- New Horns
- Passenger Speakers
- Master cylinder/braking issues
- Both front door shut way to easily!
- How can a GX460 steering wheel be fitted to a GX470?
- Reality check and a few questions about the 1st gen GX 470
- AC Compressor
- 2015 Lexus GX460 front struts
- Fuel filling issue Solved
- Aftermarket side mirrors
- Front springs
- Recommended UCA with a lift
- Oil Change Interval?
- HELP! Need part numbers for knock sensors and harness
- New Owner
- Wheel Bearing repair cost. Am I missing something?
- Driver window control
- Change the start up option on entertainment screen
- transmission change fluid or not?
- Transmission Oil Pan torque values
- airbag light on
- Trouble with my nav screen, display manual controls, and radio in my GX
- Anyone tried these seat covers? (Searched but didn't see much)
- LED H3 Bulb Question
- Under Part 3rd Party ?
- Where is this water coming from?
- Muffler comparison
- caliper replacement question
- Shop re-checking their work - list of what to ask them to look at specifically?!?
- Radiator
- CV Axle
- Has anyone installed a tablet style head unit?
- Throttle Body Coolant Leak?
- Airbag Height adjustment
- 2009 - GX470 ,- 2021 Stock Toyota wheels - Stock Wheel Specs
- Exhaust manifold
- Zero Point Calibration
- BT firmware?
- Front diff needle bearing / bushing
- Brake Light Not Working
- Paint, CV Axle, ML Speaker Replacement
- Can you clue me in here.....
- Help! Undercarriage rust opinions
- Bluetooth and Google Maps
- AT Oil Temp light came on while driving in the mountains
- Would you buy this?
- Need 4 roof corner pieces in green 2007
- 2003 GX470 Passenger Window Not Working From Master Switch
- Bluetooth upgrade
- CAM sensor help
- another shocks question (bypass shock, no conversion)
- Cigarette Lighter Power
- Lexus 2007 GX470
- Alignment not done right or ball joints worn?
- Need help diagnosing buzz/noise
- Gx 470 no start no connection to computer
- Just another 'new to me' thread
- Lower Control Arm Replacement
- 2004 Nav adapter with Bluetooth and Sirius XM
- Oil pressure light stays on ?
- GX470 Struts
- 1st 2nd 3rd Gen GX's
- 3rd Brake Light issue (Solved)
- Suspension conversion kit
- strange noise - at low speed acceleration ONLY
- Coil Conversion or hold on to airbags?
- Steering rack question - garage said it was 'weeping'
- What clip is this?
- Fuel Pump
- New (old) Member
- PCV Catch Can
- Looking for pristine GX470 2005-09 WITH NAV.
- 311,000 miles on my still working original alternator!
- That tricky C/OPN Relay
- 2008 Drivers vent bezel
- Grounding the valve covers
- J2534 Interface
- Help buying gx out of state
- Upgrading stock Nav and Stereo options 2020 edition
- GX470 overlander review
- Need picture of a 470 and 460 with the front bumper off
- Anyone have input on Levinson amp model number interoperability? My 0W141 is dead...
- No Start After Injectors
- Rear suspension
- Entering service history on Lexus.com
- Front shocks
- What they hay, intake oil !
- 2006 Lexus GX 470 Engine noise
- Ground, or Grounded?
- Just purchased GX470 - Needed suspension recommendation
- Possible transfer case oi leak
- Front Suspension Question?
- 2006 GX470 Skid Plate (?)
- Help me decide.
- Sounds like ....
- Oil changes in the time of Covid
- Radiator question
- TRD offroad wheels on 2006
- Nav and Power differences between GX470 03-04 and 05-09
- Rear passenger door won't open either side. How to fix?
- Price Check? Front Struts
- Price / sanity check on service quote
- Gx 470 tail and head lamps are burning out very quickley
- Seat Position Sensor fault
- 2004 Lexus GX 470 With 118,240 Miles
- High pitched sound
- Front passenger window
- Everything going wrong
- ‘03 Exhaust question (and what to do next)
- Rear airbag trick, is a 2” lift too much?
- GX 470 as a daily driver
- Hi! New 2005 GX470 owner w codes. Any advice?
- Center Cap Damage
- Shocks replacement 2004 GX 470 but keep rear air bags
- Fuel smell after dirt road, then truck won’t start
- Will 2006 touchscreen / radio fit 2004?
- Just got one
- ABS and VSC dash warning lights disable on a GX470
- 2006 GX470 Radio Install (single din) / maintaining GPS
- GX470 A/C condensor fan not working
- Engine Cover
- Failed Spare Tire Carrier Mechanism
- Icon Remote Reservoirs
- FYI - Windshield replacement
- My new to me GX
- Any idea what this noise is or where it’s coming from?
