Drivers seat
Old Sep 22, 2023 | 02:20 PM
Stevenm8's Avatar
Stevenm8
2nd gear
Default Drivers seat
Any tips on removing the drivers seat or how to remove the back panel of the seat? 2013 Gs 350
Old Sep 22, 2023 | 04:58 PM
SebastianD's Avatar
SebastianD
Yup! Drivers seat has your standard 4 bolts around the seat that hold it down. Then wiring underneath. Needed to remove for 02 sensor replacement.
The back part if I remember correctly has 4 screws or so on the bottom that you remove, then a plastic retainer, and the whole thing slides downwards. Took mine off because they rattled, and installed felt tape.
Old Sep 22, 2023 | 05:05 PM
Stevenm8's Avatar
Stevenm8
2nd gear
Default Seat removal
Ok great thanks, i have a problem with the side panel adjustment the motor or gears are making horrible grinding noise its programmed so it happens on entry and exit only way to stop it at the moment is to push the set button
what option would be the best removal of the seat or back panel?
Old Sep 22, 2023 | 06:59 PM
EAST's Avatar
EAST
It looks like there's two "rubber bands" under the seat. One is held on by a clip. Then there is an additional clip that should be removed.
At he back, there's two screws at the bottom. Then it's just mentioned to push and slide downward to disengage clips.
CJS57
ES - 7th Gen (2019-2025)
May 28, 2023 11:50 AM
jdmjedi
Jul 15, 2019 02:46 PM
ccnash4
NX - 1st Gen (2015-2021)
Jul 5, 2019 05:29 PM
odaymax
Sep 13, 2017 09:42 AM
