ISF Valve cover/Spark plug gaskets
Old Jun 8, 2022 | 07:50 AM
rmillsISF's Avatar
rmillsISF
Default ISF Valve cover/Spark plug gaskets
I need to get the spark plug gaskets done on my ISF but I want to know what other seals to do at the same time. I've heard there's a few oil seals and the valve cover seals that I may as well do at the same time. IF anyone has all the part numbers or at least seal names I need to look for that would help a ton!
Thanks
Old Jun 8, 2022 | 03:04 PM
Rickna's Avatar
Rickna
Using search can be quite helpful-
https://www.clublexus.com/forums/is-...r-gaskets.html
https://www.clublexus.com/forums/is-...ction-yet.html
Old Jan 11, 2025 | 03:00 PM
O1GS43O's Avatar
O1GS43O
Just did mine. Wasnt to bad. bought $150 in gaskets and less than 8hrs working slow. I did mill down the 3 bolts on each side. The ones that top has threads that didnt have anything thread on to them.
Old Jan 11, 2025 | 08:16 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
What three bolts?
Old Jan 12, 2025 | 02:59 AM
O1GS43O's Avatar
O1GS43O
What three bolts?
The center bolts
Old Jan 12, 2025 | 05:15 AM
O1GS43O's Avatar
O1GS43O
Side note. I would highly recommend doing the passenger side first as for me it was the most challenging side. Also I would say to torque all the lower 10mm value cover bolts first as they are the hardest to get to. I'm a huge fan of taking on the most difficult things first so the rest is easyer.
Old Jan 12, 2025 | 04:06 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
That's not a good plan for getting a good long lasting seal. You need to start in the middle and criss cross top to bottom the same as a head gasket if you want even pressure on the gasket. Tightening one side first ensures your torque values will not be helping you at all.
Old Jan 12, 2025 | 04:19 PM
O1GS43O's Avatar
O1GS43O
Well I did the 3 middle bolts first. Lol
eknine9
Dec 24, 2014 10:59 PM
NihS07
Aug 30, 2011 06:52 AM
02msmg3
Dec 16, 2010 10:50 AM
elscorcho
Jun 18, 2005 03:29 PM
