Headlight compatibility
Old May 31, 2023 | 02:43 PM
barnyarnavitch's Avatar
barnyarnavitch
3rd Gear
Default Headlight compatibility
Hello
Can someone tell me definitively if 2014 headlights are plug and play for a 2011 IS F ?
Old May 31, 2023 | 03:03 PM
Lushman's Avatar
Lushman
I can't give you a 100% definitive answer, but most products like headlights are offered as being compatible for 08-14, like these VLands.
https://vlandshop.com/product/06-12-...with-blue-drl/.
One thing you could do is call your local Lexus dealership and confirm the part number for the 11 and 14 year headlamp models. If they're the same part number, you know they're compatible.
Old May 31, 2023 | 05:31 PM
barnyarnavitch
3rd Gear
Thanks Lushman for the timely response.
The dealer cant/wont do backwards compatibility. Understandable.
V Lands are not an option for me personally.
I searched the forums a while back and think I found someone who said they would work.
Since I'm ready to pull the trigger I'm looking for confirmation.
Thanks again for your time.
Old Jun 1, 2023 | 04:45 AM
lobuxracer's Avatar
lobuxracer
Tech Resource
The last date I can find for a part number change is for cars produced 09/2011, so if your build sticker shows after September 2011 production, your lights are interchangeable through the end of the model run.
Old Jun 1, 2023 | 08:04 AM
Lushman's Avatar
Lushman
Hi Barnyardavich,
First of all, listen to lobuxracer.
Second of all, sorry, I wasn't clear. I meant if you call the dealer asking for the part number for a '11 ISF headlight, get that part number, then call back and ask for the part number for a '14 headlight, then you could use that as confirmation it's the same part number. But forget that now, just listen to lobux.
Old Jun 1, 2023 | 08:45 AM
barnyarnavitch
3rd Gear
Thanks lobux.
My production date is 07/2011.
Am I out of luck?
Were the changes simply in temperature or connection?
And thanks again Lushman I've been lurking long enough to know to trust and respect lobuxracers advice!
Old Jun 1, 2023 | 11:04 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Originally Posted by barnyarnavitch
Thanks lobux.
Am I out of luck?
I wish I could tell you what changed, but the only thing I know for sure is the part number change. It might be trivial, or it might not.
JomsyandG
IS F (2008-2014)
Mar 25, 2023 07:34 AM
Meraki Autoworks
Dec 30, 2014 07:31 PM
Meraki Autoworks
CL of Southern California
Jul 23, 2013 09:33 PM
dci4life
Sep 30, 2012 04:21 PM
flm
Mar 13, 2002 09:33 PM
