- How to seperate trans dipstick line from pan?
- Help finding part number: Door Accent Light Clip
- HIDs
- IAT wiresc
- Air suspension problem
- Bilstein 5100s on rear GX...maybe?
- GX 470 vs GX 460 (power topic)
- 2007 Lexus ES intermittent wiper not working
- How to Repair/Replace Your AC Blower in Lexus GX, Toyota, more, Saving hundreds
- Brand for Trans and Diff Fluid Change
- Red light center of dash?
- To buy used or not - your opinions
- Water sloshing noise
- OEM front floor carpets
- Bent valves and dented pistons after shop botched timing belt change
- change gx trans fluid
- rear suspension
- rear hitch cover
- A/C leak solution- eliminate rear air?
- Water Pump Nightmare!!
- 05 GX470-Does anyone have OEM Windshield DOT # & Features
- Price difference worth it with KDSS and newer
- New Jersey Off Road Trails
- Seized Calipers
- New guy here
- A/C Clutch Relay Question
- Need some help, fellow GX 470 owners!
- NEW RR-Racing GX470 Brake Kit!
- Help with SRS Airbag light & B1100 Code
- GX Rear Shocks
- Joined the club! Got an 06, few questions for a new owner
- Fog Lamp (not the bulb) replacement GX 470 Gen 1 - 2007
- ECM pin out and O2 Sensors
- Newbie Tow Question
- Are these the right manifolds to order for my GX?
- Oxygen Sensor - Most update to date info for GX470
- interested in speaking to Lexus GX 470 owners with rusted frames
- Ceiling Mounted DVD Player - malfunction
- Trailer Package - Replace 7-Pin Wiring With Longer Cable
- New member from Southern Oregon
- New Guy
- OEM Body Parts Sourcing
- Help! Strange noise behind dash what could it be?
- DIY VL●OG: GX470 Front & Rear Differential and Transfer Case Flush
- Is there a DIY for lift install on a GX470 with KDSS
- 2006 GX470 ticking noise
- Best Aftermarket Air Springs and Shocks
- Detailed 165-70R17 Tire and Wheel Upgrade
- Nav Disc Player
- Help, Car starts, won't rev or go in gear
- DIY VL●OG: GX470 Air Injection Pump CEL P0418 & P2445
- Dilemma! What do I do?
- A little noisy coming off the ramps this morning
- GX470: No sound!
- Question on braking sensation
- Has anyone installed a push start or remote start system in a GX 470.
- 1999 lexus lx 470 rear door won't open
- Secondary air injection pump
- Bent Door check strap and bent window track
- 2005 gx470 H N L stick broke??
- Upgrade resolution of 2004 GX470 rear camera?
- Right Height Sensor
- Cold Air with Heat on
- GX470 doing great in winter storm Toby
- 2006 GX470 blowing the ECU-B Fuse
- Need Alternator & Radiator
- HELP Alternator replaced now my Nav & Radio Will not Work
- Oil in the manifold?
- Gx470 Battery Drain fuse 44
- GX Key
- Gx470 AC Compressor Ticking with RPM
- wheel size
- Rearview Camera Wiring to Video Screen
- Gauge cluster problem + dead RPM gauge
- Side mirrors malfunctioning
- ls460 coil conversion
- Radiator Replacement?
- Diagnostic Scanner Tool?
- Switch Next to 2nd STRT on 2003 GX470
- Whirring noise - pulley? tensioner? PS?
- How many MILES on your GX TODAY? What year? Repairs done?
- codes c1201, p0138, p2195
- How to disable child lock in Lexus RX 330
- Cold Air Intake Suggestions?
- Power Steering Preventative Maintenance and Fix
- Front & Rear suspension upgrade Recommendations
- New Dude
- 4th Gen 4Runner exhaust on gx470
- Thinking of a GX470 for a daily/beater/tow rig
- Rhino Rack Pioneer Platform Mount options
- 2006 RX400h GPS update
- 2008 gx 470
- Actuator noises behind the dash
- Cricket Sound
- High pitched sound under hood 2003 GX
- Air Spring, F+R Shock replacement Lexus OEM parts
- Need a Replacement Steering Wheel for the GX
- Original Timing Belt - Help me decide (Video)
- Best Aftermarket Exhaust
- Safe?
- Max lift to keep alignment specs in range? (without UCA)
- mark Levinson speakers
- New Owner - Buying a 1 owner 2006 GX 470 w/128K and always garaged - from CA
- P0418 & P2445 after jumper cables shorted
- aftermarket seat covers
- 2007 GX470 PCV Valve
- Searching for the cheapest trailer hitch
- Only buy OEM quality CV Boot kits
- Strange Brake Sound
- Spilled water between console and seat. Radio died, nav and screen went dark -FUSE?
- Finally found a use for the tape deck!
- Need some quick buying advice
- Good Arguement for turning DRL off with Pics
- Transfer Case Oil Change
- Spark Plug Gap GS300
- Rear window will not roll up after battery disconnect & bad gear changes
- Buying my first GX470 - which one to get?
- TRD Supercharger Transfer From Sequoia to GX470?
- Safelite Auto Glass?
