- Phase 1
- Does our car come with a lift?
- Weird whine and clunk then loss of about 1/2 of power
- How can I tell if a GX has the KDSS option?
- How to tell if GX has KDSS option
- Gx470 Brakes issue
- Lexus Extended Warranty Prices
- My 1st New Year Project for my wife's GX...
- New GX Owner-upgraded from a 4Runner
- GX newbie questions, please bear with me
- adding an amplifier for sub question...
- GX 470 headlight replacement
- My auto lights do not work.
- My Darth Vader GX (farewell, chrome)
- 100,000 mile GX still super reliable?
- Considering used GX with 100k miles
- Reputable 3rd party Lexus shop in Phoenix area
- Stereo with iPod, nav, camera...
- 05 gx470 NAVI gets lost no GPS on display
- Pictures of my new 2009 GX
- Sound and navi work on my GX - thoughts?
- Black Birds Eye Maple trim
- reset TPMS
- Remounting OEM Exhaust Tip
- GX470 Headrests (FREE)
- A/C light blinking code 24
- Would you buy this 07?
- Starting question
- Are bigger OEM of aftermarket stabilizer bars available?
- Buying a high milage 09 vs. lower mileage 06/07
- Need your advice: get 90k mile service or save $1000?
- 2008 GX-470 Might be Mine
- Rear Heat
- Has anyone ever pulled the rear air suspension fuse to keep it in low?
- New to Forum with a 2006 GX470
- Am I crazy to own 2 Gx470's??
- Trade the GX for a 4Runner?
- What is this on 06 GX
- How can I improve my handling???
- ECU-B Fuse blows
- More Leg Room needed
- Vaistech iPod integration - where'd you run your cables?
- Remote key quit working again!!!!
- New to GX need advice on prices
- 2005 GX 470 Mileage?
- Post a pic of your GX 470
- Replacing navigation screen
- So I'm going on my first club sponsored trail ride and need preperation help!
- Replacing Mark Levinson 6X9 door speakers with 6.5" home audio speakers
- Poor Gas Mileage
- Traded the MDX for a GX and very happy!
- 2003 GX 470 hitch receiver
- Tire pressure Light!!!!
- Where is the Bump Stop?
- New to me 2008 GX470
- Squeak problem-solved
- 2003 GX470 wont shift into reverse
- No audio
- Lexus GX470 H3 HID Kit Installation DIY
- Love the Zaino!
- Smoke Smell
- Anyone else ever have an issue with VAIS customer service?
- DDM HID or HIDeXtra HID
- Husky Floor Liners
- Air Suspension to Standard Conversion?
- 2003 GX470 Odometer Calibration
- Center counsel cup holder missing part ?
- P0174 Fix?
- Sunroof Rattle from body flex??
- Running board clips
- RH Headlamp and Fog lamp confused
- New owner of 2008 GX 470
- Has anyone get the new switchable key?
- Purchasing a 2005
- My Dashboard is Cracking
- calipers replaced at dealer two days ago look rusty...why?
- Need advisor for rim & tire changing. [22"] [20"] Size matters!!
- Gasoline grade
- 2 tires or 4
- Amber bulbs needed for '07+ Sport tail lights?
- Is this a good deal?
- getting 12mpg.. WTF?
- No Sound from Radio 04' GX470
- Fresh fluids question
- Flickering temperature LCD display
- Wife's GX09 with KDSS
- Rear tire wear
- DTCs for "Large" Emission System Leak
- Just back from dealer! Please help, Experts?
- 4WD newbie question
- Intermittment humming noise
- Transmission problem(?)
- BFG tire options for stock GX
- Where do you guys go to buy OEM parts?
- Will these 18" 4Runner Limited wheels fit my GX?
- 3" front lift and 2" rear lift like the 4Runner?
- New owner
- Navigation screen issues
- Timing Belt Kit
- I need your help with arm brake
- I need a painted 3rd brake light cover...
- How do I know which bearing is bad
- What did you do to your GX TODAY?
- Grind when putting in 4wd mode
- Instructions for Map Update (2006 GX470)
- Battery problems
- Dome light / Garage Door Opener Short
- 03-04 vs. 05-07 Model Years
- Old/New GX470
- hit from behind, can someone help me find a part?
- Height control - what's the point?
- Transmission 2004
- Catalyst DTCs P420/P430 w/ VSC issues too
- Auto Door Unlock
- loose fog lights
- GX Left side passenger door issue
- Voice Command for Heat on GX-08
- 05 Alternator Diagnosis
- 2009 GX Buyout
- Snow tires and wheels, should I bother with TPMS sensors?
- Please help! New clunk, new place.
- leak coming from under car, HELP!
- Convert 2005 GX 470 to Push-button Start?
- GX jack tools part# needed
- New 2006 GX470 owner- only 12v up front?
