IS250 can't compete with the big boys in hp, i'd like to go toward improving the handling. other than springs/shocks and sway bars, any other ideas to reduce weight and improve handling on our 250?
Does the body brace even help with handling? Correct me if I am wrong, but I have heard that body braces are ineffective?
You might make the "feel" a bit different, but as far as getting around corners faster? Nope.
Maybe after doing every single other thing in this thread including corner balancing and slicks, on a prepared track, you might then be able to measure some actual benefit from a body brace, but otherwise it's dead weight on the car which is the opposite of what you want.
Thanks Kurt for the info! That's what I thought. So installing struts and braces are just useless.
