View Full Version : Suspension and Brakes
Pages :
11]
12
13
14
15
16
17
18
19
20
- Is brake drag normal?
- Cross Drilled Rotors ?
- Spring recommendations...
- is vs gs f-sport springs
- Brakes..At a Loss.. HELP!!!
- ride quality with fsport springs
- coilover installed- now car has a strong vibration on D
- quick ques about sway bars
- Megan Camber Kit Intsall
- vossen wheels + tein s. tech= rubbin?????
- question about BC Racing coilovers
- H&R Springs on F-sport Shocks
- Anyone install their springs themselves?
- Dealer installing Rear sway bar.. questions
- lookn for the rite drop
- Slammed IS, rubbing front tires
- Megan LP Damping Setting
- Sways or Springs first?
- Buying new brake pads...some questions
- Adjusting BC coils for ride comfort?
- my car is bottoming out, ahh!!!
- Camber adjustment?
- Alignment suggestions
- How to tell when needed to replace brake pads?
- Any IS 2nd Ksport Air here?? Need help
- Should I replace brake pads and rotor at the same time?
- Anyone or vendors selling awd lowering springs?
- Please help, Wheel question
- Before and After, Eibach Pro Kit and H&R spacers
- Handling with new wheels/tires
- Please help with springs
- lexus lean please define exactly what this is
- Negative camber with only coilovers??
- I've caved.. buying coils. What type should i get?
- 5mm spacer with OEM stud?
- Question about is350 brake system on is250
- Noob question... (driver side shock not working well)
- Eibach vs. S Tein vs. H&R springs?
- Questions ..
- How does my alignment look?
- did anyone have any problems with the headlights after droping there 2isx50
- 2011 IS 250 Drop spring problem HELP!
- Metal Hollow Noise on the road
- CLICKING noise when shift into park
- 2008 IS350 Front Brake Rotor and Pad Replacement
- suspension question need help!
- Asked for low dust breaks got old ones?
- brake squeak temp fix
- Sage front RCAs, i need them!!!!!
- IS350 Break Pad replacement TSB: Dealer Overcharge
- Slammed AWD ISx50s and CV Boot
- lowering 2011 is250awd?
- should i get these coilovers?
- Struts??
- Looking for new braking system
- Coilover information
- Help! [which front brake pads]
- IS350 brembo blanks
- hey what color is a good brake caliper color for glacier frost mica
- brake fitting kit??
- Excessive wear on rear inside tire. What is the correct settings for TOE?
- Clunking is making me go nuts!!!
- Megan Springs
- Sewell rear sway bar?
- Front Camber Kits
- IS250 AWD Axle Nut Size
- Please reply if you did NOT get an alignement after spring drop
- Question about Coilover Spring Rates
- EBC Redstuff Brake Pads - ceramic
- Rotor resurfacing and brake pad changed. however
- Had My F Sport Springs Installed Just One Question
- F-sport springs
- Requesting Pics of IS250 AWDs dropped on springs
- improved f-sport spring design
- Frequency of maintenance on BC Racing Coilovers?
- Shop to install Road Magnets?
- Tein S-tech and 20" wheels
- Brake Line DIY
- Brake Kit Suggestions
- Scrub Radius
- non-OEM low dust brake pads - what to buy
- Motul Brake Fluid
- IS350 brakes do NOT fit IS250 AWD
- Looking for pin holding clip for rear brake pads
- IS300 Front Camber A-Arm Compatible
- Rotor and Pad Recommendation
- Do we need zero point calibration after an alignment?
- Photos of KW V3 on max drop, anyone?
- Looking for OEM replacement shocks
- Steering Damper
- im about to purchase springs..but im a NOOBIE helpp
- Drilled / Slotted Rotors
- F-Sport Sway Bar rear only
- crackling sound when i ride the brakes?!?
- Brake gurus I need your help.
- F-Sport Springs on Standard Shocks
- F-Sport springs on F-Sport Package shocks
- F-sport springs vs. Megan coils
- Coils questions
- Megan VS BC
- Warranty issue with installing f-sport springs
- Camber Kit Install Help??
- Chime in if you have an awd with new springs on the oem shocks
- ISF brake upgrade
- question about brakes with 2006 is250
- Should I Put My New F-Sport Springs On Or Not?
- Wilwood brakes questions
- AFS Off After Coilover Install
- After Market Brake Pads???
- opinions for springs on a IS250 AWD
- question on springs
- Megan EZ Coilovers - Preinstall Questions (please help) *w/ pics*
- OK got my BC coils....
- Aftermarket rotors - Best place to buy
- Better overall ride comfort, fsport springs or coils?
- Tips for adjusting coils?
- My alignment, any suggestions
- AWD w/BCR coilover Wobble gone, Leaky CV Joints
- Anyone here using those Starke coilovers?
- BCR coils
- 250 rwd: Alignment after tein s springs??
- Anyone have pics of 19's dropped on the F-Sport Springs or other Springs
- BC vs Megan Coilovers
- First ever CL - Rotora BBK photoshoot
- Requesting: Pics of IS x50 droped on F-sport springs!