- blinkers
- Super Low Miles
- Full Stereo Upgrade-OEM Parts available
- Tweeter Rattle Problem/Door Panel Removal How to with pics
- Maintenance light problem
- Parking Brake wire on 2005 GX470
- new shoes - t4r 18's Nitto Crossteks
- KDSS vehicle on Ebay 10/23
- New guy.
- Just wanted to say Hello and Thanks
- GX470 speaker replacement/sizes
- TPMS Sensor what to do?
- tires
- Water Stains Rremoval on Windshield
- Gas cap tether
- GX 470 Stereo Upgrade Options, Non-NAV
- Aux Input
- Buying a GX470
- Xenon Home Depot HID failure <24 hrs!?!
- Yet other reason to change your own oil
- Tire sensor
- Advice for Possible buyer/BT Pairing?
- Is Excessive Rust on the GX 470 Undercarriage/Suspen./Brakes a sign of problems?
- low tire pressure sensor
- Early Season :(
- double wide armrests modification from jjproducts
- VAIS SLI2up install?
- H3 HID foglight help
- diff/transfer/tranny fluids, propeller shaft, etc, etc
- New TSB?
- Help Please!!! VSC, VSC Trac, Check Engine Lights On
- Air suspension replacement question
- 2011 4runner SR5 wheels?
- Pirelli Scorpion ATR tires any good?
- Service manual
- Please helpp!!
- Please help
- Uh ohh
- New member, new GX
- 17" Tacoma Wheels on GX470??
- GX Rear Cup Holder
- 2007 GX470 70K, Price Question
- Dealer oil changes - going to do it myself now
- Wierd 110 volt outlet question
- Help with RSES / rear seat entertainment system
- Passenger Seat Vibration
- advice on buying a 2004 Gx470
- 2005 gx470
- KDSS worth it?
- When did KDSS start?
- Fair price for a 2007?
- When did bluetooth start?
- Xenon bulb 6,000K or 4,300K
- I need Help! Anbody near QUEEN CREEK/GILBERT (Phoenix) AZ?
- OK what gives? (Fuel economy)
- VSC/Trac off lights came on???
- POLL: Ride Quality of GX
- Steering noise??
- 04 GX Engine Filter replacement
- Turn rotors on 2005 GX
- Service Indicator Light - which service is due?
- anyone good at photoshop?
- CV Boot Replacement or Repair
- Cold air intake for 2009 gx470? will 2006-2009 4runner intake fit?
- Sat Radio Activation Question
- Disable Bluetooth?
- Years to stay away from/cost of repairs?
- New GX Owner
- OEM "Pintle" Hitch Questions
- Please help, weird clicking noise near the key / AC area, video inside
- ? about extended warranty and Battery
- Buzzing noise behind glovebox at start up
- cd won't load
- iCarKit for iPod using the tape deck input
- Removing Instrument Cluster
- Prado Tail Light Swap question
- Brakes Squeaking
- Squeaky suspension 2005
- ? where to purchase some skid plate bolts
- cold air intake
- Tires Sensor battery life
- Warning Lights On
- surging transmission
- Warranty is ending soon
- Front Doors will not Lock
- Deterrent Theft System
- front cup holder, does it adjust?
- Replacement Headphones - Which will work?
- Wind noise
- Need Help ASAP lights and check engine on???
- Window is not working----HHHHHelp !
- DIY, Bank 2 Sen 1 O2 sensor replaced
- New 03 GX470 - Headunit Question
- tinted windshield
- Best place to buy OEM shocks
- Maint Req. light-can it be changed for Synthetic?
- 1st Towing Experience
- suspension issue
- 2004 GX470 Bluetooth/Iphone Aftermarket Products - Is there one that works?
- Replace key w/ flip key ( from ebay ), can't start the engine :(
- GX470 door lock actuator motor repair
- where is the connection to the power amplifier?
- Largest tire size on stock GX suspension
- Rear suspension not airing up
- Considering used GX purchase; help
- How to install factory roof racks 04 GX470
- Any Lexus-specific salvage yards?
- New 05 GX470 owner - mild off road pics
- 03 GX470 new owner with questions on common problems
- GX 470 Trasnsfer case issues
- Tires Cuping After 5000 Miles
- Good Deal on a 2006 GX470?
- DVD Override/ Nav 08
- Fairwell Lexus Forums
- Front shocks???
- 1st day with 08, suspension question
- Substitute for Trailer Wiring Harness 82169-60050?
- coolant leaked all over engine...
- NEW clunk please help
- 2005 Gx470 Buying Advice
- How much should I offer for 2008 GX
- TRD Performance Brake Components
- 2004 GX470 Questions-Voice Command and Brakes
- Reputable HID bulb failing after three hours of burn time?
- went offroading today...just hope my GX is fine!
