- Grinding noise from rear while in gear and not moving...
- Broken driver and passenger dash wood trim
- GX470 Steering Noise First Thing In The Morning
- Gx 470 Need more legroom
- 04 GX steering wheel stiff intermittently
- Just checked service records for my new GX470
- Axially twisted rear axle?
- Just replaced rear shocks, rear airbags and height sensors
- Front strut removal
- Suspension Swap
- Keep my '08 or a get 460 ??
- 08 GX470 Stalled while driving, Now cranks no Start.
- List of TSB's
- factory hitch hardware
- Coil Spring Conversion...Please make this simple for me
- Is this Rust repair too bad to buy?
- Atf jws3324
- 2006 GX470 Coil spring UN-conversion
- Stuck sunroof
- break upgrade gx470 to gx460?
- Mystery plug and clips
- Bilstein front shocks
- ICON Suspension
- GX-470(2004) There is contnous noise on startting the SUV
- Speakers
- Amp missing
- Potential Purchase: 2004 Lexus GX470
- Spare tire wheels
- 2008 GX rear suspension leaning issue...
- 17" TRD Pro Wheels - Tire Compatability
- Gold 09 150k miles or Black 08 130k miles?
- Bump stops
- GX470 Wonky Radio (delayed turn on)
- New owner -GX —1st GEN(2004)
- Fail to boot head unit
- New (excited!!) 2006 GX owner!!
- In search of 2008 GX470 Engine Cover
- 20's on Gx470
- 20's on Gx470
- Ignition key does not match door key-can that be fixed?
- 07 with 18&k miles. Good buy?
- 04 Gx 470 uncomfortable ride
- Sell my GX470 or Repair It?!?
- Cracked dashboard just to be expected
- 2008 GX470 ML Audio distortion.
- It's Finally wheel time !
- Backup Sensors on an 05 GX
- Where is my bank 1 sensor 1 located? (P0031 code)
- GX470: Front Shock? Quick Strut Assembly?
- Air conditioner driver side not working right
- Mount front plate on 2009 GX470
- Alternator replacement with KDSS
- Saddle Blanket Seat Covers for 08 GX?
- 03 GX 4x4 ques???
- 503k mile - GX 470
- Bouncy ride
- Newbie here, what part is this (chewed wire near brake pump?) ?
- Non ML Front Door Speaker replacement - poll/thoughts?
- steering rack bushings how many are there?
- driveline shop Phoenix
- blown head gasket
- Air Spring normal
- OBD performance chip plug ins
- A different kind of clunk. What is it?
- Head unit won't power up
- Fog Lamps no Turn On
- Lexus GX470 Transfer Case
- Crashed 2004 GX 470. State Farm wants to total it
- driveshaft vibation in seats at hiway speeds
- Rocky Road Sliders?
- Rear Power Outlet
- after replacing rack and pinion steering seems harder to turn
- New 2008 GX owner! Previous FJ owner.
- How widespread is this “Brake Failure” issue and did Lexus do anything about it?
- Gauge Cluster Lens Replacement
- Key fob won't lock while headlight are on
- GX470 rear door shock/strut conversion
- Android touchscreen update
- New and Proud owner of a GX 470
- cracking noise - help diagnosing (vid)
- How to reset/initialize the ABS computer. Rotated front driveline. Lights on now
- Rear suspension squeaks
- GX470 passenger heat problems
- Code p0057 o2 sensors
- Brand new to Lexus GX 470
- Recently purchased Lexus 07 GX 470
- Rust on Lexus GX470 2003
- Major Water Leak in Trunk/Cargo? Replacement Carpet?
- Rear suspension tilt
- Replacement headlights
- Third Lexus
- Trouble starting - NEW battery
- AC short cycling at idle
- Front Bumper Template
- Might be the new owner of a 2008 GX tomorrow
- Rear door Strut Conversion
- New GX470 Owner - Always coming back to Lexus
- Rear Air Bags
- Power Steering Warning
- Tires that perform well in snow
- Lexus GX470 died while driving, now it won’t even crank..
- 2003 Lexus GX470 No audio (replaced amp)
- 2006 gx470
- Non Mark Levinson AMP/Radio issues - ANYONE ELSE DEAL WITH THIS!??
- Navigation version for gen 5 radio
- Rough engine when stopped
- Heat coming from passenger floor vent
- Lexus rear hatch emblem (chrome and black)
- Need to replace rear entertainment - video monitor
- 2004 GX470 lost control
- 2003 GX470 transmission fluid change
- GX470 Remote Start NEW question.
- Bumper Plugs (Ash Blue Mica)
- Replaced rusted axle vent
- This is a strange one
- Converting rear suspension - seeking isolator data
- Blown engine?