- New brakes?
- adjusting ride height Megan LP Suspension
- Squealing brakes in the morning? / 5000 mi check up
- 06 rear rotor / pads fit on an 07?
- still no camber kit available for front on IS350's
- brakes
- For those who have BC COILS Chime in!!
- BC coil owners what's your spring rate?
- Question - F Sport Kit - F Sport Lowering Springs
- Brake Fluid Question
- squeal replacing brake pads
- Just got an Alignment, What do you guys think?
- My Dilema
- Cheapest place to buy tein s springs?
- -camber tire wear...
- IS250 Rear camber adjustment
- Megans VS H&R
- Question about what tools/supplies needed for following mods: sway bar install...
- Installing BC coilovers!
- Suspension clunk from passenger rear - BC Coils
- f-sport spring installation time and cost
- Brakes and Rotors replacement. Do outside dealership?
- Springs
- Help: bang for your bucks coilovers
- JIC Magic Coilover models
- F-Sport Full Faced Wheels with Sport Suspension?
- Is Alignment Necessary?
- X pkg on F sport springs
- Swift assist?
- Megan Rear Arms. What do I need?!?!
- How long do springs last?
- Another Knocking/Clunk On Front F-Sport Sway Bar Now...Ugh!
- Question Adjusting Megan Coilovers
- Please Help - AWD Sway Bar advice - Dealer wrong?
- Brake Question Help Needed
- HSD Coilovers
- IS-F suspension on IS350?
- Slight Vibration at idle after BC Coil install
- Tein CS Coilovers - Good deal?
- Please help me! On stock f springs on a rwd is250.
- Sewell f sport springs question
- Road Magnets spring
- Best Caliper Paint
- IS350 Brake Calipers
- Brake Pad?
- Rolled fenders or stock springs?
- 245/35/19's and lowering with Megan springs
- F sport brake vs stoptech brake
- IS250 AWD Coilovers...
- Brake pedal clicking noise
- HELP! AWD Shocks and Springs
- G2 Blue Paint w/ Rotora pads/Rotors and GFX stickers
- Sport Tuned Suspension part numbers? (Do they exist?)
- Stainless Steel Brake Lines
- F-Sport springs/shocks combo or BC Racing BR coilover?
- Camber plates
- Any actual data with coilover or F-Sport suspension on IS 350?
- is this a good deal??
- F-Sport Sway bar question
- Firestone Lifetime Suspension Service
- BCR Coils with F-sport rear sway?
- F-Sport springs out, BC Coilovers in FTW
- Megan EZ Street or Street LP Coils?
- FSport Sway Bar Question???
- 2is rear brakes
- Megan Racing Srings anyone????
- Pic request: IS250s with Tein springs
- Question about the ABS brakes
- SAGE SS RCA Front and Rear where to buy?
- Need to replace brake pad!! is EBC RED Brake Ok??
- Cars that are lowered on spring chime in!
- 32k miles should i change pads with fluid?
- For those lowered on Tein S-Techs, how often do you scrape or bottom out?
- IS250 Seized Front Caliper slide pin
- Megan ez baller on budget or BC COILOVERS?
- annoying brakes
- How does my alignment look - IS250 AWD
- High pitch squeaks with new install of EBC Red Brake Pad and EBC Sport Rotor
- 2006 IS350...Springs/Spacers ???
- Aftermarket Brake Rotor Options
- Low dust rear brake pads for IS250?
- RESURFACE or REPLACE Rotor? What do you think?
- Which F-Sport should I get installed first?
- Eibach pro is350 vs Tein H
- Best Lowering Springs
- Awd is250 coilover questions
- what are the sizes for the 2011 18'' staggered rims
- $2500 for F-Sport spring!?
- question for coils on my 2010 is350
- New Coilovers, Brakes and track wheels.
- Mechanic tells me i have to change my rotors w/ a break pad change... this true?
- ideas to improve handling of IS250
- definitely getting the f-sport springs, but is the f-sport shocks a must?
- Is something wrong with my brakes?
- suspension creaking/squishing sound
- F-Sport Shocks + H&R
- Spring rates?
- Suspension overhaul
- best coils
- Am i lowered??
- Lowering affect turning radius?
- Comprehensive Coilover Ratings
- F-sport springs
- Suspension Question Scenario..
- New springs going on my baby this Sat. am excited!
- AWD guys that went from springs to coils
- Coilover Rebuild
- $500 Lexus GC F-Sport shock and Tein?
- Brake Decals
- is250 lower spring issue?
- 06 IS250 Clunkin noise when turning
- THANKS circuit motorsports
- Did Sewell double the price of there Brake Kit Upgrade?
- Is it necessary to resurface rotors when replacing brake pads?
- Can I drop ONLY the front?
- New Alignment - Check my specs
- 2007 IS350 - Brake Pads
- time to replace these rotors?
- Gs350 awd springs on is350 rwd?
- Adjusting my BC Coils Dampening??
- Camber vs Toe
- F Sport Big Brakes?
- Question About Lowering My Car!
- Correct Way to Lower BC Coils??
- help on bc coilovers
