Square setup with OEM 19" X 9.5" wheels on front
Has anyone here made/run a square set up putting OEM 19" X 9.5" on the front ? With 255/35's there is plenty of clearance lock/lock and 1/4" clearance between the inside edge of the tire/wheel and spindle so I would definitely need to add a spacer. I like the OEM wheel/paint color combination and am trying to maintain the "stock" appearance. And badly rolled the front 225/40 PS4S's during last track day. Next steps in my thinking are adjusting in more negative camber ( have R&R UCA's), square set-up, and going to coil overs.
square 19x9.5 +38 265/30/19 all around, lowered a good amount. Shaved rear quarters, no mods to front wheel wells except replacing protruding bolts with flat bolts/screws to hold fender liners on. I have total clearance full lock, unless I'm at a bump in the road. -2 camber F&R. I also heat gunned the fender liners back a bit.
Johnny
Jul 22, 2008 03:34 PM