- Seat memory not working with presets
- 2003 Lexus GX470 static sound
- Urgent advice needed
- TRD Off-Road Wheels on the GX
- LED Bulbs for Switches
- Looking for advice on a GX470
- Rusted Frame- Corroseal
- Air Fuel Ratio Sensor, upstream, bank 1 sensor 1
- Please help - Need advise on dealership repair opinion
- Electrical Issue
- O2 Sensor Bank 2 Sensor 2
- FREE: 2004 GX 470 Running Boards (Black)
- More questions... intermittent wheel shimming while braking
- GX470 to Prado tail light wiring help
- Covid nightmare getting tags
- 2004 gx470 help
- Bleeding Brakes Issue!!!
- 265/70/17 rubbing on stock setup
- smoke at start up.
- Do GX460 seats fit in GX470s?
- Need help with hood closure assembly part
- Bleeding Master Cylinder Solenoid
- Blind Spot Monitors
- Right Rear Quarter Window Latch
- Information service
- New Rear Brakes & Control Arm and now it rides TERRIBLE. What gives?
- Adventures in buying a new car
- Rear brake caliper sliding pin boot
- Interior lights working intermittently
- GX470 135K miles
- How to tell if factory installed tow package?
- 2005Gx470
- Advice on buying 07 GX470
- Lexus gx 470 2005
- 06 GX470 - am I getting hosed by the dealership?
- TRD RIMS ON my 2008 gx470
- Losing Coolant - Transmission Issue?
- Vr-602 highland bronze
- No squeeks
- Constant ABS/VSC lights on
- Drivers Low Beam Out
- Purchase Gx470 with 234k miles ?
- LED Headlights
- 2007 Lexus GX 470
- Trying To Get Aftermarket BT Yatour to Work Again
- CEL P2240 Doug Thorley Long Tube headers and Doug Thorley Y-Pipe
- Suggestions for buying OEM
- can't find coolant leak
- Service Manual for 1st Gen GX
- Blinker Relay Replacement
- Liners Debate
- Non-Nav Headunit Questions
- Quick AC question
- Location of Skid Control ECU
- Speaker Upgrade
- What is everyone doing for replacement carpeted mats?
- mud in tailgate weatherstrip
- AC Intermittent: Bad Compressor Relay
- New wheels!
- Lost maintenance records on Lexus drivers
- Popped my second rear diff What gives?
- Only have one Chinese option for an all aluminum radiator?
- 2006 GX470 Clunk noise (before / while stopping)
- Airbag Light/Reverse Lights
- Keeping Electronically Adjustable Front Suspension while Using Spacers
- How good is the factory alarm in a 2009 GX470
- Searching for mechanic or someone handy
- 2005 GX470 Hitch Part Number Help
- throwing a code P2445 Air system pump bank 1 stuck....
- 2004 GX470 transfer case lever grinding sound?
- 2004 GX470 Stock Tail Lights to Prado
- To buy a New Jersey 2007 GX470? (80k miles)
- best after market GPS for my Lexus GX470 2009
- My car won’t restart after the engine is warm
- Decided to buy a GX470 instead of GX460
- Phoenix Android Gx470 Updates
- Loud Noise Near Glove Box
- Factory exhaust piping size?
- Need a Fix for faulty Windshield Spray Nozzles
- Installing '06 4runner wheels on 2007 GX470
- Replacing the air springs
- 2007 Lexus GX470 - Keyfob 'Lock' button does not work after recharging the car batter
- Receiver help
- The Definitive LED Bulb Replacement Thread
- Very strange suspension problem
- 2006 GX470 Rust Treatment
- GX470 features and aux port
- Need Part Number
- New Member 07 GX470 Blizzard Pearl
- 2004 GX - Need help diagnosing stiff steering
- Radio / GPS
- RIM Advise - Looking to replace 2006 original rims
- Horrible A/C noise
- Brake Question
- 4.7 coolant hose
- Drivers Side Rear Door Handle
- Bluetooth for 2007 GX
- All Terrain Tires for GX
- brakes
- Wheel Spacers for GX470
- Detailed guide on how to remove interior panels/trim
- Broken Arm Rest Mechanism
- Odd noise from dash
- Sport Bumper
- Rearview camara with tesla phoenix radio
- GX 470 Replacement/upgrade Key Remotes
- Bulb replacement ride comfort switch
- 2008 GX Leak on the front Kick Pannels
- what parts to replace suspension (struts)?
- A/C condenser fan doesn't turn/spin
- Lexus GX470 KDSS
- Brake pad replacement
- 4LO engaged
- Cralicking Dash Speaker
- Height control problem
- What are you covering your center console with?
- New GX owner here
- New Seat Covers
- First time GX owner - Black '07 "build"
- New Owner and Build Thread!
- The Beast
- *HARBOR FREIGHT JACK STAND RECALL* Be safe and look at your 3 & 6 Ton Jack Stands
