Check Air Conditioning System not connected error
Old Aug 17, 2021 | 01:19 PM
Singh007's Avatar
Singh007
Default Check Air Conditioning System not connected error
Hi All,
Ive owned my GX470 from the beginning, always done mainteance etc, no issues. Today it has 200K miles and AC stopped working. The panel for the AC buttons will not light up or do anything however all navigation and other systems and screens work fine, just not Climate, it throws that error. I checked all fuses and relays and everything is fine, radio also works etc. No after market products at all on this one. What am I missing here?
Old Aug 17, 2021 | 02:46 PM
chiph9's Avatar
chiph9
If you have illumination from the other switches on the dash, there's no reason why the heater control panel shouldn't light up.
Pins 12 & 22 go to shared interior lights
Pin 11 goes to ground behind the center of the dash
Also check fuse ECU-B, since that runs the A/C ECU (behind the right side of the dash) It is common for this fuse to go bad after 15+ years.
Chip H.
Old Aug 17, 2021 | 02:51 PM
Singh007's Avatar
Singh007
Chip H.
Hi Chip,
Yes sir, all of the other things light up and no issues with functions either, just the AC/HEAT buttons wont work, everything else works just fine, even the turn signals, Passenger airbag lights etc. When you say the ECU-B fuse, behind the right side of the dash, where do you mean inside the car or under the hood? I believe there are only 2 fuse boxes, one on the Drivers side kick panel and the other in the engine bay near the battery itself.
Thanks
Gary
Old Aug 19, 2021 | 06:15 PM
chiph9's Avatar
chiph9
According to Toyota, there's actually 4 fuseboxes (they count the two small ones by the under-hood fusebox separately).
The ECU fuses are in the main fusebox in the engine compartment. There are two 10-A fuses - ECU-B and ECU-B No.2
Chip H.
Old Aug 20, 2021 | 06:40 AM
Singh007's Avatar
Singh007
I had ordered an AC Amplifier which I replaced today,(Didnt mount it just swapped the wires over to the one i bought on ebay) AC buttons and stuff started working however now noticing the ac clutch is not engaging. Solid AC Light in the car, not flashing or anything. Double checked all the relays and fuses etc, they all seem good. What am i missing here? I dont think it could be freon because my AC has never had an issue and prior to this AC Amplifier issue, my AC was blowing Ice cold. Help..........
Old Aug 20, 2021 | 02:43 PM
Singh007's Avatar
Singh007
Went to a mechanic guy today that told me that my Freon is full, all relays work, and all fuses are good to go. He stated the Compressor is not getting power but wants $80/hour to chase this down. Anyone know what this might be before I open up my wallet to this guy?
ggaines10
GX - 1st Gen (2003-2009)
Aug 22, 2021 11:02 AM
yaknamean
Nov 18, 2017 09:41 PM
Tantrix
Mar 16, 2015 09:30 PM
Vortes
May 14, 2009 04:04 PM
Maximilien
Dec 29, 2002 01:59 AM
