How does my alignment look?
Old May 19, 2011 | 08:57 AM
flektone's Avatar
flektone
Default How does my alignment look?
I really dont know much about alignment specs so can you tell me if mine is where it should be? The only thing is im lower a 1/4" on the left side of my car. I didnt mess with the coils out of the box because to me the drop looked even all around. As of right now im not going to raise it up 1/4" to match the right because I just spent $140 on an alignment. The guy told me it wont result in signifigant uneven tire wear. I will probably fix it in the fall or next spring. I only drive the car about 10k a year
Old May 20, 2011 | 02:24 PM
flektone's Avatar
flektone
no one knows alignments?
Old May 22, 2011 | 06:59 PM
CarbonDtls's Avatar
CarbonDtls
Looks ok, rear has some negative camber and toe seems a bit high but you should be ok.
Old May 26, 2011 | 12:51 AM
mindf's Avatar
mindf
My settings can be found HERE. Rear TOE is similar to yours and my rear tires doesn't even last 10k kilometres.
Old Jun 20, 2011 | 06:01 PM
BigA86's Avatar
BigA86
u r goin to have inner tread wear for sure!!!
Old Jun 20, 2011 | 06:11 PM
Salduchi's Avatar
Salduchi
Do you feel any difference in the drive/handling? I just scheduled an appointment with West End for mine.
Old Jun 20, 2011 | 06:48 PM
Denver's Avatar
Denver
you will wear out your inner tires, they should have put it into specs with only .25" drop
Old Jun 22, 2011 | 07:58 PM
FutureITR's Avatar
FutureITR
There's no caster adjustment kit? That's a crap load.
They could have adjusted your toe a lot more couldn't they?
Old Jun 22, 2011 | 08:32 PM
VIS250P's Avatar
VIS250P
U be fine.. Does it drive straight?
Old Jun 24, 2011 | 09:50 AM
flektone's Avatar
flektone
yeah, it drove straight before the alignment, feels the same after
idk, the guy said thats all he can get out of it. im thinking cuz one side is "1/4 lower then the other thats whats throwing it off
no, no difference.
Bender25
Mar 13, 2012 07:27 PM
Lexy602
IS - 1st Gen (2001-2005)
14
Aug 7, 2010 07:10 AM
qgoat
Suspension and Brakes
Mar 18, 2010 04:19 PM
MarcusMIA
Oct 14, 2009 07:08 PM
bishop977
Maintenance
Jun 15, 2004 10:16 AM
