- Help! Christmas Tree lights on dashboard + key fob / central locking out
- Rate my Rust :) Is this worth buying?
- Help Diagnosing P0156 / P0158 Then Later P0051
- Dropped AC port cap...
- Air-Fuel Sensor
- 05 KDSS lean
- Rear Wiper stuck....
- 08 Problem with Gas Gauge
- 03 Lexus GX 470 Nav/Audio not working
- Non-Mark Levinson amplifer not working - Pioneer 86280-60291 Amplifier
- Strutmasters conversion and other adjustments
- 06 GX470 A/C codes
- warning lights VSC, ABS and Emergency Brake on
- 2007 GX470 randomly not starting.
- Shaking at idle (in gear) with foot off brake
- '04 GX470 Batt. replacement shenanigans
- Window Control Bezel
- Mechanic Sevierville, TN
- Radiator Pressure Test
- What does this part do?
- Gas Prices
- Car Covers
- Hewitt Tech Bypass Experience
- Please support 3DCarStickers
- Transfer Case Actuator
- GX470 Differential lift
- 2005 gx470 with ML Nav & RSE strange wire harness?
- Do I have a vvt-i engine?
- Rear brake caliper torque values
- Rear Door Won’t Open
- Rear Recovery Point Suggestions for a 2006 GX470
- 2008 GX470 towing assistance needed
- Change tires for a lift
- adjustable struts questions
- Volume Know not Working
- 2004 GX 470 Transfer case lights ( L N H ) indicator lights are all green
- Window Switch Lights
- Acceleration studder
- Transmission Lab results
- CD Changer Cubby
- GX 470 Facelift Idea Suggestion
- GX 470 Side Mirror Issue
- Chasing a heat problem - Passenger side cold
- Windshield washer not working properly
- 2003 Lexus GX470 - Power steering hoses
- All for sale threads belong in the marketplace classifieds only
- Satellite Radio Screen Issues
- Low AC Freon?
- Help Diagnose this Noise
- Wheel options
- Wheel options
- Weathertech Sunroof Visor
- Need your advice! First time buying a 2006 Lexus GX 470
- Oil Accumulator
- Mini Fuse seat fix
- Junction Connector Locations??
- How Many Miles Can A Gx470 Go?
- Interior Control/Button Removal
- 2008 gx470 just stopped running
- Replacing Drivers Seat Bottom - Instructions?
- 2005 GX470 buying tips.
- Rear door switch / alignment
- Audio Issues After Alternator Repair
- Matt rescues another GX
- 2003 GX470 Radio/Nav Unit Mess
- 2004 GX470 replacement GPS,Radio etc
- Buying
- Oil Filter base hoses
- Front suspension refresh
- Audio issues
- Climate Fan Speed Control Not Responsive
- VSC off TRAC light
- Larger wheels/tires
- Purchasing 2004 GX
- Front Marker Light
- 2006 GX470 Windshield Washer
- Rear Coil Conversion
- Interior Trim garnish panels
- Want to use the running board light harnesses for rocklights...
- Replacing Exhaust manifold and Converter
- GX470 Fuel Pump
- ML speakers- repair or replace
- Street Rays Lift Spacers
- Transfer case oil
- Crazy GX car pricing
- Justin
- New Front Springs
- Transfer Case Actuator Replacement Flashing Diff Light
- High fuel pressure?
- Where is the vent valve?
- Where’s the vent valve
- 06 GX 470 Rear lowering but no leak??
- Tail light out, but turns on when braking
- looking for 1st hand experience in sand
- Asia GX470 Treasure Hunt
- 03 GX larger tire sizes without issues
- Carbon Fiber Trim
- Any stolen catalytic converters?
- Overheated Engine Swap Koyorad Radiator I have ???s
- 2006 GX470 - AV Amp
- Running board clips
- Question: Suspension Upgrade / Airbag Delete Advice for KDSS Model ?
- Brakes Pulling right when applied.
- 2004 gx470 feels different lately
- Rear door cladding removal
- 2008 GX470 Navigation Update
- Fog Bulbs, Weirdest Thing
- 2005 gx470 tranny issues
- 2007 GX470 Error Codes P0430 and P0420
- Project car, 05 GX470, 141,144 miles
- 2005 GX470 Default Home Screen Question
- LED fog lights recommendation
- Fob Issues
- Check out my drawers!
- P0451 Code
- 2004 gx470 nav unit, mark levinson need to add camera and BT. HELP
- 06' GX470 speakers pop a second when turning the key and then no sound any more
- Well Looky Here, #1
- 2006 Airbag Issues
- P0418 / P2445 codes
- Horn and starting issues
- shop recommendation near New Bedford, MA
- Rusty frame
- gx470 2005 no start no check engine light no connection to ECU
- 2006 Suspension Issues
- ABS Issues - Complete Replacement?
