Driveshaft splines and U joints grease
I did a few searches and can't find the info again but I recall reading somewhere that the Driveshaft splines (yoke?) and the four U joints on the shaft need different types of grease to keep them happy.
Anyone have the info on that?
Also I remember reading to not pump too much grease into the splines/yoke or you will put a tremendous amount of pressure on your transfer case and potentially crack it over time since the grease will act as a hydraulic press. Is it 5 or so pumps?
Well I found this thread for the 2nd gen GX and thinking this is probably the same for us..... maybe...
https://www.clublexus.com/forums/gx-...de-yoke-2.html
Use moly on the slides about 5-7 pumps if regularly serviced. If it’s been neglected you may have to pump a lot more. Use lithium such as Red & Tacky on the spiders until you hear cracking and new grease begin to ooze out.
Ok, all done. 6 zerks exercised and put moly in the splines (10 pumps each) and red & tacky into the spiders (till they oozed out of the seals). It had been several years since I lubed them but everything looked good still.
Are there any other zerk lube points in the suspension which need some love?
GreggyG
GX - 1st Gen (2003-2009)
Oct 21, 2016 08:29 PM
