-15 models. All GSs of that era had the same analog cluster. For the 16 refresh, the regular, premium, and luxury trim models got a new analog cluster, and the F Sport got the new digital one.
The following 2 users liked this post by JDR76:
Coolchuck (08-04-23),
peteharvey (08-02-23)
4th Gear
Thanks for any advice - much appreciated.
You don't want the base, base model unless you don't even want a NAV system. Some base models don't have heated seats, rear shade, parking alert, rain sensitive wipers, etc., etc. You want at the very least the Premium model.