- Front “bearing poop” photos
- front shock subs for 05 gx
- Front coils backwards - does it matter?
- Help- GX470 Died While Driving on Highway!
- Shop Recommendation near Annapolis, MD
- Brake Accumulator only Removal
- Blacked out Headlights
- Codes Suddenly Came on- don't trust diagnostic 2008 Lexus GX 60k miles
- OKADVENTURES GX470 Build
- Moonroof Stuck open Solution
- Suspension issues
- Lights staying on after locking vehicle
- Secondary air pump question
- 2007 GX470 Mark Levinson and Nav questions. Any help is greatly appreciated!
- Exterior LED Question
- OBDII scanner/diagnostic tools '05 gx470
- Fuse keeps blowing in 2004 GX470 (#22 7.5amp)
- Is there a way to enable a "dog mode" (A/C on, doors locked) in a 2006 GX?
- Request - picture of tow hitch
- Door lock question
- HID Upgrade Kits
- Washer Fluid Sensor Stuck
- Outside mirrors won't move horizontally
- Japanese Export Nav Update
- silver 2004 looking for parts.
- 04 GX 470 Rust
- New rubber!
- 07 GX470 making noise on hard right turn
- Looking at a 2004 GX470 need advice
- Wiper Control Failing?
- Bilstein 5100 install
- Driveshaft
- New To Me 2008
- 2007 gx470 issues
- Brushed too hard and scuffed body
- Front end conversion
- GS Owner Looking to Add a GX
- I need some braking wisdom please gentleman
- Oil in the Intake
- How does one get the door latch assembly out of the back passenger doors?
- Reset calendar
- The Car Wizard looks over a 2008 GX470
- GX 470 2003-2009 Height Control Air Dryer 4895060020
- Exhaust Manifold Leak
- My 2006 GX 470
- Glove compartment damper cord
- Please ID this Wire
- Fresh vinyl interior wrap and new head unit
- Teardown of a non-VVT-i 2UZ-FE
- Homemade rear drawer project
- P0353 with multiple other misfires
- Only high range speakers work. Rear door speaker wiring
- New Tires Opinion
- CV Axle Warning
- What is up with these brakes!!!
- Coolant leak at throttle body
- MY gx470 has GX460 rims
- Anyone have ride quality experience with arnott rear air springs?
- HVAC servos: blender/damper issues
- Instrument Panel Lights On - What Systems Don't Work
- Replaced both air springs and the ride is bumpier now?
- Long-Term Storage - Recommendations
- VIN decoder accuracy?
- New here !
- Blown Amp
- Metal tech hitch - will the stock knock out cooperate with it?
- Snap Ring Position For Bilstein 5100’s
- Rear air bad delete but ordered wrong springs
- Changed plugs-now THIS on dash!
- Ashtray receptacle cover won’t close
- New to me 2006 GX470
- Sharing a summer vaca experience
- Another new GX470 Owner
- Would you drive cross-country in your GX?
- Mysterious ML Tweeter Crackle
- Engine sound
- oil change every 10k?
- If I decide to sell what should I ask?
- Check Air Conditioning System not connected error
- Loose front wheel hub dust covers
- Heated Seat Stuck "On"
- Road trip checklist and tips
- 4runner frame recall
- 2006 gx470 wont shift out of park, abs, vsc lights on
- Hello I’m the new guy.
- Welliswan
- Buying advice
- Front Lower Ball Joints
- 2004 GX470 Nav screen blank, no sound on audio, entertainment screen no power
- Pesky parasitic drain - OBD
- Rear Air Bags
- Gas mileage on highway
- GX 470 door hardware
- Removing Engine Sludge
- KDSS Nightmare
- OEM or Used
- Subwoofer & Rust
- Opinions on Air Spring Compressor replacement
- 08 GX470 with airbag issues
- Air bag issue
- 2004 GX470 low beam and interior light won’t work.
- Part numbers
- Weird chainsaw buzz sound
- Which replacement headlights?
- Screw for drivers seat front molding
- Roadtrip disaster: Pink spray in engine, can’t shift
- Terrible Gas Mileage
- Advice on center console entertainment/dash cover
- GX470 lift 2" vs 3"
- Turn signal issue! Help!
- 03 gx470 center diff won't engage
- Lexus OEM bike rack - $32?
- RA Closeout Parts
- Salvage rebuild??
- Any products out there to preserve a non replaced dash?
- Should i be concerned? (2004 Gx470 differential issues)
- Issue with Vibration/Whirring Sound Similar to Wheel Bearing
- Water permeation in the back of my 2005 GX470
- GX470 valuations
- Help identify wiring in the engine.
- 2006 front diff leaking gear oil on drivers side
- Driveshaft splines and U joints grease
- Battery Light Still On
- BURNT OUT GX 470 Left Front Turn signal plug, running light housing pigtail
