AA80E Swap and Control
I’m looking for some guidance. I am considering swapping an AA80E into my SC. I’m fairly certain that any of the “better” standalone computers can control the transmission, but cash is going to be tight with the economy slowing down a bit. So, I’m weighing swapping the transmission and using a factory ECU for the engine and a separate controller for the transmission. I found something called MegaShift which may work, but I haven’t seen any real world cases using the AA80E.
My thinking is to switch to a standalone in the future, so keeping it a low cost solution is imperative. I don’t want to spend a bunch of money and then throw it away later. Any ideas would be appreciated fellas.
Thanks!
Nick
Thanks!
Nick
Nick
I found some information from Mega Shift which implies it’s possible, but I don’t know if anyone has done it and the transmission needs certain engine parameters sent to it as well. My ‘97 SC400 doesn’t have DBW, so blipping on downshifts may prove tricky, but I figured I could perhaps do that manually, to some extent.
Nick
Does anyone have a wiring diagram for the transmission? I’m interested to learn what information is coming and going from the Transmission Control Module. I’m thinking I may be better off adapting the transmission AND the module to avoid having to tune all the driveability and behaviors and shift logic after the swap. If I can supply whatever voltages it requires from a standalone, then I would be good to go, in theory.
And just to confirm, the ISF does NOT run on CAN BUS, correct?
Thank you guys!
Nick
Thank you guys!
Nick
Thank you guys!
Nick
Thank you guys!
Nick
Any info on transmission control module wiring?
Thanks for your feedback!
Nick
For what it’s worth, I wanted to also swap the ISF cluster into my SC, to eliminate any issues there and update the look of the cabin. The basic shape of the clusters is similar, so it’d be a little fiberglass work and leather wrapping the dash — shouldn’t be too difficult.
Nick
You'd be way ahead to buy a 2 day subscription to TIS and get all the wiring diagrams you need. The good diagrams are color coded. The printable overall diagrams are not. You'd be better off with color screenshots IMHO.
Nick
eefmydee
Feb 26, 2017 03:19 PM