- Intermittent ECU Issue in cold weather
- vsc, trc, engine light abs and brake light is on
- Brake Upgrade for GX470
- Recent 2008 GX470 Purchase
- Axle Seals
- 2006 GX 470 wheels vs 4 runner wheels
- 2005 GX470 - How long will it last
- gx470 2005, p0420 ,p0430
- Best lift for $1500
- Down Shifting
- Bilstein 5100 install time?
- Tire Options
- Gx470 height control flashing off
- my Lexus RX-330 beeps 2 to 3 times when hits bump. No warning lights came on
- 2004 GX 470 vs 2008 4Runner
- Gx470 Spark Plugs
- Timing Belt Question
- LED Headlights pattern is horrible
- 05 GX470 non-nav stereo replacement
- Lexus LX570 Parts
- 2017 GX wheels/tires fit 2006 GX?
- Transfer Case Actuator Leaking - HELP!
- Anyone ever hear of this 1?!?!?!?!
- Has anybody here replaced 85535-60050 "cover, power outlet" (in the console) ?
- New GX470 owner, battery indicator light Q.
- LED vs HID Replacement Bulbs
- GX470 2006 Oil Pressure Sensor Location
- Climate Control Bulb
- 2006 GX new owner first mod cabin filter
- BRAKE pedal humming after I installed new pads.
- Anyone tried these - Tang Band 6x9
- Other than Lexus where can I get a spare key fob for a ct200t 2016?
- Alternator?
- Timing belt 124k
- Navigation warning screen on start up
- 2005 GX sudden total electrical failure
- Dash kits
- 2005 gx470 rear view power, remote door out
- Running Fan and Low Coolant
- Will GX460 brake calipers fit on the GX470?
- vsc light on
- Key won't turn in ignition...any suggestions.
- 08 GX New Alternator Black Nav, Help!
- Bluetooth Capability?
- Rear end bottoming out.....
- Help Identify part: 3rd row seatbelt guide/keeper
- I am not getting any outside air into the cabin
- 2007 lexus gx470 air suspension
- Airbag light coming on in cold weather
- 2007 lexus gx470 rough ride
- Front strut change out
- Looking to buy low mileage 2008 GX470
- lexus visors for 1997 4runner
- Lift while keeping air suspension
- GX470 Small Lift 1"
- Tire Sensors serviced and within 2 hours rear height of vehicle is lower and bounces
- Navigation Won't Run
- Mechanic in Austin, Tx area
- odd issues. Symptoms of low battery voltage
- How do ichange the transmision fluid?
- A T Oil Temp light on - car won't run
- C1340 - Open Circuit in CDL signal
- Second Row Seat Strut (Stay/Prop)
- Removing 2nd Row Seats
- Traction Control and VSC not functioning - no lights on dash
- Driver Side Air Mix Servo Location
- Ceika big brake kit,,,, anyone???
- Need some radiator advice
- Giving up. Exercise in futility
- Take the Takumi Cats challenge
- After Irma windshield woes
- Re: Lexus gx470
- GX470 Wooden Dash Bezel
- Just bought my 07 GX- need tire advice
- Toyota techstream help...
- My GX470 DOES NOT RESPOND TO ACCELERATION IMMEDIATELY ABOVE 50MILES PER HOUR?
- Codes P1441 P 1444
- Question regarding headlight for 03 GX470
- Ride Control Blinking "OFF"
- FJ rear springs
- Quarter Belt Molding replacement
- Just bought my first Lexus 1st gen GX
- Transmission leaks
- GX470/truck
- # of hours of labor for rear coil conversion?
- Can I DIY a rear suspension airbag replacement
- Help Decipher Caution Lights On Dash
- OEM Flasher Relay Mod
- Help valuing my GX if I decide to sell?
- Tire size dilemma...
- Help evaluating pre purchase inspection
- Lexus service history shows nothing?
- Suncore Air Springs
- My 2004 GX470 needs a new makeover
- Catalytic Converter
- AC issues in potential buy - how expensive can the repairs get?
- Interior lights
- 90k Mile Service
- 05' GX470: Advice on Determining If Wheel Bearing is in need of Replacement
- Best aftermarket brakes for a 2004 Lexus GX470
- 13 years Time to upgrade
- Install Aftermarket Camera
- '05 GX470 Remove 3rd Row?
- Which way should the hitch bar go?
- What is the odd sound coming from engine?
- VSC Light on?
- 06 gx flip down DVD remote will not work
- Kal El’s 2007 GX470 -build/progress/maintenance Thread
- PSA~Shocks and Struts
- First Road Trip
- 150k miles service items?
- Having trouble putting gas in fuel tank
- Rear Suspension died - Now what??
- 2007 GX 470 rear wiper motor replacement options
- Sold my Supercharged Land Cruiser and lifted my ‘08 GX470!
- Leaking transmission fluid from radiator cooler
- Good tires for NYC ??
- Mark Levenson Radio wont come on irradict
- P0420 & p0430
- Weird TPMS issue
- CEL, VSC Trac, VSC OFF, Dash lights all came on
- Help! 2004 GX470 rear hatch locked siezed
- Will Tacoma TRD Wheels Fit?
- Passenger Side footwell
- Air Injection System Bypass kit, anyone actually use one?
- Gx 470 fender flares
- Fuel tank strap
- Vibrations over bumps
- Replacing stock with high performance Brake Parts
- Roof Rail delete
- Elm327