- Finished my "not drawers" cargo solution that mounts to the 3rd row mounting points
- CEL + VSC + TRAC + Skid
- Help
- p1442
- New to me GX470
- PAINT PEELING on 2007
- 2006 gx470 AC and idle problem!!
- 3rd row seat
- (HELP) 2006 gx47 AC and idle???
- 4 Runner TRD off road rims added!
- Control Arms: Worn bushings/ball joint causing movement, shop wants to replace both
- Rear climate control stays lit up even when off
- Wow first oil change!
- New radiator issue?
- 2nd Row seats cant stay up. back rest if loose and falls back
- Glove Box Light
- Sorry prohibited topic
- 2006 GX air springs - not calibrated
- 2006 GX470 Back-up Camara
- Painted Gx
- Searching for roof rack end caps
- Considering buying. HELP
- Floor Mats
- re purpose air system, after bag delete ?
- audiovox avx1b4s - Replacement Fob
- Uneven Ride Height
- VSC traction OFF light
- Rock Slider advice (bolt on)
- Loose steering and vibrations after installing a lift/coil conversion
- Coolant fully drained?
- All warning lights on when accelerating
- DTC B1269 - No communication from theft deterrent ECU for more than 10 seconds
- Awesome GX for sale
- Head Unit
- Stuck spare tire carrier
- Vsc trac, vsc off, check engine lights
- Heater help
- Thoughts on my new suspension?!?! NEED YOUR OPINIONS!
- Help me find an oil leak
- Inner CV axle torn driver side
- Air line repair for ride height adjustment
- Running board lights
- How do you get to the bottom bolt on passenger side of valve cover?
- No interior heat, Changed some Relays Same with AC
- Question about AC compressor noise and draw on engine
- Torn outer CV boot
- 2008 GX470 Rear Bounce, Height doesn't change when compressor runs
- 2005 GX 470 Rear Shock issues
- luftmeister shocks
- Tires toe in after 2 inch lift.
- Does a 4runner v8 cat back fit a GX
- CEL code: p0172
- Front wheel vibration
- Any have experience with a refurbished ABS pump?
- Noise from dashboard
- Interior/running board LED recommendation
- 1st Gen???
- Lugnuts for TRD Pro wheels
- Headlight Upgrade Advise - 2006 GX47”
- Gear in N or R Still moving forward
- Suspension Recommendation
- Part No. help needed for running board
- Screen upgrade
- Fender liner/splash guards
- GX gets stuck in soft sand
- Service manual
- Should I buy or run?
- No words
- Auto lock question 2009 GX 470
- How do I replace the side mirror?
- New Horns
- Passenger Speakers
- Master cylinder/braking issues
- Both front door shut way to easily!
- How can a GX460 steering wheel be fitted to a GX470?
- Reality check and a few questions about the 1st gen GX 470
- AC Compressor
- 2015 Lexus GX460 front struts
- Fuel filling issue Solved
- Aftermarket side mirrors
- Front springs
- Recommended UCA with a lift
- Oil Change Interval?
- HELP! Need part numbers for knock sensors and harness
- New Owner
- Wheel Bearing repair cost. Am I missing something?
- Driver window control
- Change the start up option on entertainment screen
- transmission change fluid or not?
- Transmission Oil Pan torque values
- airbag light on
- Trouble with my nav screen, display manual controls, and radio in my GX
- Anyone tried these seat covers? (Searched but didn't see much)
- LED H3 Bulb Question
- Under Part 3rd Party ?
- Where is this water coming from?
- Muffler comparison
- caliper replacement question
- Shop re-checking their work - list of what to ask them to look at specifically?!?
- Radiator
- CV Axle
- Has anyone installed a tablet style head unit?
- Throttle Body Coolant Leak?
- Airbag Height adjustment
- 2009 - GX470 ,- 2021 Stock Toyota wheels - Stock Wheel Specs
- Exhaust manifold
- Zero Point Calibration
- BT firmware?
- Front diff needle bearing / bushing
- Brake Light Not Working
- Paint, CV Axle, ML Speaker Replacement
- Can you clue me in here.....
- Help! Undercarriage rust opinions
- Bluetooth and Google Maps
- AT Oil Temp light came on while driving in the mountains
- Would you buy this?
- Need 4 roof corner pieces in green 2007
- 2003 GX470 Passenger Window Not Working From Master Switch
- Bluetooth upgrade
- CAM sensor help
- another shocks question (bypass shock, no conversion)
- Cigarette Lighter Power
- Lexus 2007 GX470
- Alignment not done right or ball joints worn?
- Need help diagnosing buzz/noise
- Gx 470 no start no connection to computer
- Just another 'new to me' thread
- Lower Control Arm Replacement
- 2004 Nav adapter with Bluetooth and Sirius XM
- Oil pressure light stays on ?
- GX470 Struts
