DRL issue
Old Oct 16, 2023 | 02:00 PM
laz2300's Avatar
laz2300
2nd gear
Default DRL issue
Hi guys I'm new had a question about a 2016 Lexus GS350 F Sport that I have the passenger daylight running light is not worked I want to know is there a place that I can send the headlight unit you to restore it or do I have to buy a brand new unit if anyone have any other options upgrade please let me know thanks
Old Oct 17, 2023 | 01:23 PM
AJLex19's Avatar
AJLex19
@laz2300 the two primary possibilities are the right/passenger headlamp ECU has a problem or the actual DRL is broken within the assembly itself. I would take it to the dealer or your preferred mechanic and have the problem diagnosed. A new headlamp will be expensive if it turns out to be a physical issue with the DRL. The ECU will be cheaper than the headlamp but I wouldn't recommend replacing such expensive parts without a diagnosis first.
Old Oct 18, 2023 | 04:04 AM
laz2300's Avatar
laz2300
2nd gear
thank you I appreciate the advice and will take the vehicle to get looked at by my local mechanic or worst case go to the Lexus dealership
apwall
GX - 2nd Gen (2010-2023)
Feb 28, 2023 05:58 AM
DrWikins
Dec 4, 2022 07:15 PM
lexusg1
Apr 22, 2022 11:03 PM
RV14
Apr 17, 2016 09:15 PM
GSman
Jun 26, 2001 07:54 PM
