08 Problem with Gas Gauge
Old Apr 11, 2022 | 05:20 PM
jds4u2's Avatar
jds4u2
Default 08 Problem with Gas Gauge
Normally, when pumping gas, pump clicks off, gas tank's full.
With my car, pump clicks off denoting a full tank but the gauge does not show that's its full 100%. It's always down by 1/4 tank.
This has happened 2x.
Any input? Thanks.
Old Apr 12, 2022 | 04:18 PM
chiph9's Avatar
chiph9
If you're certain the pump at the station is shutting off when it's full, it's probably a bad sender inside the tank.
(I have had problems with the new Costco vapor recovery boots shutting off too soon)
The tank has to be dropped to replace it, so as a courtesy, run it to less than 1/8 tank before leaving it with your mechanic. Since the gauge is inaccurate, you might have to go by mileage, not the reading. The part is around $150.
https://www.mylparts.com/oem-parts/l...QtN2wtdjgtZ2Fz
Chip H.
Old Apr 13, 2022 | 05:06 PM
jds4u2's Avatar
jds4u2
Thanks, Chip, I'll look into that. If memory serves, I think this happened a couple of years ago and it "fixed" itself. I've been trying to keep the tank full which is filling every other day. I like buying gas at Costco because they sell 10% above their cost which is lower and better quality than my neighborhood convenience store.
Old Apr 15, 2022 | 03:00 PM
Lexus4321's Avatar
Lexus4321
I posted a pic in the forum what an old 2006 240kmi sending sensor looks like. Super ez to replace, once after the pita tank drop. Might even need the tool to get the locking ring off.
Old Apr 16, 2022 | 03:49 PM
jds4u2's Avatar
jds4u2
UPDATE...
Filled it up yesterday and all was normal. Go figure. Properly at some time, it will need to be addressed but for now everything's good.
Thank you all for input and comments.
Regards,
jds4u2
Old Apr 17, 2022 | 07:17 AM
IanB2's Avatar
IanB2
Originally Posted by jds4u2
UPDATE...
Regards,
jds4u2
Maybe a strong candidate for putting sea foam or some similar product in the gas tank to work on any crud buildup that might be affecting the fuel level sender in the tank?
Old Apr 17, 2022 | 11:35 AM
chiph9's Avatar
chiph9
Maybe, but the pivot point on the sender should be a couple of inches above the bottom of the tank so there'd have to be a ton of crud in there to jam it up.
Or maybe rust - if the fuel had a lot of water in it (but OP would have had misfire codes).
I'm wondering if the float has become saturated, but from photos it looks like a hollow plastic box. So if it had a leak it wouldn't be a partial failure.
Chip H.
YWW
Feb 16, 2017 04:39 PM
b2884987
RX - 1st Gen (1999-2003)
Feb 2, 2017 12:33 PM
bored7one4
Aug 28, 2016 09:20 AM
jcuddy428
IS - 1st Gen (2001-2005)
Nov 30, 2012 07:05 PM
Sweetser
Nov 11, 2006 12:19 PM
